Re: Docx4Support NoClassDefFoundError [message #1625765 is a reply to message #1383991] |
Fri, 20 February 2015 16:26 |
Anyone get any resolutions to the docx issues. Currently experiencing some issues as well. I don't believe it is the same issue but can't get docs4j to load data into the template file. I am using
DocxAdapter object to call docxFile.fillTable(tableBookmark, startRow, startCol, data) method. And the template file has a bookmark on the table.
!ENTRY org.eclipse.scout.rt.client 4 0 2015-02-20 11:22:27.778
!MESSAGE org.eclipse.scout.rt.client.services.common.exceptionhandler.internal.InternalClientExceptionHandlerService.differentiatedLog(InternalClientExceptionHandlerService.java:116) ProcessingException: ProcessingStatus[ERROR code=0 Table is not set ]
Table is not set
!STACK 0
at org.eclipse.scout.docx4j.DocxAdapter.fillTable(DocxAdapter.java:591)
at org.eclipse.scout.docx4j.DocxAdapter.fillTable(DocxAdapter.java:572)
at fabricator.client.core.ui.desktop.Desktop.runReport(Desktop.java:216)
at fabricator.client.core.ui.desktop.Desktop.access$0(Desktop.java:201)
at fabricator.client.core.ui.desktop.Desktop$ReportsMenu$BillOfLadingMenu.execAction(Desktop.java:194)
at org.eclipse.scout.rt.client.ui.action.AbstractAction.doActionInternal(AbstractAction.java:271)
at org.eclipse.scout.rt.client.ui.action.AbstractAction.doAction(AbstractAction.java:253)
at org.eclipse.scout.rt.client.ui.action.AbstractAction$P_UIFacade.fireActionFromUI(AbstractAction.java:604)
at org.eclipse.scout.rt.ui.swing.action.SwingScoutAction$1.run(SwingScoutAction.java:148)
at org.eclipse.scout.rt.ui.swing.concurrency.SwingScoutSynchronizer$1.runVoid(SwingScoutSynchronizer.java:71)
at org.eclipse.scout.rt.client.ClientJob.runStatus(ClientJob.java:189)
at org.eclipse.scout.rt.client.ClientJob.runTransactionWrapper(ClientJob.java:172)
at org.eclipse.scout.rt.client.ClientJob.run(ClientJob.java:159)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
[Updated on: Fri, 20 February 2015 16:26] Report message to a moderator
Re: Docx4Support NoClassDefFoundError [message #1742591 is a reply to message #1630527] |
Mon, 05 September 2016 19:44 |
Samuel Messages: 22 Registered: January 2012 |
The message "table is not set" is from docx4j.
If you are using the method "fillTable" to export data to a table, you must indicate a text mark that identifies the table as the first argument of the method. If there is no text mark in your word template, docx4j complains with this error message.
[Updated on: Mon, 05 September 2016 19:45] Report message to a moderator
FUDForum. Page generated in 0.04024 seconds
