Struts 2 in Eclipse [message #209748] |
Thu, 06 March 2008 04:03 |
Originally posted by: tomsattler.gmail.com
Greetings. I am trying to set up a Struts 2 project in Eclipse, and I
can't seem to do so. I have installed the Webtools project, as well as
the Graphical Editor Framework, the Eclipse Modeling Framework, and the
Java EMF Model, just like the instructions say. All the tutorials I have
found say "From File->New->Other menu, select Dynamic Web Project". I see
nothing even remotely close to "Dynamic Web Project" in that list. Could
someone let me know what I am doing wrong here?
Thanks very much in advance,
Tom
Re: Struts 2 in Eclipse [message #209756 is a reply to message #209748] |
Thu, 06 March 2008 05:01 |
> have found say "From File->New->Other menu, select Dynamic Web
> Project". I see nothing even remotely close to "Dynamic Web Project" in
> that list. Could someone let me know what I am doing wrong here?
> Tom
Just get the Project Explorer view, right-click in the white space,
choose New->Project... Then click on Web near the bottom and you'll see
it there. Now, from your description, I couldn't tell if you downloaded
Eclipse JEE--that's the one you want.
Russ
Re: Struts 2 in Eclipse [message #209801 is a reply to message #209748] |
Thu, 06 March 2008 15:12 |
Is it possible that you're not running with a 1.5 or higher
supported JRE?
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Struts 2 in Eclipse [message #209869 is a reply to message #209756] |
Fri, 07 March 2008 03:41 |
Hello Russ,
Thanks very much for the answer. Yes, you were absolutely correct, I was
not working with the JEE version of Eclipse. I was working with the
"classic" version. Once I downloaded and configured the JEE version, it
worked great.
Thanks again. I don't think I would have figured this out on my own.
--Tom
Re: Struts 2 in Eclipse [message #209874 is a reply to message #209801] |
Fri, 07 March 2008 03:43 |
Nitin,
I am running with a 1.6 JRE. The problem was solved by the first poster;
I was not running with the JEE version of Eclipse, and once I switched
over to that, everything works. Thank you for your insight and assistance.
--Tom
FUDForum. Page generated in 0.05335 seconds
