Home » Eclipse Projects » GEF » How to draw draw2D Label vertically
How to draw draw2D Label vertically [message #209385] Tue, 14 February 2006 05:00 Go to next message
Originally posted by: s.prasad2.zensar.com
I would like to draw draw2d Label (org.eclipse.draw2d.Label) "vertically".
Would be great if you suggest someting about it.
-sanjay
Re: How to draw draw2D Label vertically [message #209395 is a reply to message #209385] Tue, 14 February 2006 11:47 Go to previous messageGo to next message
Sanjay,
Just subclass the Label, and override the paintFigure() method by
calling graphics.rotate(90); before super.paintFigure().
Draw2d team seems to look for a plugable style mechanism that would
allow to decorate your figures without subclassing them. But you'll have
to be patient.
Didier.
Sanjay P semwal wrote:
> Hello,
> -sanjay
Re: How to draw draw2D Label vertically [message #209435 is a reply to message #209395] Tue, 14 February 2006 10:07 Go to previous messageGo to next message
I'm not sure rotation would be considered a style. It requires altering the
preferred size.
"Ptitjes" <ptitjes@beuz.org> wrote in message
news:dsscgd$gbp$1@utils.eclipse.org...
> Sanjay,
> Just subclass the Label, and override the paintFigure() method by calling
> Draw2d team seems to look for a plugable style mechanism that would allow
> to decorate your figures without subclassing them. But you'll have to be
> patient.
> Didier.
>> Hello,
>> "vertically".
>> Thanks,
>> -sanjay
Re: Soem issues with coordinates [message #209479 is a reply to message #209435] Wed, 15 February 2006 09:03 Go to previous messageGo to next message
Originally posted by: geeteshjain.yahoo.com
hi .. i have a issue with the behaviour of graphics object when object is
rotated.
I have been trying to display a text vertically (for Swimlane) in bottom
to top fashion.
for which iam using rotate() method .
protected void paintFigure(Graphics g) {
Rectangle r = getBounds()
g.rotate(270);
g.drawString("Pool", r.x, r.y-55);
But after using the rotate method, the coordinates changes..
So i want to know how to trace the exact x,y coordinates after the
rotation method, so that i can place text "pool" in the required fashion
Thanks .
Geetesh
Re: Soem issues with coordinates [message #209633 is a reply to message #209479] Fri, 17 February 2006 09:52 Go to previous messageGo to next message
You need to first translate to the location where the top-left placement of
the rotated text will be. Then rotate, then draw the text at 0,0.
"Geetesh" <geeteshjain@yahoo.com> wrote in message
news:678eb4b89651e9a9e36e3c3ec0ff9188$1@www.eclipse.org...
> rotated.
> to top fashion.
> g.rotate(270);
> But after using the rotate method, the coordinates changes.. So i want to
> know how to trace the exact x,y coordinates after the rotation method, so
> Thanks .
> Geetesh
Re: Soem issues with coordinates [message #1715206 is a reply to message #209633] Fri, 20 November 2015 04:11 Go to previous message
Can you tell me is there any way, we can optimize paintfigure () method in GEF ? I am see it is getting called continuously , so want to make sure it does not leak memory ...
Previous Topic:meassuring performance and optimization of figure painting
Next Topic:[GEF4] FXViewer don't work into FX SplitPane.
Current Time: Sat Nov 08 11:26:30 EST 2025
Powered by FUDForum. Page generated in 0.25437 seconds
