Home » Eclipse Projects » GEF » one problem at PolylineConnection.class [GEF]
one problem at PolylineConnection.class [GEF] [message #210779] Mon, 06 March 2006 05:06 Go to next message
Because i want to draw connected line At GEF, i implement NodeEditPart for
my EditPart.
But i occure one problem which i wish that the CONNECTION_LAYER is the back
and the other figures
are the front.
ths attach file "right.png" is the picture that i want to do.
thanks .
  • Attachment: right.png
    (Size: 1.60KB, Downloaded 185 times)
  • Attachment: wrong.png
    (Size: 1.71KB, Downloaded 165 times)
Re: one problem at PolylineConnection.class [GEF] [message #210851 is a reply to message #210779] Mon, 06 March 2006 10:18 Go to previous message
If you always want connections at the back, then you could change the order
in which the layers are created in the root edit part for your Editor.
i.e.
* Creates a layered pane and the layers that should be printed.
* @see org.eclipse.gef.print.PrintGraphicalViewerOperation
* @return a new LayeredPane containing the printable layers
protected LayeredPane createPrintableLayers() {
FreeformLayeredPane layeredPane = new FreeformLayeredPane();
// Create connection layer first so that it will always be on the bottom
layeredPane.add(new ConnectionLayer(), CONNECTION_LAYER);
layeredPane.add(new FreeformLayer(), PRIMARY_LAYER);
return layeredPane;
-Steve
"veinson.fu" <fusiju@realtek.com.tw> wrote in message
news:duh1j5$10g$1@eclipse.org...
> my EditPart.
back
> are the front.
> thanks .
Previous Topic:How to create filled and not filled triangle at the end points of connection
Next Topic:gef diagram in table cell
Current Time: Sun Sep 21 22:57:48 EDT 2025
Powered by FUDForum. Page generated in 0.03527 seconds
