Home » Modeling » GMF (Graphical Modeling Framework) » Drag & Drop not working on Windows
Drag & Drop not working on Windows [message #209721] Tue, 28 October 2008 10:44 Go to next message
Originally posted by: knakov.scopeset.de
On my linux box I can successfully drag an item from the project
explorer to the canvas. But on windows the
DragDropEditPolicy.getDropObjectsCommand() is not invoked at all. What
could be the reason?
Kalin
Re: Drag & Drop not working on Windows [message #209728 is a reply to message #209721] Tue, 28 October 2008 11:12 Go to previous messageGo to next message
I have traced this exception:
java.lang.ClassCastException: org.eclipse.jface.viewers.TreeSelection
cannot be cast to org.eclipse.emf.ecore.EObject
org.eclipse.gmf.runtime.diagram.ui.editpolicies.DiagramDragD ropEditPolicy.getDropObjectsCommand(DiagramDragDropEditPolic y.java:78)
org.eclipse.gmf.runtime.diagram.ui.editpolicies.DragDropEdit Policy.getCommand(DragDropEditPolicy.java:80)
org.eclipse.gef.editparts.AbstractEditPart.getCommand(Abstra ctEditPart.java:473)
This problem appears on windows only.
Kalin Nakov wrote:
> Cheers,
> Kalin
Re: Drag & Drop not working on Windows [message #209765 is a reply to message #209728] Tue, 28 October 2008 13:11 Go to previous messageGo to next message
Hello Kalin,
Is it something like: https://bugs.eclipse.org/bugs/show_bug.cgi?id=249718?
Alex Shatalin
Re: Drag & Drop not working on Windows [message #209812 is a reply to message #209765] Wed, 29 October 2008 03:25 Go to previous messageGo to next message
Yes, could be the same issue. The problem occurs only when dragging an
item from a domain model. Dragging files works fine. The reason is that
the drag&drop operation does not fill in the objects being dragged. I
have solved the issue both on windows and on linux by adding a new drop
target listener to the diagram editor, filling-in the content in
getObjectsBeingDropped() using
LocalSelectionTransfer.getTransfer().getSelection() and converting the
selection to EObjects using getAdapter().
Kalin
Alex Shatalin wrote:
> Hello Kalin,
> Alex Shatalin
Re: Drag & Drop not working on Windows [message #209825 is a reply to message #209812] Wed, 29 October 2008 05:36 Go to previous message
Hello Kalin,
What is the difference between your DropTargetListener and one generated
by GMF? (you can see example of GMF-generated DropTargetListener in ecore
diagram editor - org.eclipse.gmf.ecore.part.EcoreDiagramEditor.DropTargetList ener
class.
Alex Shatalin
Previous Topic:Customize Figures and Layouts
Next Topic:how I customize my Outline View
Current Time: Sat Sep 27 11:58:58 EDT 2025
Powered by FUDForum. Page generated in 0.02951 seconds
