Re: ECP Views Extension [message #1262080 is a reply to message #1262036] |
Mon, 03 March 2014 08:39 |
Jonas Helming Messages: 699 Registered: July 2009 |
OK, sorry for the confusion, I meant an e4 or an e3 application :-)
In this case, I would recommend to create your own custom application,
with your own Application model. This way, you can customize and modify
all context menus as you wish. The application ECP provides is meant as
a demo application. It is possible to based your own application on
this, but you gain more flexibility, if you have an own one and the
application itself is not much work, so the benefit of reusing it is not
big.
I therefore would recommend to have a look at the sources of the
existing demo application and create your own based on this template.
Best Regards
Jonas
Am 03.03.2014 08:37, schrieb Hammad A:
> hi Jonas,
> I am planning to create an e4 application.
> Regards
FUDForum. Page generated in 0.05803 seconds
