| SetPropertiesRule error [message #210618] | Thu, 20 March 2008 08:28  |  |
| Eclipse User  |  |  |  |  | Hi, I have installed the eclipse-jee-ganymede-M5-win32.zip. I created a new
 workspace.
 In my new workspace I created a dynamic web project named 'Zohar'. In my
 project I created a new servlet.
 I defined a new tomcat 6 (6.0.16) server.
 When I add the new project to the server and run it I get:
 WARNING: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting
 property 'source' to 'org.eclipse.jst.jee.server:Daphna' did not find a
 matching property.
 All output to the console is red (err stream I suppose).
 When I try to access my servlet I get a 404.
 What's wrong?
 Zohar.
| Re: SetPropertiesRule error [message #210643 is a reply to message #210626] | Thu, 20 March 2008 11:24  |  |
| Eclipse User  |  |  |  |  | Windofkeltia wrote: > zohar wrote:
 >> new workspace.
 >> my project I created a new servlet.
 >> Setting property 'source' to 'org.eclipse.jst.jee.server:Daphna' did
 >> not find a matching property.
 >> What's wrong?
 >> Thanks,
 >> Zohar.
 > I can't answer your full question, but the fact that the console window
 > contains red output from Tomcat does not necessarily indicate error.
 > When I start Tomcat, it's always red and works fine.
 > "INFO: Server startup in 815 ms"
 > If you see the above message at the end of everything else (with a
 > different value perhaps than 815), then your Tomcat server is almost
 > certainly up and running.
 > Look for your HTP 404 error based on a messed up path in the address
 > line of the browser (i.e.: doesn't match your project paths), a missing
 > class or JSP file, or an incorrect web.xml.
 > Wish I could help more, but I struggle against the mighty 404 myself all
 > too frequently.
 > Russ Bateman
 The warning about the source property is new with Tomcat 6.0.16 and may
 be ignored.  WTP adds a "source" attribute to identify which project in
 the workspace is associated with the context.  The fact that the Context
 object in Tomcat has no corresponding source property doesn't cause any
 problems.  As Russ states, the 404 is unrelated to this warning.
 Larry
FUDForum. Page generated in 0.03089 seconds
