how to use java( or ocl if is possible) for a link constraint in gmfmap [message #209532] |
Sun, 26 October 2008 16:05 |
Originally posted by: mattia.lambertini.studio.unibo.it
I have an Element TProcessor and an element that rappresent a link
TEdge. TProcessor have an attribute type and depending on the value of
type the number of outgoing and ingoing edge( of type TEdge) is different.
How can i write a link constraint that solve my problem?
Re: how to use java( or ocl if is possible) for a link constraint ingmfmap [message #209652 is a reply to message #209595] |
Mon, 27 October 2008 21:27 |
Thank a lot Alex! That's what I need! But know I have another problem.
The TProcessor's type is not a simple type but a complex TProcessorType
type. How can I specify the desiredType?
I don't understand how I can do something like self.type =
TProcessorType.Start
I tried: self.type = 'Start' and self.type = 0 but they don't work.
If help I post two little piece of my ecore.
This is the attribute type of TProcessor in the ecore file:
<eStructuralFeatures xsi:type="ecore:EAttribute" name="type"
eType="#//TProcessorType"
unsettable="true">
<eAnnotations
source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="kind" value="attribute"/>
<details key="name" value="type"/>
<details key="namespace" value="##targetNamespace"/>
</eAnnotations>
</eStructuralFeatures>
And this is the TProcessorType in the ecore:
<eClassifiers xsi:type="ecore:EEnum" name="TProcessorType">
<eAnnotations
<details key="name" value="TProcessorType"/>
</eAnnotations>
<eLiterals name="Start"/>
<eLiterals name="Simple" value="1"/>
<eLiterals name="Par" value="2"/>
<eLiterals name="Join" value="3"/>
<eLiterals name="JoinWT" value="4"/>
<eLiterals name="And" value="5"/>
<eLiterals name="JoinPar" value="6"/>
<eLiterals name="JoinWTPar" value="7"/>
<eLiterals name="AndPar" value="8"/>
<eLiterals name="SimplePar" value="9"/>
<eLiterals name="JoinSimplePar" value="10"/>
<eLiterals name="JoinWTSimplePar" value="11"/>
<eLiterals name="AndSimplePar" value="12"/>
<eLiterals name="Incoming" value="14"/>
<eLiterals name="End" value="15"/>
</eClassifiers>
Alex Shatalin wrote:
> Hello Mattia,
> Try link source(/target) constraint (OCL) like:
> self.outgoing->size() < (if self.type = <desiredType1> then <x> else if
> self.type = <desiredType2> then <y> else <z> endif)
> Alex Shatalin
Re: how to use java( or ocl if is possible) for a link constraint ingmfmap [message #209660 is a reply to message #209652] |
Tue, 28 October 2008 03:20 |
Originally posted by: cdamus.zeligsoft.com
Hi, Mattia,
The syntax for enumeration literals is like this:
self.type = TProcessorType::Start
Christian
> unsettable="true">
> <eAnnotations
> </eAnnotations>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
>> Hello Mattia,
>> if self.type = <desiredType2> then <y> else <z> endif)
>> Alex Shatalin
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209735 is a reply to message #209693] |
Tue, 28 October 2008 15:46 |
> try "TProcessorType::Start" or (even better)
> "<modelPackage>::TProcessorType::Start"
It doesn't work! If i only type this test: self.type =
TProcessorType::Start or self.type = process::TProcessorType::Start it's
always false.
Is there a way to see the value(what is) of self.type and
process::TProcessorType::Start on runtime? like a log.
Or something like an interpreter to use for testing my ocl code on my
model? Something that tell's what i am wrong.
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209743 is a reply to message #209735] |
Tue, 28 October 2008 16:31 |
I discovered the Error Log window :).
If i i write an ocl test like:
the error is:
Expression problem:Unrecognized variable: (type)body:self.type =
and for this test:
self.outgoing->size() < 5
the error is:
(outgoing)body:self.outgoing->size() < 5
it don't find type and outgoing, but i am sure that type exist. Any idea?
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209758 is a reply to message #209743] |
Tue, 28 October 2008 17:06 |
Hi, Mattia,
Probably, then, the constraint is defined on the wrong EClass? What is
your context EClass? (the type of "self") It seems clear that the
context EClass does not have a "type" attribute.
To test OCL expressions on your Ecore model, you will find the
Interactive OCL Console example very helpful. Install it from the MDT
OCL component's examples feature. It adds a menu action to Ecore and
UML editors that opens the OCL console. A quick guide to using it is in
the OCL SDK help documentation.
MDT OCL also provides tracing options for parsing and evaluation; see
the Tracing tab in the Run launch configuration dialog.
HTH,
Christian
> the error is:
> and for this test:
> the error is:
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209771 is a reply to message #209749] |
Tue, 28 October 2008 17:39 |
> Hello Mattia,
>> idea?
> Is it a LinkMapping.creationConstraints.sourceEnd/targetEnd constraitn
> or LinkMapping.DomainSpecialization ?
> (first option is correct).
> Alex Shatalin
I think the first but maybe i am wrong. I do link mapping -> link
constraint -> source end constraint.
If i write: self.name = 'zio'
and i set 'zio' as name in my element all work!
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209778 is a reply to message #209758] |
Tue, 28 October 2008 18:01 |
Hi Christian,
My context Eclass is TProcessor class. surely there is an error in
something that i do but as you can see in this piece of my ecore there
is an attribute type in that class:
unsettable="true">
<eAnnotations
</eAnnotations>
the whole TProcessor element in my ecore:
<eClassifiers xsi:type="ecore:EClass" name="TProcessor"
eSuperTypes="#//NodesType">
<eAnnotations
<details key="name" value="TProcessor"/>
<details key="kind" value="elementOnly"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference"
name="cancellationArea" eType="#//TCancellationArea"
containment="true" resolveProxies="false">
<eAnnotations
<details key="kind" value="element"/>
<details key="name" value="cancellationArea"/>
</eAnnotations>
name="processLogic" eType="ecore:EDataType
http://www.eclipse.org/emf/2003/XMLType#//String">
<eAnnotations
<details key="name" value="processLogic"/>
</eAnnotations>
name="sourceAndEdgeId" eType="ecore:EDataType
http://www.eclipse.org/emf/2003/XMLType#//IDREF">
<eAnnotations
<details key="name" value="sourceAndEdgeId"/>
</eAnnotations>
name="supportedEvents" eType="#//TEventType"
unsettable="true">
<eAnnotations
<details key="name" value="supportedEvents"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="th"
eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//Integer">
<eAnnotations
<details key="name" value="th"/>
</eAnnotations>
unsettable="true">
<eAnnotations
</eAnnotations>
</eClassifiers>
thank a lot for this information!
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209792 is a reply to message #209785] |
Tue, 28 October 2008 18:50 |
> then try self.type = process::TProcessorType::Start
it doesn' work. But maybe the problem is that in my link mapping the
source feature is a Connection.source:TProcess. Where TProcess is a
superclass for TProcessor. In TProcess there isn't the attribute type.
Is it the problem?
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209815 is a reply to message #209792] |
Wed, 29 October 2008 08:42 |
> Is it the problem?
I saw that self is considered only a TProcess and so i can access only
its attribute.
There's a way to cast self into another type in ocl? If there isn't, I
can write the constraint in java, right? Optionally i can do this into
the java classes. Which classes i have to touch?
Re: how to use java( or ocl if is possible) for a link constraintingmfmap [message #209820 is a reply to message #209815] |
Wed, 29 October 2008 09:16 |
I solved using
self.oclAsType(TProcessor).type = process::TProcessorType::Start
Thank for the precious help till now!!
I have another problem, if i want to set the max number of link that an
element can have i have to write:
self.oclAsType(TProcessor).outgoing->size() < 2
but outgoing doesn't exist. What's outgoing?
FUDForum. Page generated in 0.03622 seconds
