Home » Eclipse Projects » Dash » Selected Resource
Selected Resource [message #1687] Tue, 07 November 2006 09:45 Go to next message
Is it possible to get the selected file in a dash script
Is it also possible to create a new file ?
Re: Selected Resource [message #1695 is a reply to message #1687] Wed, 08 November 2006 20:57 Go to previous messageGo to next message
Sure - anything you can do in Java you can do in Monkey.
--- Came wiffling through the eclipsey wood ---
* Menu: Selected File
* Kudos: Bjorn Freeman-Benson
* License: EPL 1.0
* DOM: http://download.eclipse.org/technology/das\
h/update/org.eclipse.dash.doms
function main() {
selection = window.getSelectionService().getSelect\
ion().getFirstElement();
Packages.org.eclipse.jface.dialogs.MessageDialog.o\
penInformation(
window.getShell(),
"Monkey Dialog",
selection.toString()
--- And burbled as it ran! ---
and
* Menu: IO > File Sample
* Kudos: Paul Colton, Aptana, Inc.
* License: EPL 1.0
function main()
var date = new Date();
// Write out new file
var file = new File("myFile.txt");
file.createNewFile();
file.write("Date: " + date);
// Read lines from file
var text = file.readLines();
// Display what we read
Packages.org.eclipse.jface.dialogs.MessageDialog.\
openInformation(
window.getShell(),
"File I/O",
"Contents: " + text
Re: Selected Resource [message #2731 is a reply to message #1695] Tue, 14 November 2006 11:00 Go to previous message
if i try to run that i get serveral errors
"TypeError: getFirstElement is not a funciton
"Error File is not defined
> * License: EPL 1.0
> function main() {
> penInformation(
> window.getShell(),
> "Monkey Dialog",
> and
> * License: EPL 1.0
> function main()
> openInformation(
> window.getShell(),
> "File I/O",
> "Contents: " + text
Re: Selected Resource [message #560418 is a reply to message #1687] Wed, 08 November 2006 20:57 Go to previous message
* License: EPL 1.0
function main() {
penInformation(
window.getShell(),
"Monkey Dialog",
and
* License: EPL 1.0
function main()
openInformation(
window.getShell(),
"File I/O",
"Contents: " + text
Re: Selected Resource [message #560426 is a reply to message #1695] Tue, 14 November 2006 11:00 Go to previous message
> * License: EPL 1.0
> function main() {
> penInformation(
> window.getShell(),
> "Monkey Dialog",
> and
> * License: EPL 1.0
> function main()
> openInformation(
> window.getShell(),
> "File I/O",
> "Contents: " + text
Previous Topic:Selected Resource
Next Topic:Still here?
Current Time: Thu Nov 06 23:40:41 EST 2025
Powered by FUDForum. Page generated in 0.87093 seconds
