Tomcat runs good but don't stop correctly [message #212230] |
Thu, 10 April 2008 12:34 |
Originally posted by: alessandro.zucchi.zucchetti.it
Hi all,
I'm using Eclispe 3.3.2 (WTP 2.0.2) with Tomcat 6 and Java5 (update 15) on
Windows Xp sp2.
My web application runs ok but when I try to stop Tomcat by "server view"
Eclipse is not able to shutdown tomcat process the wait for ever. Only
killing the process with Task Manager resolve the problem.
I tried with Tomcat 5.5 ,with java5 but nothing.
Any ideas?
Best regards
Alex
Re: Tomcat runs good but don't stop correctly [message #212246 is a reply to message #212230] |
Thu, 10 April 2008 14:22 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
Alex wrote:
> Hi all,
> on Windows Xp sp2.
> view" Eclipse is not able to shutdown tomcat process the wait for ever.
> Only killing the process with Task Manager resolve the problem.
> Any ideas?
> Best regards
> Alex
I assume that Tomcat starts to shutdown, but never finishes shutting
down. This can be an expected Tomcat behavior. Tomcat will wait
forever for all webapps to "cleanup" before exiting. The typical cause
is a webapp starting a Thread, directly or indirectly, which is not set
to daemon mode (i.e. Thread.setDaemon(true) ). The means that the
webapp will have to stop the thread itself before Tomcat will exit. If
this appears to apply to your situation, you can start Tomcat in debug
mode and after attempting to shutdown, check the Debug view to see if
you can spot any "extra" threads.
If it seems like something else is going wrong, please provide more details.
Larry
FUDForum. Page generated in 0.04131 seconds
