Home » Eclipse Projects » Eclipse Scout » Sort and preselect in SmartFields
Sort and preselect in SmartFields [message #1269232] Tue, 11 March 2014 11:11 Go to next message
I was wondering, if it is possible to change the sorting mechanism and preselect values in a smartfield.
In my case the smartfield contains dates, which should be sorted from the latest to the oldest date. In addition the newest date should be preselected.
Thanks for your help.
Re: Sort and preselect in SmartFields [message #1269728 is a reply to message #1269232] Wed, 12 March 2014 02:05 Go to previous message
Have you tried using the "order by" clause in the SQL query with which you select the entries to populate the smart field? If that doesn't work you could store the result of the query in a sorted set before creating the LookupRow[] in LookupService.getDataByAll() and getDataByText().
Previous Topic:Questions concering SQL Service
Next Topic:SWT Rendering inner Group Box on a Custom Field
Current Time: Fri Nov 07 20:51:18 EST 2025
Powered by FUDForum. Page generated in 0.02413 seconds
