[EMF] How to get the extension for an EObject/EClass [message #1272585] |
Tue, 18 March 2014 05:00  |
I am extending the backend of NetXStudio to be able to deal
with a regular XML store. I need to auto-generate the URI's of the
resource files based on the EClass.
So a file URI is produces with "file://path/package_name.extension"
For the extension, I can retrieve the registered extension parts, and
get a map with this.
Registry instance = Resource.Factory.Registry.INSTANCE;
Map<String, Object> extensionToFactoryMap = instance
.getExtensionToFactoryMap();
But how do I know which EClass belongs to this EResourceFactory?
Is there a link between the EPackage of the EClass and the corresponding
EResourceFactory?
Thanks!
Christophe
Re: [EMF] How to get the extension for an EObject/EClass [message #1272698 is a reply to message #1272585] |
Tue, 18 March 2014 10:31   |
Christophe,
Comments below.
On 18/03/2014 2:00 AM, Christophe Bouhier wrote:
No, there isn't really such a general mapping.
> corresponding EResourceFactory?
You could generally use "xmi" for any EObject. Even for something like
the Ecore model, tools would generally expect an EPackage to be at the
root of a *.ecore resource but anything else from an Ecore model would
be expected to be nested below an EPackage...
For a generated package, you could use
getEPackageNsURIToGenModelLocationMap to locate the GenModel containing
a GenPackage for the EPackage's nsURI, and from that you can look at
things like
org.eclipse.emf.codegen.ecore.genmodel.GenPackage.getFileExtensions()
and
org.eclipse.emf.codegen.ecore.genmodel.GenPackage.getContentTypeIdentifier().
> Thanks!
> Christophe
Re: [EMF] How to get the extension for an EObject/EClass [message #1272713 is a reply to message #1272698] |
Tue, 18 March 2014 11:12  |
On 18-03-14 15:31, Ed Merks wrote:
> Christophe,
> Comments below.
Thanks, it's harder than I expected...
> things like
> and
>> Thanks!
>> Christophe
FUDForum. Page generated in 0.06616 seconds
