Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EMFStore] Urgent - ModelElements not populated after shutdown and restart of application
Re: [EMFStore] Urgent - ModelElements not populated after shutdown and restart of application [message #1268628 is a reply to message #1268621] |
Mon, 10 March 2014 19:18 |
Marina Knieling Messages: 83 Registered: February 2013 |
Member |
What exactly do you mean?
This is what I do in my performFinish method:
ESLocalProject organProject =
workspace.createLocalProject(organ.getOrganID());
ESUsersession userSession =
workspace.getServers().get(0).getLastUsersession();
organProject.getModelElements().add(organ);
organProject.shareProject(userSession, new ESSystemOutProgressMonitor());
And the xml files also exist in the .emfstore/client and
..emfstore/server folders. The projects get read and the IDs are exactly
as they are displayed in the folder. It's only the model elements that
aren't populated.
This is one of the xml files (client version):
<org.eclipse.emf.emfstore.internal.common.model:Project
xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:commamod="http://www.vknie.com/commamod"
xmlns:org.eclipse.emf.emfstore.internal.common.model="http://eclipse.org/emf/emfstore/common/model">
<modelElements xsi:type="commamod:Organ"
xmi:id="_xuZ8gKhUEeOipqjw_3X4mA" name="Domorgel" location="Paderborn"
numberOfStops="92" organBuilder="Sauer" yearOfConstruction="1876"
numberOfPipes="9840" numberOfRanks="4"/>
</org.eclipse.emf.emfstore.internal.common.model:Project>
So obviously there IS a model element (the Organ) in the file. But
calling localProject.getModelElements().size() returns 0 and debugging
also only displays an empty list.
Am 10.03.2014 20:00, schrieb Jonas Helming:
> do you save the project somewhere?
> regards
> jonas
> Am 10.03.2014 14:18, schrieb Marina Knieling:
>> Hey guys,
>> another problem or strange behaviour just popped up. I'm using the
>> EMFStore API to store my objects. I have a wizard that creates an object
>> and in the performFinish method I create a ESLocalProject, add my own
>> object to the modelElements and share it with the server. This works
>> perfectly fine, the file is created and the object is stored in it.
>> I also have a mechanism to switch the active element to work with (like
>> switching the workspace in eclipse). This is implemented using a JFace
>> ListDialog. The idea was to iterate through all local projects and get
>> the first modelElement out of it (which should be my top object). This
>> works fine, when I do it in the same "session" where I created that
>> object / that local project. But when I shut down my application and
>> start it again, the ListDialog keeps empty and debugging shows, that
>> there are no elements in the modelElements reference from the
>> ESLocalProject. I even tried the projects from the helloworld example
>> and they are also empty.
>> The code is the following:
>> List<ESLocalProject> projects = workspace.getLocalProjects();
>> List<Organ> allOrgans = new ArrayList<Organ>();
>> for(ESLocalProject p : projects){
>> System.out.println("modelElements: " +
>> p.getModelElements().size());
>> for(EObject o : p.getModelElements()){
>> if(o instanceof Organ)
>> allOrgans.add((Organ) o);
>> System.out.println("organs: " + allOrgans.size());
>> dialog.setInput(allOrgans);
>> Is there something wrong with my code? Do I have to do anything else?
>> Thanks in advance
>> Marina
Re: [EMFStore] Urgent - ModelElements not populated after shutdown and restart of application [message #1269016 is a reply to message #1268628] |
Tue, 11 March 2014 09:20 |
Edgar Mueller Messages: 89 Registered: March 2011 |
Member |
Hi Marina,
Jonas meant whether you called the save() method on the ESLocalProject
after you've added your model elements, but this should already be the
case when sharing a project.
I do not yet entirely understand your application's control flow. When
the performFinished method has finished and you restart your
application, does anything happen before you iterate through the
workspace? Can you check the project's contents right after application
has restarted?
The helloworld example does work for me (although you'll need to modify
the example since it always creates a new empty project). Can you tell
me how you checked the helloworld example? Ideally, something
reproducable would help us to diagnose the problem.
Edgar
Am 10.03.2014 20:18, schrieb Marina Knieling:
> aren't populated.
>> Hi,
>> regards
>> jonas
>>> Hey guys,
>>> Thanks in advance
>>> Marina
Edgar Mueller
Get Professional Eclipse Support: http://eclipsesource.com/munich
Re: [EMFStore] Urgent - ModelElements not populated after shutdown and restart of application [message #1269134 is a reply to message #1269016] |
Tue, 11 March 2014 12:36 |
Member |
Ok, let's try again:
When the application is started the very first time, the user needs to
create an Organ object (this is my top level object in my hierarchy -
like the League in the helloworld example). I create this object via a
JFace wizard. The performFinish method creates an ESLocalProject, adds
the Organ object to its modelelements and shares the project (as already
mentioned in the previous post).
I have a command to switch the Organ (like switching the workspace in
eclipse) and if I call this command/handler now (in the same "session"
where I created the Organ object), the recently added Organ gets
displayed in the ListDialog and my console output says 1 modelelement is
there and 1 project.
I now close my application. I checked back the standard .emfstore
folders whether the project was created correctly and I don't find any
errors there. The project file exists and has the before mentioned
contents (see last post).
Now I start my application again and call the SwitchOrgan handler. The
ListDialog keeps empty and the console output says 0 modelElements, but
1 project.
Concerning the helloworld example:
I ran the example and then ran my application afterwards (so the
..emfstore folder still had the 2 projects from the helloworld example)
and my console output said: 3 projects and 0 modelElements for each of
those projects.
Console output refers to these lines in the OrganSelectionDialog class
with the ListDialog in it, which should be populated with all Organs
(i.e. all top level modelElements from all local projects):
System.out.println("# projects: " + projects.size());
System.out.println("# modelElements: " + p.getModelElements().size());
The only thing I do during startup is to find the last active Organ (I
store the ID in the preferences), but already there the modelelements
are empty, see attached screenshot of debug.
I hope my problem is now clear and you understand what I'm doing. Thanks
for your help guys.
Am 11.03.2014 10:20, schrieb Edgar Mueller:
> Hi Marina,
> has restarted?
> Cheers,
> Edgar
>> aren't populated.
>> <?xml version="1.0" encoding="UTF-8"?>
>>> Hi,
>>> regards
>>> jonas
>>>> Hey guys,
>>>> Thanks in advance
>>>> Marina
Re: [EMFStore] Urgent - ModelElements not populated after shutdown and restart of application [message #1269177 is a reply to message #1269134] |
Tue, 11 March 2014 13:36 |
Member |
Hi Marina,
from your screenshot I can see that your workspace didn't initialze
correctly (modCount of the modelElements feature should not be 0), i.e.
the load function within ESWorkspaceProviderImpl did not get called or
failed for some reason.
How do you initialize your workspace reference? Do you use
ESWorkspaceProvider.INSTANCE? Are you able to send me the complete code
of your Activator?
Edgar
Am 11.03.2014 13:36, schrieb Marina Knieling:
> 1 project.
> those projects.
> for your help guys.
>> Hi Marina,
>> has restarted?
>> Cheers,
>> Edgar
>>> aren't populated.
>>>> Hi,
>>>> regards
>>>> jonas
>>>>> Hey guys,
>>>>> object
>>>>> (like
>>>>> Thanks in advance
>>>>> Marina
Edgar Mueller
Re: [EMFStore] Urgent - ModelElements not populated after shutdown and restart of application [message #1269184 is a reply to message #1269177] |
Tue, 11 March 2014 13:49 |
Member |
Hi Edgar,
I just changed my runtime config from features to plugins, now the
helloworld example projects are populated with their modelElements but
my own still aren't. Maybe I even miss something in my runtime config
although I don't get any errors on startup.
However, find attached my Activator. Yes, I do use
ESWorkspaceProvider.INSTANCE.getWorkspace().
Thanks for your help
Am 11.03.2014 14:36, schrieb Edgar Mueller:
> Hi Marina,
> of your Activator?
> Cheers,
> Edgar
>> 1 project.
>> those projects.
>> for your help guys.
>>> Hi Marina,
>>> has restarted?
>>> Cheers,
>>> Edgar
>>>> aren't populated.
>>>>> Hi,
>>>>> regards
>>>>> jonas
>>>>>> Hey guys,
>>>>>> object
>>>>>> (like
>>>>>> Thanks in advance
>>>>>> Marina
package com.vknie.comma.app;
import java.util.List;
import org.eclipse.core.runtime.preferences.InstanceScope;
import org.eclipse.e4.core.contexts.IContextFunction;
import org.eclipse.e4.ui.internal.workbench.E4Workbench;
import org.eclipse.e4.ui.workbench.modeling.EPartService;
import org.eclipse.emf.emfstore.client.ESLocalProject;
import org.eclipse.emf.emfstore.client.ESServer;
import org.eclipse.emf.emfstore.client.ESWorkspace;
import org.eclipse.emf.emfstore.client.ESWorkspaceProvider;
import org.eclipse.emf.emfstore.client.exceptions.ESServerNotFoundException;
import org.eclipse.emf.emfstore.client.exceptions.ESServerStartFailedException;
import org.eclipse.emf.emfstore.server.exceptions.ESException;
import org.osgi.framework.BundleActivator;
import org.osgi.framework.BundleContext;
import org.osgi.framework.InvalidSyntaxException;
import org.osgi.framework.ServiceReference;
import org.osgi.service.prefs.BackingStoreException;
import org.osgi.service.prefs.Preferences;
import CombinationManager.Model.Organ;
import com.vknie.comma.core.services.organprovider.OrganProvider;
@SuppressWarnings("restriction")
public class Activator implements BundleActivator {
private static BundleContext context;
OrganProvider organProvider; // OSGi Service
ESServer localServer;
ESWorkspace workspace;
ESLocalProject lastActiveProject = null;
static BundleContext getContext() {
return context;
* (non-Javadoc)
* @see org.osgi.framework.BundleActivator#start(org.osgi.framework.BundleContext)
public void start(BundleContext bundleContext) throws Exception {
Activator.context = bundleContext;
// Start local EMFStore Server
try {
// Create a client representation for a local server and start a local server.
localServer = ESServer.FACTORY.createAndStartLocalServer();
localServer.setPort(8090);
workspace = ESWorkspaceProvider.INSTANCE.getWorkspace();
workspace.addServer(localServer);
for (ESServer existingServer : workspace.getServers()) {
if (existingServer != localServer) {
try {
workspace.removeServer(existingServer);
} catch (ESServerNotFoundException e) {
e.printStackTrace();
localServer.login("super", "super");
} catch (ESServerStartFailedException e) {
// TODO try to recover or at least print a message to the user and shut down the application afterwards
System.out.println("Server start failed!");
} catch (ESException e) {
System.out.println("Login failed");
// obtain organ provider service
ServiceReference<?> organProviderServiceReference = context.getServiceReference(OrganProvider.class.getName());
organProvider = (OrganProvider) context.getService(organProviderServiceReference);
// get last active organ
Preferences preferences = InstanceScope.INSTANCE.getNode("com.vknie.comma.app"); //$NON-NLS-1$
String lastActiveOrganID = preferences.get("lastActiveOrganID", ""); //$NON-NLS-1$ //$NON-NLS-2$
if(p==null) // no project exists = first time start
break;
if(p.getProjectName().equals(lastActiveOrganID)){
lastActiveProject = p;
break;
if(lastActiveProject!=null && !lastActiveProject.getModelElements().isEmpty())
organProvider.setActiveOrgan((Organ) lastActiveProject.getModelElements().get(0));
* (non-Javadoc)
* @see org.osgi.framework.BundleActivator#stop(org.osgi.framework.BundleContext)
public void stop(BundleContext bundleContext) throws Exception {
// save the organID of the last active organ in the preferences
preferences.put("lastActiveOrganID", organProvider.getActiveOrgan().getOrganID()); //$NON-NLS-1$
// stop local EMFStore Server
ESServer.FACTORY.stopLocalServer();
try {
// forces the application to save the preferences
preferences.flush();
} catch (BackingStoreException e) {
Activator.context = null;
public static EPartService getEPartService() {
try {
final ServiceReference<?> service = context.getServiceReferences(IContextFunction.class.getName(),
"(service.context.key=" + EPartService.class.getName() + ")")[0];
// TODO a "bit" ugly
return (EPartService) ((IContextFunction) context.getService(service)).compute(E4Workbench
.getServiceContext(), null);
} catch (final InvalidSyntaxException e) {
return null;
Re: [EMFStore] Urgent - ModelElements not populated after shutdown and restart of application [message #1269325 is a reply to message #1269184] |
Tue, 11 March 2014 18:11 |
Member |
Hi Marina,
I think the issue lies within the initialization order of your bundles.
It seems as if your model plugin has not been resolved when the
workspace is initializing. That's why the example project seems to work.
Can you try to make sure your model bundle is loaded before the emfstore
bundles?
Edgar
Am 11.03.2014 14:49, schrieb Marina Knieling:
> Hi Edgar,
>> Hi Marina,
>> of your Activator?
>> Cheers,
>> Edgar
>>> 1 project.
>>> those projects.
>>> for your help guys.
>>>> Hi Marina,
>>>> has restarted?
>>>> Cheers,
>>>> Edgar
>>>>> exactly
>>>>> aren't populated.
>>>>>> Hi,
>>>>>> regards
>>>>>> jonas
>>>>>>> Hey guys,
>>>>>>> object
>>>>>>> own
>>>>>>> (like
>>>>>>> JFace
>>>>>>> and get
>>>>>>> This
>>>>>>> example
>>>>>>> else?
>>>>>>> Thanks in advance
>>>>>>> Marina
Edgar Mueller
Re: [EMFStore] Urgent - ModelElements not populated after shutdown and restart of application [message #1269913 is a reply to message #1269325] |
Wed, 12 March 2014 10:04 |
Member |
Hi Edgar,
I tried to change the start level of my model and model.edit bundle from
default to 3, 2 and 1, but nothing worked. The application only
recognizes the helloworld example projects' modelelements.
Is there any way to "see" when the bundles are loaded? I know about the
OSGi console and I used a breakpoint in my start method from the
app.Activator class I send you, but it seems that it is already too late
as my model bundles are already active/starting and the emfstore bundles
as well.
I don't have the helloworld example in my runtime config, only the
created projects in the .emfstore folder, but nevertheless my
application knows that there is 1 modelelement in it.
Any other ideas? I'm slowly going mad.
Am 11.03.2014 19:11, schrieb Edgar Mueller:
> Hi Marina,
> bundles?
> Cheers,
> Edgar
>> Hi Edgar,
>>> Hi Marina,
>>> of your Activator?
>>> Cheers,
>>> Edgar
>>>> 1 project.
>>>> those projects.
>>>> for your help guys.
>>>>> Hi Marina,
>>>>> has restarted?
>>>>> Cheers,
>>>>> Edgar
>>>>>> exactly
>>>>>> aren't populated.
>>>>>>> Hi,
>>>>>>> regards
>>>>>>> jonas
>>>>>>>> Hey guys,
>>>>>>>> object
>>>>>>>> own
>>>>>>>> (like
>>>>>>>> JFace
>>>>>>>> and get
>>>>>>>> This
>>>>>>>> example
>>>>>>>> else?
>>>>>>>> Thanks in advance
>>>>>>>> Marina
Re: [EMFStore] Urgent - ModelElements not populated after shutdown and restart of application [message #1269930 is a reply to message #1269913] |
Wed, 12 March 2014 10:21 |
Member |
Hi Marina,
ok, can you check the registration of your model, i.e.
the org.eclipse.emf.ecore.generated_package extension point? Is the
value of the URI attribute the same as in your model? I think in your
case it should be "http://www.vknie.com/commamod".
Am 12.03.2014 11:04, schrieb Marina Knieling:
> Hi Edgar,
> as well.
>> Hi Marina,
>> bundles?
>> Cheers,
>> Edgar
>>> Hi Edgar,
>>>> Hi Marina,
>>>> of your Activator?
>>>> Cheers,
>>>> Edgar
>>>>> already
>>>>> modelelement is
>>>>> but
>>>>> 1 project.
>>>>> example)
>>>>> those projects.
>>>>> Thanks
>>>>> for your help guys.
>>>>>> Hi Marina,
>>>>>> ESLocalProject
>>>>>> the
>>>>>> When
>>>>>> application
>>>>>> has restarted?
>>>>>> modify
>>>>>> tell
>>>>>> Cheers,
>>>>>> Edgar
>>>>>>> exactly
>>>>>>> that
>>>>>>> aren't populated.
>>>>>>> debugging
>>>>>>>> Hi,
>>>>>>>> regards
>>>>>>>> jonas
>>>>>>>>> Hey guys,
>>>>>>>>> object
>>>>>>>>> own
>>>>>>>>> works
>>>>>>>>> it.
>>>>>>>>> (like
>>>>>>>>> JFace
>>>>>>>>> and get
>>>>>>>>> This
>>>>>>>>> that
>>>>>>>>> application and
>>>>>>>>> that
>>>>>>>>> example
>>>>>>>>> else?
>>>>>>>>> Thanks in advance
>>>>>>>>> Marina
Edgar Mueller
Re: [EMFStore] Urgent - ModelElements not populated after shutdown and restart of application [message #1269945 is a reply to message #1269930] |
Wed, 12 March 2014 10:40 |
Member |
Edgar, my saviour (you can join Jonas now ;-) )
You did it!!! It wasn't the same. How can that happen and how do I
prevent that from happening again?
Thank you very very much for your patience.
Marina
Am 12.03.2014 11:21, schrieb Edgar Mueller:
> Hi Marina,
>> Hi Edgar,
>> as well.
>>> Hi Marina,
>>> bundles?
>>> Cheers,
>>> Edgar
>>>> Hi Edgar,
>>>>> Hi Marina,
>>>>> of your Activator?
>>>>> Cheers,
>>>>> Edgar
>>>>>> already
>>>>>> modelelement is
>>>>>> but
>>>>>> 1 project.
>>>>>> example)
>>>>>> those projects.
>>>>>> Thanks
>>>>>> for your help guys.
>>>>>>> Hi Marina,
>>>>>>> ESLocalProject
>>>>>>> the
>>>>>>> When
>>>>>>> application
>>>>>>> has restarted?
>>>>>>> modify
>>>>>>> tell
>>>>>>> Cheers,
>>>>>>> Edgar
>>>>>>>> exactly
>>>>>>>> that
>>>>>>>> aren't populated.
>>>>>>>> debugging
>>>>>>>>> Hi,
>>>>>>>>> regards
>>>>>>>>> jonas
>>>>>>>>>> Hey guys,
>>>>>>>>>> object
>>>>>>>>>> own
>>>>>>>>>> works
>>>>>>>>>> it.
>>>>>>>>>> (like
>>>>>>>>>> JFace
>>>>>>>>>> and get
>>>>>>>>>> This
>>>>>>>>>> that
>>>>>>>>>> application and
>>>>>>>>>> that
>>>>>>>>>> example
>>>>>>>>>> else?
>>>>>>>>>> Thanks in advance
>>>>>>>>>> Marina
Re: [EMFStore] Urgent - ModelElements not populated after shutdown and restart of application [message #1270069 is a reply to message #1269945] |
Wed, 12 March 2014 13:06 |
Member |
Hi Marina,
glad to hear you could solve the problem. I think this error happens if
you already have triggered the generator once and change the nsURI
attribute afterwards, since the changes will not be written to the
plugin.xml.
But it should work, of course, if you delete the plugin.xml before you
trigger the re-generation, such that the whole file will be written again.
Edgar
Am 12.03.2014 11:40, schrieb Marina Knieling:
> Cheers,
> Marina
>> Hi Marina,
>>> Hi Edgar,
>>> as well.
>>>> Hi Marina,
>>>> work.
>>>> emfstore
>>>> bundles?
>>>> Cheers,
>>>> Edgar
>>>>> Hi Edgar,
>>>>>> Hi Marina,
>>>>>> i.e.
>>>>>> called or
>>>>>> code
>>>>>> of your Activator?
>>>>>> Cheers,
>>>>>> Edgar
>>>>>>> needs to
>>>>>>> hierarchy -
>>>>>>> via a
>>>>>>> adds
>>>>>>> already
>>>>>>> workspace in
>>>>>>> "session"
>>>>>>> modelelement is
>>>>>>> find any
>>>>>>> handler. The
>>>>>>> but
>>>>>>> 1 project.
>>>>>>> example)
>>>>>>> each of
>>>>>>> those projects.
>>>>>>> class
>>>>>>> Organ (I
>>>>>>> modelelements
>>>>>>> Thanks
>>>>>>> for your help guys.
>>>>>>>> Hi Marina,
>>>>>>>> ESLocalProject
>>>>>>>> the
>>>>>>>> When
>>>>>>>> application
>>>>>>>> has restarted?
>>>>>>>> modify
>>>>>>>> tell
>>>>>>>> Cheers,
>>>>>>>> Edgar
>>>>>>>>> exactly
>>>>>>>>> that
>>>>>>>>> aren't populated.
>>>>>>>>> debugging
>>>>>>>>>> Hi,
>>>>>>>>>> regards
>>>>>>>>>> jonas
>>>>>>>>>>> Hey guys,
>>>>>>>>>>> using the
>>>>>>>>>>> creates an
>>>>>>>>>>> object
>>>>>>>>>>> add my
>>>>>>>>>>> own
>>>>>>>>>>> works
>>>>>>>>>>> it.
>>>>>>>>>>> with
>>>>>>>>>>> (like
>>>>>>>>>>> JFace
>>>>>>>>>>> and get
>>>>>>>>>>> object).
>>>>>>>>>>> This
>>>>>>>>>>> that
>>>>>>>>>>> application and
>>>>>>>>>>> that
>>>>>>>>>>> example
>>>>>>>>>>> else?
>>>>>>>>>>> Thanks in advance
>>>>>>>>>>> Marina
Edgar Mueller
Re: [EMFStore] Urgent - ModelElements not populated after shutdown and restart of application [message #1700010 is a reply to message #1270069] |
Mon, 29 June 2015 15:51 |
Ravikanth Somayaji Messages: 49 Registered: July 2009 Location: Oxford |
Member |
I've been having a similar problem in that when i try to retrieve the model objects that I added to localProject.getModelElements() return an empty list.
This problem occurs even without the restart - as soon as I add the model elements to the list and try to do a getModelElements() there aren't any -
I have tried
- Setting the emfstore plugins start level to 5 (which is greater than those of my models)
- the uri in the model is that in the generated_package contribution
Any help would be appreciated. You also mentioned resources not loading in the
org.eclipse.emf.emfstore.internal.client.model.ESWorkspaceProviderImpl.load()
Is there something I should be looking out for?
[Updated on: Mon, 29 June 2015 16:20] Report message to a moderator
Current Time: Fri Apr 26 04:32:00 GMT 2024
Powered by FUDForum. Page generated in 0.05234 seconds
