| change eclipse vm frequently: easy solution? [message #211937] |
Wed, 10 August 2005 03:16  |
Originally posted by: aks.terma.com
I cannot be the only one with both new (java 1.5) and old (pre 1.5) projects
who changes the eclipse jre all the time to avoid
- very slow eclipse (when using old projects with java 5)
- reserved keyword errors when using i.e. 'enum' in my package/class names
etc.
- etc.
I doesn't help to change the project vm, only to change the eclipse vm (in
preferences, java, installed jres, checkbox)
I use 1.4.2_03 or 1.5.0_02
So I change the VM all the time
Does anyone have the same problem?
/aksel
| Re: change eclipse vm frequently: easy solution? [message #212016 is a reply to message #211951] |
Wed, 10 August 2005 11:07   |
Originally posted by: eclipse3.rizzoweb.com
Aksel Schmidt wrote:
> Hi Csaba and thanks for the effort
>>1. Change the project jvm to an 1.4 java (Project properties / Java Build
>>Path / Libraries)
>>2. Change the source compliance level to 1.4 (Project properties / Java
>>compiler / set Enable project specific settings / Compiler compliance
> level:
>>1.4)
>>3. If you have run configurations you created before you maybe have to set
>>the the jvm in the run configuration / JRE tab.
> Thanks, I still have problems with my Enum-class (eclipse compiler finds the
> 1.5 'java.lang.Enum' and gets confused)
> (It is a small thing, but our enum is used *everywhere*)
> How can the compiler suggest a 1.5 class with all the above settings?
Check the Libraries tab of the Project's build path settings. Chances
are it is referring to the JRE 1.5 library (if that was the workspace
default JRE when you created the project). Just select that entry and
then click Edit to change it to the proper JDK.
>>Also - if your pre-1.5 and 1.5 projects are not dependent on each other -
>>you can create two workspaces: one for 1.5 projects and one for 1.4 ones.
> I believe more in this one - I just felt that with all these parameters and
> compliance levels, it should haven been working with a recipe like yours
> your second solution will work, or a simple plugin that will bring the
> eclipse vm selection to some buttons on the toolbar ('Use 1.4'/'Use
> 1.5'-like)
There is no need to "change the current VM" - in fact, that doesn't make
sense because each project and launch configuration can be associated
with its own JRE settings. Once you get your projects and launch configs
set up properly, it just works. Trust me: I currently have Eclipse
itself running under JDK 1.5, have some 1.4 and some 1.3 projects in my
workspace, and occasionally create a 1.5-based project for testing stuff.
HTH,
Eric
| Re: change eclipse vm frequently: easy solution? [message #212077 is a reply to message #212016] |
Wed, 10 August 2005 15:37   |
No, its 1.4.2 alright (and always has been)
I dont want to make a big thing out of it - there is a workaround (change
the vm), but fact is that my bla.bla.Enum class is considered ambiguous as
the java.lang.Enum (of java 1.5) clashes with the (*) import of the Enum
type.
In smaller 1.4 projects, I just use explicit imports, but in projects using
Enums 1000+ places, it makes me use the easy solution which is 'change the
eclipse vm'
it sounds stupid alright, cant explain it, why I asked here...
/aksel
| Re: change eclipse vm frequently: easy solution? [message #212084 is a reply to message #212077] |
Wed, 10 August 2005 18:18   |
> type.
> eclipse vm'
The only way for the bla.bla.Enum class to be ambiguous with the
java.lang.Enum class in 1.5 is for the 1.5 jre jars to be on the build
path. How are you specifying the jre jars on your projects build path?
If you are using the JRE_LIB variable, then changing the default jre in
the preferences is changing it for your project.
If you want to make sure that a given project always uses the 1.4 JRE
classes on the build path, you need to remove the JRE_LIB variable and
replace it with an explicit reference to a 1.4 JRE.
Project->Properties->Java Build Path->Libraries.
Select JRE_LIB and click the Remove button.
Click the Add Library button.
Select JRE System Library and click Next.
Select Alternate JRE and select the appropriate 1.4 entry from the drop
down box.
Your project will now compile against 1.4 classes no matter what you pick
for the default JRE.
> /aksel
| Re: change eclipse vm frequently: easy solution? [message #212111 is a reply to message #212084] |
Thu, 11 August 2005 06:03  |
------=_NextPart_000_0010_01C59E6C.B5B85420
Content-Type: multipart/alternative;
boundary="----=_NextPart_001_0011_01C59E6C.B5B85420"
------=_NextPart_001_0011_01C59E6C.B5B85420
Content-Type: text/plain;
charset="iso-8859-15"
> The only way for the bla.bla.Enum class to be ambiguous with the=20
> java.lang.Enum class in 1.5 is for the 1.5 jre jars to be on the build =
> path. How are you specifying the jre jars on your projects build =
path? =20
> If you are using the JRE_LIB variable, then changing the default jre =
in=20
The jre classpath looked like this (and followed the eclipse jre to =
1.5.0 when this was selected):
=20
> If you want to make sure that a given project always uses the 1.4 JRE=20
> classes on the build path, you need to remove the JRE_LIB variable and =
>=20
> Select Alternate JRE and select the appropriate 1.4 entry from the =
drop=20
> down box.
>=20
> Your project will now compile against 1.4 classes no matter what you =
pick=20
>=20
yes - after this event, the jre version will stick to 1.4.2, otherwise =
it will follo the eclipse jre..
you can't tell the difference on the build path view though...
Thanks! :)
/aksel
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-15">
<META content=3D"MSHTML 6.00.2800.1505" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>> The only way for the bla.bla.Enum =
class to be=20
ambiguous with the <BR>> java.lang.Enum class in 1.5 is for the 1.5 =
jre jars=20
to be on the build <BR>> path. How are you specifying the jre =
jars on=20
your projects build path? <BR>> If you are using the JRE_LIB =
variable,=20
then changing the default jre in <BR>> the preferences is changing it =
for=20
your project.<BR></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>The jre classpath looked like this (and =
followed=20
the eclipse jre to 1.5.0 when this was selected):</FONT></DIV>
<DIV><FONT face=3DArial size=3D2><IMG alt=3D"" hspace=3D0=20
src=3D"cid:000b01c59e5b$f22c76e0$e6f014ac@terma.com" align=3Dbaseline=20
border=3D0> </FONT></DIV>
<DIV><BR><FONT face=3DArial size=3D2>> If you want to make sure that =
a given=20
project always uses the 1.4 JRE <BR>> classes on the build path, you =
need to=20
remove the JRE_LIB variable and <BR>> replace it with an explicit =
reference=20
to a 1.4 JRE.<BR>> <BR>> Project->Properties->Java Build=20
Path->Libraries.<BR>> Select JRE_LIB and click the Remove =
button.<BR>>=20
Click the Add Library button.<BR>> Select JRE System Library and =
click=20
Next.<BR>> Select Alternate JRE and select the appropriate 1.4 entry =
from the=20
drop <BR>> down box.<BR>> <BR>> Your project will now compile =
against=20
1.4 classes no matter what you pick <BR>> for the default =
JRE.<BR>>=20
</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>yes - after this event, the jre version =
will stick=20
to 1.4.2, otherwise it will follo the eclipse jre..</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>you can't tell the difference on the =
build path=20
view though...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks! :)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>/aksel</FONT></DIV></BODY></HTML>
------=_NextPart_001_0011_01C59E6C.B5B85420--
Content-Type: image/jpeg;
name="jre.jpg"
Content-ID: <000b01c59e5b$f22c76e0$e6f014ac@terma.com>
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAYEBQYFBAYGBQYHBwYIChAKCgkJ ChQODwwQFxQYGBcU
FhYaHSUfGhsjHBYWICwgIyYnKSopGR8tMC0oMCUoKSj/2wBDAQcHBwoIChMK ChMoGhYaKCgoKCgo
KCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCgoKCj/ wAARCABZASwDASIA
AhEBAxEB/8QAHAAAAgMBAQEBAAAAAAAAAAAAAAUEBgcDAQII/8QATRAAAQMD AgMCCgYEDAMJAAAA
AQIDBAUREgAGEyExFCIHFRYyM0FRVZHRI1NhlLHTNHFy0kJSVGKBkpOhorPh 8DZDcwgXJCV0pLLC
8f/EABkBAQEAAwEAAAAAAAAAAAAAAAABAgMEBf/EADARAAIBAgMGBQMEAwAA AAAAAAABEQIDBBMU
EiExUYHwBRVBkaEiYdEyQlLxcbHh/9oADAMBAAIRAxEAPwD9IEkRk2/jn8Br nkfaddD+ip/bP4DV
O8KrJV4PdwSW5EyNIhQJEth2JKdjrS4hpZSSW1JKgDzxNwbC45a5vUzLbkfa dGR9p1k/lWr/ALye
28as+LvGPiDDscnsHCwtxssOHxu2/QZ5Wx5W/h6i+DKpVZNMp78eLWXpi9uC a5Gq1S4vjWQUtltc
da3HA2kHiBfmY8dkqTzTZANiyPtOjI+06qW3dyHydq9Q3BMbC6UtztwRTnYp i4NJcUhSC45mQlWW
aFKSoEY36msxd3budrMagS4sOnVR+SyBIlwgUcFxiY5yZalL5hUO2RdHnnuD EFSAankfadGR9p1j
u7dyVncGyd4QmV06L4tpEzty1xlu9qs5MjnhAOJ4N+yKV3uJbiAc8CVX/cFQ qfjym0ajOw40iVGk
S1SZcdUhAS0plBQEJWg3JfByy5YEWOVwgFjyPtOjI+06x3ytqW36BUV0SJ27 xbMq1QqLHAScWO3y
sPpFPN4ZcJ4XSh4jG5T0C7FL3LuVuq1WE3T2+3hDi6dTTGut5lLzbZkiSXg0 sBK8yweEvmEkgWWp
ANAyPtOjI+06zrcVRfrfgyadZnR5D8qoxYTjxp7sdpV6g2y425GcXnjbJC0K UMhkOQOuqK5U6W4t
llFKRS6RPg0R2KzEU2XVPJjDiNK4hS0hPaU2bKV8myMxldKAaBkfadGR9p1h 9CqFTqXg6220y7DY
pdLk7eiOsrjqW8+omA9mlzMJQPpkjEoV5hN+93WcHwg7qfpcSe5RYbSKoiI/ ARJcbZGL0mO1hdDz
q3BjIH0vDbxKUkoOYSLsg13I+06Mj7Tqmt1qsx94Q6ZVzHjQ3rMx3UwVrFRd DBccUhxLpEexCvo3
UkkIJStVzhzqO5amxV57jIhil0+qQ6S7HW0ovPKkdn+lS7mEoCe1J7hQq/DP eGXdkAu2R9p0XPtO
qJsTclZqXk/47XTnvHdINVa7HGWx2fHgXbVk4viX7QLKGNsDyOXdrqFbgmOU JxNVhlat2VJuEqTE
ceLCUJqSSlw8YcQYpASE4YgAd62kA1zRrKJXhA3IpchFNpMeR4qZddqDv0aG neHJksE5uyG+zpPZ
Fqys9iF8wcLrsW6Gqm74QtvJo0uHEkeK6gVLlxVSEFPFhXASlxsg3tzueh5c 7hALro1ndF35Nq22
XKuiJHYyqNKjNtEqXi1LRCUu5uMlJ7UsA2A7qbjreu+DWu1eorVEpjkOJNqa Gqk5IltOy0JCKbTA
UBJdStRJkA5qcJ7hvkVXDZEmzaNZtt6oVOJ4OfBpEozsNiRUo0WKp6XHU+hC RAceJCErQSSWgPO9
Z1GrPhArEajPS6fCbmSKQiU7VmW44wLbL7zKVpWt9BaDhjPEBKXyn1g2GaBJ qWjWRoVuCY5QnE1W
GVq3ZUm4SpMRx4sJQmpJKXDxhxBikBIThiAB3rauu2a3Nqi4YkLpyLdvYfbS VJdddjSUsB1pBJs2
bLKgSopK2xkeZJoFn0AkdNGjUB7kfadGR9p15o0B7kfadGR9p15o0B7kfadG R9p15o0B7kfadGR9
p15o0B7kfadGR9p15o0B1P6Kn9s/gNK6hR6ZUpMOTUadDlyIa+JGdfYS4thV wckEi6TdKTcW6D2a
aH9FT+2fwGq1X4TFR3Ft2HLC1R3nXwtKHFIKgGVKHNJB6gHr6tWJYG3i+F2f gdkj8Djdo4fCTjxe
JxM7WtlxO/frlz689cnqPTHoDEF6nQ3ITCC21HWwkttpwLeKU2sBgpSLD+Co jodRZe1ttIcWy3Fq
BdbWgL4b0tQHRRFxkPNPT7eo6iTE2ftmWlZZiy+4rBQXJkoINgeilA9CPjrP LfMknsalRYNINOo7
TdLjhC0tCE0hAYKrnJCcSi9yTzSRfqDqu7S2BTNszVSYjvFv3g2qBCYCVgFI cBYYbVkErcSOdrOK
Fueme4tqUanxmDDhPOPOuhAR2t9aiLHmlPFTfna/MWFz6tLYG3IvjeLGqNLd ZYey76pLqOYHIAiQ
vmTblbmL+zWqpumpUQ3PrG4ySTUyOKltfb9UbabqdDpUxDS3HG0yIjbgQpxW TigCDYqVzJ9Z5nUm
sUemVuMmNWadDqEdKw4lqWwl1AUAQFAKBF7Ei/2nXfyE2/8AySR99f8A39cV bM24mU3HMObxHEKc
BEmSUAJKQbryxB7wsCQTzIBxNtuWzGSLUtr7fqjbTdTodKmIaW442mREbcCF OKycUAQbFSuZPrPM
6FbX2+tuoNqodKUiorDk1JiNkSlBRUFOC3fIUSbqvzN9L1xNiorr1IW3UUy2 XkRnXCZwjodWlCkN
qf8ARBSg43ZJVclaUjmQNRFubAR29SmK0I8DtPaZXZ6l2dHZ8+N9NbhnEtrH JRuRYXJA0y2JLSmn
wkwmIaYkcQ2OHwWA0nht8Mgt4ptYYlKSLdCBbprk9R6Y9V2Kq9ToblUYQW2p i2El5tPPupXbIDvK
5A/wj7dK6/S9mUGVEiz4tWXJlIccaahpny1qQ2UBaiGciAC4gXNvOGh6m7IY qdCp0hM1mdXEOOQG
HXZiFuBtAWvIE/RkJIJC8T6rX5aZbEktza+33ZMGS5Q6UuRBQhuI6qI2Vx0o N0JbNrpCTzAFrerX
SPt+jRnpbsekU5p2W8iRIWiMhJedQvNK1kDvKC+8CeYPPrpLNRsKG5OD7VWL MFDzkiU23UHIzYaS
pTv06QWyU4KBAVfIFNsuWmFCoW063x+xU+tNcHHLtrc+Je97Y8bHLob43tyv a40y2JJ7NHpjNXfq
rNOht1R9AbdmIYSHnE8u6pdsiO6nkT/BHs0PUemPVdiqvU6G5VGEFtqYthJe bTz7qV2yA7yuQP8A
CPt1A8S7L8XdvtI7J23xfn2mV6ftHZsLZX9L3b9PXe3PRtuibP3JAcmUqNUV R23lx1GQqZHUHEHF
YxdKSbKukm1rgjqCAy2JGkenwo3ZuzxI7XZWTHY4bSU8Fo43Qiw7qe4jkOXd T7Brkmj0xNRcqCad
DE9xaXFyQwniqUlCkJUVWuSELUkG/IKI6E6V0Sm7IrcpcenJmrcCC62XHZjS JDYIBcZWshLzfeT3
2ypPfQb95N+TUfweu0iDVGpYXT500U+I+mdIKZD5dLQQ33+9daVcxcWBVfEX 0y2JGkjb9GkvRHZF
IpzrsR5ciOtcZCiy6tealoJHdUV94kcyefXRWtv0au8Hx3SKdUuDlwu2RkPc O9r45A2vYXt7BqBJ
puyI1ZFLeTNEnNDSlh2YphtxdsG3HgeGhxWSLIUoKOaLA5puCnbEVFqslt1x 1mlyuxSlNTJK8ZFk
fQpAUSty7iEhKbkqOAGXLTLYknztv0aoVOPUp9Ip0qox8eDKejIW61irJOKy LixJIseRN9c5O19v
yYAgyaHSnoQWhwR3IjamwpKA2lWJFrhACAfUkAdNFE25tKtRVyIDE0pQstuN vPymHWl2BxW24pK0
GxSoBQF0qSRyIJiSabsiNWRS3kzRJzQ0pYdmKYbcXbBtx4HhocVkiyFKCjmi wOabstiTtWtp0asx
KVDnwI7lOprweZhFlBYNmltJSWyCMQHCQBaxSn2W11qG19v1KNDjVGh0qXHh o4cZp+I24hhNgMUA
iyRZKRYW6D2aSLe8HiIzz6jUeEjAtqAnntKVuIbSqP8AyhJW42Mmsx9Ig3sp JPVTWx0xW31Qq+FO
LUhEcxKn2hWISVLDGPELYzQC5jiCoC9yBplsSP00emJqLlQTToYnuLS4uSGE 8VSkoUhKiq1yQhak
g35BRHQnXVinwmHkusRI7bqOLitDSQRxFhbliB/CWApXtIBNzpCmLsFc+PFZ ckPcfhhEll+W5GCn
AC2lUhJLSVLCkFKVKBVxG7A5pv1olN2RW5S49OTNW4EF1suOzGkSGwQC4ytZ CXm+8nvtlSe+g37y
bstiSx6NQU7M24qU5HEObxG0JcJMmSEEKKgLLyxJ7puASRyJAyF+3kJt/wDk kj76/wDv6ZbEkjRq
P5Cbf/kkj76/+/pT4l2X4u7faR2Ttvi/PtMr0/aOzYWyv6Xu36eu9uemWxI+ 0aTv7a2wzX4VIVCm
mTKivy0KEx7AIaWylQJ4l7kvoty9R6crsPITb/8AJJH31/8Af0y2JJGjUfyE 2/8AySR99f8A39LI
O29sz5FZjx4U1LtMkCK6VzHrKWWGngU/Scxi8kc7cweXrLLYkd6NVmobeoMX jLMcttNFWSnJkiyQ
m9yTxBy5a4sUKjKcWHIa8A2tV0y5AIskn1uH2a3aO5G0YZtMwWzRrulKUSmU ISEoTgAkCwAsOWvl
T7oJ+kV8dc0GwD+ip/bP4DSKd/xhtf8A60j/ACF6en9FT+2fwGkU7/jDa/8A 1pH+QvVX6kGRd+US
bWkORodUqdNUipxJZEeKHG3UNuRllRUWXO8nhKKQCAVWC7p5as9CZdwkFUmY uzqBxX2ktrfs20Ct
QwSASUqBxCRzNgOVu8+cwVLYCXnHGnEFYRHWsAgpV1CFC9rH4cx1EuJLalpW WSvuKwUFtqQQbA9F
AHoR8dbzExbwn13ctO3etijVESGmGk45REFUdakJyTckBRNgu9rDO3q012tW nqimJCd4inxLZkIK
yVEJ4qeICbC9uYJ9ZKvZq61dOzVVJ/xwNvGoDEO9q4PF80Wyy5+ba1/VbXKD L29Dq8FqkwKclqQg
8KZEbQEXyKSkKSLHvAg8+pHt1zYh3qK6L11pU0uFu47W6H8depnZpstV0UNu pqWm1Cj1Xr/wl76p
8qpbfDcBrjSGJsOaGgoJU6liU08pCSSBkpLZCciBci5AuRSqPt6v1HfdTrL0 WpbdjzO18N7iRHJD
WTVLQnu3db7xiPjobAeolOuvhp3JW6HKoEWgVFEFc3tAWVJZORAbSk3dviEl y98bXAyIHJVNf3D4
SQHP/NmkFSihtKFQipxSkZgNCxLhxeaIxyvigcyVBXp2sJcu07VMR/lI5a79 Ftw/9FzXs+uN1asz
3Js6oQ01aLO8WOGMgVNLEWMA7mlCVNvB5kKAyQ2otBJSlKysKXNuVdO3d7Up rbm4FVGqorLbMldV
aVAUH3X3GcWTJsgqCmxcNAgqNyAVHVYVvDf66aJ/j2OzHebcdbC1QkLKQXU3 S2oZGx5DkblpPW6s
viFvXftRZcej1xplkqUhK3xDYTlZRsguJGRTmjpe2Ld/OOe7y2/x3e6Nestf f2ZoG6I1Sr1fodVk
bS3SiNFizYzjEOqMRJCVuLiqQsralpBbIbcFszzSCU+adRN0bc3lW5W4q1T+ wwXCinrgUyXFDrsg
wyJbaVOokhCCqQ460rkRigEHnkc6c8Ju8lZ41xaMsrYxWO7fO1rt+rNNr39G m97qy7Hwh74dhSJb
dZWmOhwNKWmNH7ilh0pABRc8gbdfRJv1Vlk/CsSuK+UTXWefwX/e23qvVI+4 Ym2aFV6cqVFntSDI
ntdjnByO8lIZYD6ktuLfU04VltskBwqUCpSVWWhU6ZKpT8GIjd218HkvCRNn R57z10kFCVOuSbJF
kkju87W6q1irnhN3krPGuLRllbGKx3b52tdv1Zpte/o03vdWQ54Td5Kzxri0 ZZWxisd2+drXb9Wa
bXv6NN73VlfKcT/H5RNdZ5mq+KKz2Hyc8TycPKDxr404zHZeF4y7bjbicbLD uW4ds/Xj39MNj0qs
LpKDOXV9vOM1afLVDvDcEpp6Ut9AWQHbDFeJxUhV8/5qtZJJ39vpuQphytcB xbPHSCzGACFNqcSQ
Si18VosDckoQLElQUVjwgb2p9TnQXq9Z6O84wotRmCkKCnB3bt9BkLX+rTfq rLFeF4h7kl7outtc
/gvdK2TUqrTKDRawxOpMai0I0Z+W26wvti84huyn6QKZUIiwpLyE5JcCSg3U E9fJ6v0nwf8AYOy1
KtzzubxhhxIiFpYTU+053u2jvoRlbrm7ayUiyM1c8Ju8lZ41xaMsrYxWO7fO 1rt+rNNr39Gm97qy
HPCbvJWeNcWjLK2MVju3zta7fqzTa9/Rpve6ssvKcT/H5RNdZ5mtVah1dys1 aEzTnXI1TrtPrCZ4
daDDDcfsmbbgKg5xD2RdsUKT30XUO9jylUiszmd8NeJ5LCZVaiTo5ceYylsN IiocDKkuEtukRnCh
Si2UlbagpCgSjOqXvnedUM0+U7UFmOyX3HXorZShJXgLBLKiSC8i3I+jTf8A hZcZW/d+NQGJrlWe
Ziy1OpYc7LHsopyyxujmE8RAueV20jn38sfLMRMR8oy1tqJk1bbVRpuzoc1W 550bb7VSmqfhR6zU
WjKLaWWUK4rqnFcVWaVEHiLIQptNwAEJXmLJrcqo+JG2qlSaxXYFYZq8WUy5 EbbjGIHG1ELzLl4b
gGCFJutF1DvY5zD37vypLkpg1Z5ZaZdkOYRY9mm0hZKrlHIDJNr9ShA5kqyI W/t9VJ5xqJWsTipa
lKZjNoaSSoAla0BKQCtAGR5lCBzJVkfheIXFL3RNbafr8FwpWy6j2KOxUaDO eTBp6WJaFVThiXIQ
9GcSunFDhMZsFhxQbHZ0klhJCQm7bZNBrgpwmxGdwRKiiU4xS0GfGekw4jrb RcRJdfLyVNl9nMqT
xnEpKAkWCmxmtQ8Ie+Ikl5h+srZdF+SY0dQAUFlJScCFCy0FJ5ghCDzBVlNX u/wiORkvNVNZ41sG
mmYq3khZUEHhYFYBLjeJULHFvrkcz8MxC3tL3RdZaf8ATNCo1MqtMk0Pb9Qo dSqNDojMOLElR1xU
x33G22x2p5C3w53FA4thKgkoz76uHw5dAlV9zxlV6rtGpDcIhOKjtyJUQR0W sUw2VoeWU5KCcnVJ
GZTkrEJbbRnkbc2/JNTYhObmiRFTFFuO6G477SnCogNhbTawFDioNldAhBV5 xz0TwM7hqW5NuT5V
YlplSGp7jSVBDaChGDawkhB9WZtcJNrXB85XPewtywlVXw/v8M2271FxxT33 Ij3dRHapu7djdLpj
UyJJi0tuqJjx4zjzq0GWrFIkAsKeSFQ1EO9GiCOZb118FWzqhTqwqo7ggyUK jQkx4Ha3mlKZSJk8
pHDZUWkqTHeZSCgAJStSEWSVJ1qujXObRezAkt1l+aurTnYziAhMBaGeA0e7 3kkNhy/I+csjvHl0
tnXkBI8U9o4dS8a+U3jDgeNnuz8Dxvx8+DxeD6Hv2xvf1Z61XRoCgVaL4rjb cnrp/i+PC3M867HD
/GU52tyTGQ6k9O+5LbdKSRglSgLlISa/RtgV2LGobD8m7TL0OBITw2+5Ep7j bkV3krnmth04jvJ8
YWUVBgA6/o0BiDew6u/ApsQUR2A+wiGzWpbUlpldYfRNhuLlpcac4iilDMpY ccwdHG7oyUoCz03a
s2j7tqtTYp7TlJ7chMOCgoQmM0YUZjtLKQQkFODjakq7wbCuHjdSHtI18P8A oXP2T+GgMw3bSHq5
VQxIl4Udt5xUiOgELeUF90FV/N+zl09ZIKeW16dKpEeZDemdqioaeEXId9Df CV3VH126Dl6vtAFt
qDaBIcKXXOSiOaWSeXLqpok/0k6jw1tB9QcU4UcNZPJoAgJJscW0m3L2/wB2 vU2nsNx6HI19XEeH
9Nb/AFo/Aa4K84/r10kOpYe4zmWDaUrVikqNgAeQFyT9g56rZ3O0ST4qrf3B z5a8JncWQ/oqf2z+
A0inf8YbX/60j/IXp6f0VP7Z/AaQVJWG7dsK5cnZBNzb/kL1V+pB8CPvyiTa 0hyNDqlTpqkVOJLI
jxQ426htyMsqKiy53k8JRSAQCqwXdPLVnoTLuEgqkzF2dQOK+0ltb9m2gVqG CQCSlQOISOZsBytJ
XVWEGylAH9lf7uvWKmy+opaUlSha4OQ6kD1j2ka6cupKWjXtLmYZ4WYdPmb4 lcXxWh9hlll1cpHf
eVhlxDjjzstKfX5gtbpqJtt5yKytqLNjuIhoS8wlh1QbjDiAEhBJHeccbUen mHkb63xdWjoWUqWL
j2BZ/wDrrzxxG/jj+qv93XFicBiMTTVRVW9l/bhy9jdZrwlm4r1Nv6167T67 uG8yTw4vs1YbOcMp
uEzLYkPhT5UQkFLJF0oJJ62uEKsT5yb96tP7npbCKYENIkvRHrJkhLgWwpEa M0h5tJKUqGbSlBKx
zCQCEX1su5IG3tyKjGtMKkiMSW08V9CQSpKjcJsDzQnrflkOilAom9h7DRhj TFHHG2UqUemFr3PP
0ab363Vfz1X9/CYh2baorobjpx6HnX7OZXtU1JGT1CRFe2zChM1ek/8AhY7j a0LhrLzig+6scNws
3AUFJsMk9TcC51F2xKjsMgVKfB8XB7J6C/HU664iwz4SuGQ2pQGNwtBukXIs CNib2HsNGGNMUccb
ZSpR6YWvc8/RpvfrdV/PVcRsTYbeFqYo442ylSj0wte55+jTe/W6r+eq/X5j 9Lpy3v397jRo3Ke0
u+plQqaY1OpMh5qOJs1LLTq5IK2nIrDtklaEg91RbQggDK0YnnxDqVV9wNSI VTjRa7LEiQ2yp11y
Q+406EB/NhtSk8TA8VFkuC1wq6jyKtKb2JsNGGNMUccbZSpR6YWvc8/Rpvfr dV/PVf1vYexEYY0t
RxxtlKlHpha9zz9Gm9+t1X89V8dem5dt99C6V8Ntd9SiT93Q1SS9GlR2W0pk qhBhMkuxAqO6hCLr
Vi0cltjFoY3Te4CE3r+4qzHqNKdaMpb7yVQlshYUcVdnV2kgkcip0pKv4yu9 z661tGw9iN4Wpau5
jbKVKPTC17nn6NN79bqv56rjew9howxpijjjbKVKPTC17nn6NN79bqv56rqM dTQ01bffQVYWqpQ6
131Mqcl05NQaqKanHWF0rsZYS27xEOdgLPO6MbZgC4UeoPS5DqobniCrVOU7 WUVMPPSXYObbrqYq
FMSEhspdQAApTjIxSCk4d7kBe9o2JsNvC1MUccbZSpR6YWvc8/RpvfrdV/PV fxvYmw0YY0xRxxtl
KlHpha9zz9Gm9+t1X89V5VjVVxt1cI73FWGa4VLn3vMyotahp2/NZmzkLVJZ krktS1yVuOyVIVw1
oSm7RF+EcnO8FBRvySdfb9YZrG4dxuzR2yhpcVMSkXaAS28eHYABQz4qmz7C +XFAlJOtLb2HsRGG
NLUccbZSpR6YWvc8/RpvfrdV/PVcRsPYjeFqWruY2ylSj0wte55+jTe/W6r+ eq9eOUurLe/vduJp
XCW0u+pkFBE+uHdK0NPTKhKh8VSWW8lLUZbClEJSP1nkNQpbkU7QpzKJjK5b cyQ6uOEryQlaWkgk
lOP/ACj0J85P222xvYew0YY0xRxxtlKlHpha9zz9Gm9+t1X89VxGxNht4Wpi jjjbKVKPTC17nn6N
N79bqv56r7F4m05y3xn4jkYvBbo2l25MnoFchUd+dT1NRJtPHay3KcQ8hTxL C22wUpWOSr2AUCU8
RdiLk6V0aLSVPsrnVBlI7OXS2826EcUOFIaUpAUq2NlkpHMd26T3htbexNho wxpijjjbKVKPTC17
nn6NN79bqv56r+t7C2IjDGlqOONspUo9MLXuefo03v1uq/nqvPMolq3Up75D R8JqW7vmYvJpFYq8
x+TBYkVhsKCDJhRXC1cJFkJGCcQkWATYAACwtbTObKgoROMuStp6TBi012IG F9ojrZLAWpSVBKLf
QKsAu/eTcDnjqqNh7EbwtS1dzG2UqUemFr3PP0ab363Vfz1XG9h7DRhjTFHH G2UqUemFr3PP0ab3
63Vfz1Xj8Sbibb3d8vsNEl+5bzN9vpMzcG1YUBaKk9BnJfedgR1oaQzmyAVJ KE94YqKllPMFF1G1
hoP/AGeF5bPqQzyxqSxbK+P0LRtbJVut7WR1vjzyV18hdiMt5ppSlBpIUQZk nzU4Ek5K52DYJ6k9
/rmrK27bpNO23AVCo0RbEYqCyhchx3nilN7rJI5JF/abk8ySeHG4vOpVGzG+ d/X8nVh7GXU6pntf
gf6NRu1K+r/xf6aO1K+r/wAX+mvOlHUSdGo3alfV/wCL/TR2pX1f+L/TSUCT o1G7Ur6v/F/poEk+
tAAAuSVdP7tJBJ18P+hc/ZP4ahLqrCDZSgD+yv8Ad18ipsPtupbUkkJ5jvA8 zb1ges6zdFSUtE2l
zM+3mauxUDUqO6p9MZx1L1PNrPIKuZSbXzFuXX7PWFc9rsVNmPMerMniS5LT zhZTbBgcJVkJ+Avz
t/eTapENx15a09k7xuStpZJPtNnAL/qA14xAUhZ4nZShSSlXDaWFEEWIupag Ljl06ezXZq7WxEnP
lVzI2dTnJSm9sgkX/oGvChoH0iv6n+uvs/prf60fgNcFecf168hnYdD+ip/b P4DVar5x3BQT7DKP
/t16sp/RU/tn8BpNUqa/Nq9Lfa4XBil4uhxeOQW2UAD7e919Vv1A5UOK02R8 GUTe0yQvcFNj1R5y
HQFLSoPsKI4jw5pS4rkUAEXFvZe/K6LvSlkSDz55Nf5zeujtIdcSErjR1oBC gFTh1BuD6LqCAf6N
SafTltPZOtsoF0kkSw4TioKA8xNuaRz59Ptvr2K79vYaTONUVbRAU55pv6h+ GvOL9upzlK76uG2g
o9V5gHL+ofx18+KlfVN/fR+XqrE2hl1kPiD2/wB+jiD/AGdTPFSvqm/vo/L0 eKlfVN/fR+XpqbXM
ZdZD4g/2dGYPr1M8VK+qb++j8vR4pV9U399H5emptcxl1kTIe3XnE+3UzxSr 6tv76Py9HipX1Tf3
0fl6uptcyZdZD4n266R1o47eZGOQvc8rX1I8VK+qb++j8vR4qV9U399H5eo8 TafqXLrFYmFTCPpE
FRSi9gL3Ij3/APkv4nUnIe3UvxSr6pv76Py9HilX1bf30fl6uptehMush8T7 dHE+3UzxUr6pv76P
y9HipX1Tf30fl6am1zLl1kPiD/Z0Zg+vUzxUr6pv76Py9HilX1Tf30fl6mpt cyZdZEyHt15xft1M
8Uq+rb++j8vR4qV9U399H5erqbXMZdZD4n26OIP9nUzxUr6pv76Py9HipX1T f30fl6mptcy5dYvl
KvDl/wDpn/8AKXq6cMarqKTkHELQ2lK0KbKu1BZAUCDYYDnYn1/HVh7T/Nb/ ALQa5MTdora2Tbap
amT3hjRwxrztP81v+0GjtP8ANb/tBrllG494Y0cMa87T/Nb/ALQaO0/zW/7Q aSge8Ma4zU4QZKvY
0s/4Trr2n+a3/aDXKU6XozrWLRzSUkF0C4PUfZ+vVpqSaI04Ms8JEltunxH2 5kliqNvBUFDBKlOu
dMcOihY2JPS9ud8VP6A9LXBSuoNtszFIa4qG1ZJSS63cX/8A39Z66YuUh1ak FUaOotnJBVOF0mxF
x9FyNiR/Sdd4dMWhS+IhlsKx5iUHDyUFAWwTbmBz59Ptvr0rl+3sNJnLTRVt Im6NdeCr+M3/AFxo
4Kv4zf8AXGvFhnafZ/TW/wBaPwGuCvOP69fUzJSlBp0trxADiLEpNuouCLj7 QRqu+Trvv+t/2zf7
mqwMarXqXSkNM1Ccww6slYQpXex5C9vZ1+B9ml3ljt/3rH+J+Wn+jUAg8sdv +9Y/xPy0eWO3/esf
4n5af6NAIPLHb/vWP8T8tHljt/3rH+J+Wn+jQCDyx2/71j/E/LR5Y7f96x/i flp/o0Ag8sdv+9Y/
xPy0eWO3/esf4n5af6NAIPLHb/vWP8T8tHljt/3rH+J+Wn+jQCDyx2/71j/E /LR5Y7f96x/iflp/
o0Ag8sdv+9Y/xPy0eWO3/esf4n5af6NAIPLHb/vWP8T8tHljt/3rH+J+Wn+j QCDyx2/71j/E/LR5
Y7f96x/iflp/o0Ag8sdv+9Y/xPy0eWO3/esf4n5af6NAIPLHb/vWP8T8tHlj t/3rH+J+Wn+jQCDy
x2/71j/E/LR5Y7f96x/iflp/o0Ag8sdv+9Y/xPy0eWO3/esf4n5af6NAIPLH b/vWP8T8tHljt/3r
H+J+Wn+jQCDyx2/71j/E/LR5Y7f96x/iflp/o0Ag8sdv+9Y/xPy0eWO3/esf 4n5af6NAIPLHb/vW
P8T8tHljt/3rH+J+Wn+jQCDyx2/71j/E/LR5Y7f96x/iflp/o0B//9k=
------=_NextPart_000_0010_01C59E6C.B5B85420--
FUDForum. Page generated in 0.25261 seconds
