| Tomcat Silent Deploy [message #211178] | Thu, 27 March 2008 04:12  |  |
| Eclipse User  |  |  |  |  | Hi,
 I used to change my non-Java files (.jsp, .js, .css) and it was silently
 deployed to tomcat working directory (when tomcat was running) without any
 need to restart. But it's some time that when I change even a single .js
 file, the whole application is restarted and causes problems.
 What should I do to have Eclipse copy non-Java files silently to tomcat
 working directory?
 Mohsen.
| Re: Tomcat Silent Deploy [message #211201 is a reply to message #211178] | Thu, 27 March 2008 16:51  |  |
| Eclipse User  |  |  |  |  | Mohsen Saboorian wrote: > Hi,
 > working directory?
 > Mohsen.
 If you are asking what triggers Tomcat to reload a web application, you
 might have better luck asking on the Tomcat Users mailing list.  As far
 as I know, static content typically should not do so.  It is also
 possible that something is being published in addition to your change
 that is triggering the reload.  However, there isn't enough detail here
 to do much speculation beyond that.
 Larry
FUDForum. Page generated in 0.03263 seconds
