Home » Modeling » Graphiti » Adding features dynamically
Adding features dynamically [message #1267239] Sat, 08 March 2014 13:05 Go to next message
Is there a simple way to call the FeatureProvider to populate the toolbox/palette dynamically before starting up the diagram ?
Re: Adding features dynamically [message #1268487 is a reply to message #1267239] Mon, 10 March 2014 11:06 Go to previous messageGo to next message
you can override getPalette in the Tool Behavior Provider. The default
implementation simply adds tools for all create features to the palette.
Michael
Re: Adding features dynamically [message #1270077 is a reply to message #1268487] Wed, 12 March 2014 09:15 Go to previous messageGo to next message
But the problem is i have to pass a model to the createFeatureProvider to decide what to be included in the diagram toolbox is there any way to instantiate a custom DiagramtypeProvider for a given diagram and set it to the corresponding diagram or editor before starting it up ?
Re: Adding features dynamically [message #1270788 is a reply to message #1270077] Thu, 13 March 2014 09:48 Go to previous messageGo to next message
You can pass a DiagramTypeProvider id in the DiagramEditorInput to open an
editor. Does that help in your case?
Michael
Re: Adding features dynamically [message #1271302 is a reply to message #1270788] Fri, 14 March 2014 15:39 Go to previous messageGo to next message
Not quite, i still wont be able to pass any parameter to it so the FeatureProvider wont know how to generate the CreateFeatures needed when its called by the DiagramTypeProvider "SetFeatureProvider"
Right now i declare this parameter as a global variable but a possibility to pass a parameter to either the DiagramTypeProvider or FeatureProvider would be much better to understand and maintain
[Updated on: Fri, 14 March 2014 15:42] by Moderator
Re: Adding features dynamically [message #1276264 is a reply to message #1271302] Mon, 24 March 2014 06:09 Go to previous message
Yes, but you could have different DiagramTypeProviders, each creating the
right set of features.
Michael
Previous Topic:Professional Support
Next Topic:Dynamic "Refreshing" of Palette on Object Selection
Current Time: Sun Sep 14 15:26:12 EDT 2025
Powered by FUDForum. Page generated in 0.03624 seconds
