| JVMPI error [message #210259] |
Thu, 10 May 2007 16:52  |
Originally posted by: denwe02.ca.com
I'm following the API Recorder tutorial to try a java code I have. After I
did the Java Application configuration and switching to the Profilng and
Logging perspective, I got error: Could not resolve to JVMPI interface
FATAL ERROR: JVMPI, an experimental interface, is no longer supported.
Please use the supported interface: the JVM Tool Interface (JVM TI).
For information on temporary workarounds contact: jvmpi_eol@sun.com
Error occurred during initialization of VM
-Xrun library failed to init: piAgent
I checked that I installed jdk6.0
What can I do to pass this error?
Thanks.
| Re: JVMPI error [message #210277 is a reply to message #210259] |
Thu, 10 May 2007 18:06  |
Originally posted by: wharley.bea.com
"Wenjun" <denwe02@ca.com> wrote in message
news:41add0a09b916c35905cdcf621248e05$1@www.eclipse.org...
Questions about TPTP might be best asked on the eclipse.tptp newsgroup.
But anyway: JVM 6 does not support JVMPI. If you're running on a Java 6 VM,
you need to use JVMTI instead, which means you need to use Eclipse 3.3 and
the newest version of TPTP.
The alternative is to run on a Java 5 or older VM.
FUDForum. Page generated in 0.08487 seconds
