Home » Archived » Lua Development Tools » [LDT 1.0] load a module written in Java
[LDT 1.0] load a module written in Java [message #1273956] Thu, 20 March 2014 16:03 Go to next message
I met a problem when I tried to load a module written in Java.
Such as:
require 'Hyperbolic'
I followed the instruction from LuaJ, adding Hyperbolic to classpath. And I can do it in command line, like:
java -cp someDirectory lua HyperbolicApp.lua
However I don't know how to do it in LDT. There is no "ClassPath" in the "Run Configuration".
Please help me.
Re: [LDT 1.0] load a module written in Java [message #1277849 is a reply to message #1273956] Wed, 26 March 2014 10:49 Go to previous message
To use LuaJ as interpreter you should create a new "Lua Generic".(Windows/Preferences/Lua/Interpreter)
as interpreter executable, your "java" executable.
as interpreter arguments, this big line Smile :
-cp "/home/sbernard/Dev/juaj/luaj-3.0-beta2/lib/luaj-jse-3.0-beta2.jar" lua -e "local system = luajava.bindClass('java.lang.System'); local luapath = system:getenv('LUA_PATH'); if luapath then package.path=luapath end;"
Explication :
==> to add the luaJ jar to the classpath
lua
==> to use the lua script engine registered by luaj
==> This lines of code is to workarround the fact that luaJ does not implement os.getenv correctly, it use System.getProperties instead of System.getenv. It's look like a bug.
With this you should run your lua script with luaj interpreter but not debug it :/.
I you want to debug, it should be possible but you need to write some code.
(I never test this so maybe, this will not works)
you should hack luaJ(I mean modify the code):
  • fix the getenv function in OsLib.java
  • the _VERSION global var should return "Lua 5.1" or "Lua 5.2" (see public static final String _VERSION = "Luaj 0.0" in Lua.java;
  • you could fix the DEFAULT_LUA_PATH in PackageLib to use getenv instead too
Then you should implement your own transport interface based on your luasocket for our debugger (see the interface and the transport parameter)
Previous Topic:Is somebody home??
Next Topic:Parsing files not commented in luadocs
Current Time: Tue Nov 04 17:03:20 EST 2025
Powered by FUDForum. Page generated in 0.02666 seconds
