Re: Convert Eclipse RCP 3.7 Application to RAP 2.2 [message #1271058 is a reply to message #1271046] |
Fri, 14 March 2014 06:31 |
gaurav dubey Messages: 45 Registered: July 2009 |
Member |
Hi Ivan,
Thank you for the response, yes i am fine with the compilation errors for few components, the only doubt is in RAP portal the target platform for RAP 2.2 is mentioned as eclipse 3.8 to 4.3, so i am not sure whether it will support 3.7 architecture. As our RCP application is based on Eclipse 3.7 with features like perspectives, extension point and in eclipse 4.3 this architecture has been changed so is it possible to directly migrate the application from RCP 3.7 to RAP 2.2 with features like Perspectives, Wizards, Basic controls(Text, Label, Combo, Radio buttons) or we need to make lots of efforts to change the application.
We have tried to migrate one small part of the application from RCP to RAP 1.4 and we found that it can be done by changing small portion of the code, is it also applicable for RAP 2.2 or we have to first adapt the eclipse 4.3 architecture and then only we can move to RAP 2.2.
Thanks in advance.
Gaurav
FUDForum. Page generated in 0.04202 seconds
