| key binding in e4 RCP application [message #1263889] |
Tue, 04 March 2014 16:28  |
I have a problem with key binding in my E4 RCP application. It looks like it doesn't work at all (I cannot even open liveeditor even if I have it correctly added in my run configuration).
When I try to create new example project with sample content via "Eclipse 4 application project" wizard, all key binding defiinitions are working correctly, so I just do not see something in my project. I already tried to remove all dependencies from plugin.xml and all features dependencies from my product file and add them all again but it didn't help.
Add-ons used in my model are:
contributionURI="bundleclass://org.eclipse.e4.core.commands/org.eclipse.e4.core.commands.CommandServiceAddon"
contributionURI="bundleclass://org.eclipse.e4.ui.services/org.eclipse.e4.ui.services.ContextServiceAddon"
contributionURI="bundleclass://org.eclipse.e4.ui.bindings/org.eclipse.e4.ui.bindings.BindingServiceAddon"
contributionURI="bundleclass://org.eclipse.e4.ui.workbench/org.eclipse.e4.ui.internal.workbench.addons.CommandProcessingAddon"
contributionURI="bundleclass://org.eclipse.e4.ui.workbench/org.eclipse.e4.ui.internal.workbench.addons.HandlerProcessingAddon"
contributionURI="bundleclass://org.eclipse.e4.ui.workbench/org.eclipse.e4.ui.internal.workbench.addons.ContextProcessingAddon"
contributionURI="bundleclass://org.eclipse.e4.ui.workbench.swt/org.eclipse.e4.ui.workbench.swt.util.BindingProcessingAddon"
and my required plugins are:
org.eclipse.osgi,
org.eclipse.e4.ui.workbench,
org.eclipse.e4.core.contexts,
org.eclipse.e4.core.services,
org.eclipse.jface,
org.eclipse.e4.ui.workbench.swt,
org.eclipse.e4.ui.model.workbench,
org.eclipse.e4.ui.di,
org.eclipse.e4.core.di;bundle-version="1.3.0",
org.eclipse.core.runtime;bundle-version="3.9.100",
org.eclipse.equinox.p2.core;bundle-version="2.3.0",
org.eclipse.equinox.p2.engine;bundle-version="2.3.0",
org.eclipse.equinox.p2.metadata;bundle-version="2.2.0",
org.eclipse.equinox.p2.operations;bundle-version="2.3.0",
org.eclipse.equinox.p2.repository;bundle-version="2.3.0",
org.eclipse.e4.ui.services;bundle-version="1.0.1"
I spent already more then two evenings on it but still cannot figure it out.
Does anyone have any suggestions?
Thank you very much,
Martin
[Updated on: Tue, 04 March 2014 16:30] by Moderator
| Re: key binding in e4 RCP application [message #1267065 is a reply to message #1264578] |
Sat, 08 March 2014 06:31  |
yeah, unfortunately there are no log records. I tried to debug the method defineBindingTables and binding table with id "cz.martinbayer.e4.analyser.bindingtable.dialogAndWindow" which I created for "org.eclipse.ui.contexts.dialogAndWindow" context is correctly processed.
Thank you very much for this debugging tip bud would you have any other suggestions? Do you need any other information?
Martin
FUDForum. Page generated in 0.03613 seconds
