Re: How to initiate validation of a SSE StructuredDocument [message #208435 is a reply to message #208354] |
Mon, 11 February 2008 15:25 |
Gerry Kessler wrote:
> I have a quick fix proposal that will fix an EL problem by creating a
> variable outside of the current source viewer. This means that the
> proposal won't update the current text region to become dirty, and
> therefore won't re-validate automatically.
> Ideally I would like to validate only the current region, but in some
> cases I may want to re-validate the entire document. I want to do this
> when the proposal is applied.
> Is there API to initiate validation of a SSE StructuredDocument or a
> region within?
Gerry,
You'll want to look up the org.eclipse.wst.sse.ui.sourcevalidation
extension point and the
org.eclipse.wst.sse.ui.internal.reconcile.validator.ISourceV alidator
interface (which will at least be moved into sse.core at some point).
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: How to initiate validation of a SSE StructuredDocument [message #208567 is a reply to message #208465] |
Wed, 13 February 2008 03:14 |
> Nitin,
> Maybe I wasn't quite clear, or maybe I am missing something. We already
> have a source validator. During validation, we are attaching an
> IQuickFixProcessor using message.setAttribute in the prescribed manner
> of https://bugs.eclipse.org/bugs/show_bug.cgi?id=170988.
> The issue here is that the source will not change after applying this
> particular proposal, so a validation will not re-fire automatically.
> How can I cause a re-validation event?
There's no direct way of causing this, much less a supported one. I
suppose the only thing you could do as a workaround is to replace
the text spanning the annotation's offset and length with the same
text, forcing the document event to be generated and the area to be
revalidated.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
_
Nitin Dahyabhai
Re: How to initiate validation of a SSE StructuredDocument [message #208620 is a reply to message #208611] |
Thu, 14 February 2008 22:24 |
Cameron Bateman wrote:
> What about using this new validation framework object?
> Validator[] validators = ValidationFramework.getValidatorsFor(...).
> for (Validator validator : validators)
> { validator.validate(...);
There's a catch in that the output from those validators would need
to be rerouted to create text Annotations (they make the squiggles),
something that's only done by the editor's internals.
Nitin Dahyabhai
IBM Rational
_
Nitin Dahyabhai
FUDForum. Page generated in 0.03360 seconds
