Got NPE on Marshall with JAX-RS and multi requests [message #1265995] |
Thu, 06 March 2014 21:14 |
Clovis Wichoski Messages: 7 Registered: March 2012 |
I'm using EclipseLink 2.5.1 with JAX-RS and now I got a strange problem, that I think its about multi-threads, the error occurs when I call in parallel REST resources from same client session, if I call the one, then another not in parallel, the NPE dont occurs:
here the full stack for parallel case:
WARNING: WebApplicationException cause:
javax.xml.bind.MarshalException
- with linked exception:
[java.lang.NullPointerException]
at org.eclipse.persistence.jaxb.JAXBMarshaller.marshal(JAXBMarshaller.java:539)
at de.odysseus.staxon.json.jaxb.JsonXMLBinder.marshal(JsonXMLBinder.java:127)
at de.odysseus.staxon.json.jaxb.JsonXMLBinder.writeObject(JsonXMLBinder.java:155)
at de.odysseus.staxon.json.jaxrs.jaxb.JsonXMLObjectProvider.write(JsonXMLObjectProvider.java:80)
at de.odysseus.staxon.json.jaxrs.jaxb.AbstractJsonXMLProvider.writeTo(AbstractJsonXMLProvider.java:135)
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.invokeWriteTo(WriterInterceptorExecutor.java:243)
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.aroundWriteTo(WriterInterceptorExecutor.java:230)
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:149)
at org.glassfish.jersey.server.internal.JsonWithPaddingInterceptor.aroundWriteTo(JsonWithPaddingInterceptor.java:103)
at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:88)
at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1139)
at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:557)
at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:381)
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:371)
at org.glassfish.jersey.server.ServerRuntime$1.run(ServerRuntime.java:262)
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271)
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267)
at org.glassfish.jersey.internal.Errors.process(Errors.java:315)
at org.glassfish.jersey.internal.Errors.process(Errors.java:297)
at org.glassfish.jersey.internal.Errors.process(Errors.java:267)
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:318)
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:236)
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:983)
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:361)
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:372)
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:335)
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:218)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.netbeans.modules.web.monitor.server.MonitorFilter.doFilter(MonitorFilter.java:393)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:953)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1023)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:312)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:744)
at org.eclipse.persistence.internal.oxm.XMLCompositeObjectMappingNodeValue.marshal(XMLCompositeObjectMappingNodeValue.java:145)
at org.eclipse.persistence.internal.oxm.NodeValue.marshal(NodeValue.java:102)
at org.eclipse.persistence.internal.oxm.record.ObjectMarshalContext.marshal(ObjectMarshalContext.java:59)
at org.eclipse.persistence.internal.oxm.XPathNode.marshal(XPathNode.java:401)
at org.eclipse.persistence.internal.oxm.XPathObjectBuilder.buildRow(XPathObjectBuilder.java:240)
at org.eclipse.persistence.internal.oxm.TreeObjectBuilder.buildRow(TreeObjectBuilder.java:118)
at org.eclipse.persistence.internal.oxm.TreeObjectBuilder.buildRow(TreeObjectBuilder.java:1)
at org.eclipse.persistence.internal.oxm.XMLCompositeCollectionMappingNodeValue.marshalSingleValue(XMLCompositeCollectionMappingNodeValue.java:328)
at org.eclipse.persistence.internal.oxm.XMLCompositeCollectionMappingNodeValue.marshal(XMLCompositeCollectionMappingNodeValue.java:108)
at org.eclipse.persistence.internal.oxm.NodeValue.marshal(NodeValue.java:149)
at org.eclipse.persistence.internal.oxm.XMLMarshaller.marshal(XMLMarshaller.java:751)
at org.eclipse.persistence.internal.oxm.XMLMarshaller.marshal(XMLMarshaller.java:571)
at org.eclipse.persistence.jaxb.JAXBMarshaller.marshal(JAXBMarshaller.java:537)
... 47 more
Inspecting the code at org.eclipse.persistence.internal.oxm.XMLCompositeObjectMappingNodeValue.marshal(XMLCompositeObjectMappingNodeValue.java:145)
we have this method:
public boolean marshal(XPathFragment xPathFragment, MarshalRecord marshalRecord, Object object, CoreAbstractSession session, NamespaceResolver namespaceResolver, MarshalContext marshalContext) {
if (xmlCompositeObjectMapping.isReadOnly()) {
return false;
int size =marshalRecord.getCycleDetectionStack().size();
Object objectValue = marshalContext.getAttributeValue(object, xmlCompositeObjectMapping);
if((isInverseReference || xmlCompositeObjectMapping.getInverseReferenceMapping() !=null)&& objectValue !=null && size >= 2){
Object owner = marshalRecord.getCycleDetectionStack().get(size - 2);
if(owner.equals(objectValue)){
return false;
return this.marshalSingleValue(xPathFragment, marshalRecord, object, objectValue, session, namespaceResolver, marshalContext);
The line with problem is:
But that can throw the NPE only if another thread change the size of getCycleDetectionStack().
how I can avoid that as the marshaller is injected?
regards
Clóvis
ps: The webapp runs inside a tomcat 7
Re: Got NPE on Marshall with JAX-RS and multi requests [message #1505450 is a reply to message #1265995] |
Wed, 10 December 2014 03:57 |
Just replying here with a "Me, too!" comment. I have a StackOverflow question about this same exact issue.
stackoverflow.com/questions/27384142/eclipselink-moxy-intermittent-nullpointerexception-marshalexception-with-conc
When I get to work tomorrow, I'm going to try using the latest SNAPSHOT release to see if the problem goes away for me, too.
Thanks!
FUDForum. Page generated in 0.03337 seconds
