Home » Newcomers » Newcomers » Problem with 3.3 M7 and Swing menu bars
Problem with 3.3 M7 and Swing menu bars [message #210284] Thu, 10 May 2007 20:22 Go to next message
Originally posted by: Qu0llSixFour.gmail.com
I have just upgraded from 3.3 M6 to M7 and now encounter a problem with any
Swing program I run from within the IDE where the menus on the menu bar
start out grayed-out and the menu bar background is obscured by the menus
themselves. If I then move the mouse over the menus they will appear
enabled and function normally but the menu bar background remains obscured.
If I run the exact same application from the command line it runs properly
and shows no such problems. I also tried reinstalling M6 in another
directory so I have both M6 and M7 installed at the same time. If I run the
application under M6 it behaves correctly but not under M7 using the exact
same workspace and project. I only have one JDK/JRE installed so it can't
be getting confused as to which one to run with. I have tried the simplest
of test programs that just displays a menu bar and nothing else and it also
misbehaves under M7.
Why would M7 have this effect on running a Swing program? I am using Java 6
Update 1 by the way. Is it a known problem? Am I doing something wrong?
And loving it,
-Q
_________________________________________________
Qu0llSixFour@gmail.com
(Replace the "SixFour" with numbers to email me)
Re: Problem with 3.3 M7 and Swing menu bars [message #210292 is a reply to message #210284] Thu, 10 May 2007 20:31 Go to previous message
"Qu0ll" <Qu0llSixFour@gmail.com> wrote in message
news:f20d0e$hrj$1@build.eclipse.org...
> the application under M6 it behaves correctly but not under M7 using the
> exact same workspace and project. I only have one JDK/JRE installed so it
> can't be getting confused as to which one to run with. I have tried the
> simplest of test programs that just displays a menu bar and nothing else
> and it also misbehaves under M7.
> 6 Update 1 by the way. Is it a known problem? Am I doing something
> wrong?
Never mind, I figured it out. I had configured M7 to run in Windows XP
compatibility mode to try to resolve some other issues. Obviously my
application is getting confused as to whether it's running under XP or
Vista.
And loving it,
-Q
Previous Topic:JVMPI error
Next Topic:the use of bin folder
Current Time: Fri Nov 07 03:49:07 EST 2025
Powered by FUDForum. Page generated in 0.07813 seconds
