Home » Newcomers » Newcomers » Build issue with static libraries(Eclipse Build issue with unresolved library fucntions)
Build issue with static libraries [message #1259954] Fri, 28 February 2014 19:16 Go to next message
First let me say I can build my project using the same Linaro GCC eabi tools chain without this issue, when invoking the build process from the command line. Also I should mention that libraries are static libraries.
My issue is when I try to build from within Eclipse ( using external Linaro GCC non-linux) for some reason the linker reports undefined procedure library names (symbols). The procedures that are giving me issues are called from another library, I do have the link order correct and set the same as when I build outside of eclipse. I even went so far as to use --start-group with --end-group options for both of the dependent libraries still no luck.
What I eventually had to do was add the linker option --whole-archive when I build from Eclipse, but this is not required when I build the project from the command line make.
Does Someone understand why I need to do this?
It took 2.5 days to figure out this solution.
Re: Build issue with static libraries [message #1260251 is a reply to message #1259954] Sat, 01 March 2014 03:24 Go to previous messageGo to next message
Michael,
It's best to ask CDT questions on the specialized CDT forum.
> libraries.
Re: Build issue with static libraries [message #1260759 is a reply to message #1260251] Sat, 01 March 2014 16:54 Go to previous message
Ed thanks didn't know there was a CDT forum I'll repost there.
Previous Topic:unresolved inclusions
Next Topic:LTTng Integration with Eclipse
Current Time: Mon Nov 03 04:55:40 EST 2025
Powered by FUDForum. Page generated in 0.07598 seconds
