Home » Modeling » TMF (Xtext) » Annotation values generation 2.4 vs 2.5(I can't generate annotations values after switching to Xtext 2.5 because annotation values are implemented using UnmodifiableEList)
Annotation values generation 2.4 vs 2.5 [message #1273760] Thu, 20 March 2014 13:55 Go to next message
boris michalko is currently offline boris michalkoFriend
I'm trying to add annotation with values to method in my inferrer. It is working fine under 2.4 but under 2.5 I'm getting this error :
1024 [Worker-6] ERROR org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder  - Error initializing JvmElement
java.lang.UnsupportedOperationException
	at org.eclipse.emf.common.util.ECollections$UnmodifiableEList.add(ECollections.java:354)
Problems come from this piece of code:
anno.values+=annoValue
It look like annotation values are implemented using UnmodifiableEList
How should I generate annotations values under Xtext 2.5?
In my example is based on example in documentation http://www.eclipse.org/Xtext/documentation.html#JvmDomainmodel. In toMethod function I just added code to generate annotation and annotation values.
val anno = feature.toAnnotation(typeof(javax.xml.bind.annotation.XmlElement))
val annoValue = TypesFactory::eINSTANCE.createJvmTypeAnnotationValue
annoValue.operation = anno.annotation.getDeclaredOperations().filter(o|o.simpleName == "type").head
val jvmType = typeReferences.getTypeForName(java.lang.String, feature).type as JvmGenericTypeImplCustom
val literal = typeReferences.createTypeRef(jvmType)
annoValue.values += literal
annotations+=anno
Re: Annotation values generation 2.4 vs 2.5 [message #1273923 is a reply to message #1273760] Thu, 20 March 2014 18:51 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
hi,
the editable collection has changed its name
http://www.eclipse.org/forums/index.php/mv/msg/666933/1265742/#msg_1265742
Twitter : @chrdietrich
Re: Annotation values generation 2.4 vs 2.5 [message #1274334 is a reply to message #1273923] Fri, 21 March 2014 10:09 Go to previous message
Thank you, it works now.
Previous Topic:mwe2 fragment documentation
Next Topic:formatting generated java-files after build
Current Time: Fri Apr 26 00:17:17 GMT 2024
Powered by FUDForum. Page generated in 0.03027 seconds
