Re: URGENT: Cant install and run eclipse on ubuntu 12.0.4 [message #1267193 is a reply to message #1266892] |
Sat, 08 March 2014 16:30 |
On 03/07/2014 09:31 PM, Nia Cc wrote:
> PS. I also met some weird problems when i tried to use ant to write
> simple buildfile in armidale. Im sure the code part is correct. can it
> be caused by the same reason? Should i install 32-bit OS to avoid same
> problems?
Nia,
Don't rush off to reinstall your computer just yet. Use uname -a to see
exactly what OS you've got. For example, here's what I get:
~ $ uname -a
Linux tuonela 3.2.0-23-generic #36-Ubuntu SMP Tue Apr 10 20:39:51 UTC
2012 x86_64 x86_64 x86_64 GNU/Linux
You'll notice that it says 64-bit. Also, what Nitin asked shows me I'm
using 64-bit as well:
~ $ locate libgtk-
/usr/lib/i386-linux-gnu/libgtk-x11-2.0.so.0
/usr/lib/i386-linux-gnu/libgtk-x11-2.0.so.0.2400.10
/usr/lib/x86_64-linux-gnu/libgtk-3-0
/usr/lib/x86_64-linux-gnu/libgtk-3.so.0
/usr/lib/x86_64-linux-gnu/libgtk-3.so.0.400.2
/usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0
/usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0.2400.10
/usr/lib/x86_64-linux-gnu/libgtk-3-0/gtk-query-immodules-3.0
/usr/lib/x86_64-linux-gnu/libgtk-3-0/gtk-update-icon-cache-3.0
/usr/share/doc/libgtk-3-0
To use the locate command properly, you need to do this first. It may
have been a long time since you did it. It rebuilds a database of
locations in the filesystem for the next time you use locate. Then try
locate again:
~ $ sudo updatedb
64-bit isn't what I see in your reply with the results of locate. Please
send us the result of uname -a.
Hope we're helping!
FUDForum. Page generated in 0.07749 seconds
