Home » Eclipse Projects » Eclipse Platform » Using own classloader for plugin
| Using own classloader for plugin [message #207828] |
Tue, 09 March 2004 06:26  |
Originally posted by: mremme.braintags.de
Hi all,
i am creating a plugin where i need to use an own classloader. Is it
possible to define the classloader to be used inside the plugin.xml as
extension point for the complete Plugin?
tia, Michael
| Re: Using own classloader for plugin [message #207951 is a reply to message #207881] |
Tue, 09 March 2004 09:54   |
Thank you for reply. The thing is the following:
I am building a plugin, where used classes are not all placed inside the
local classpath. Part of classes are coming from an own server. Those
classes are buildt by a factory, thus, additionally, i don't know them
complete, only the interfaces / abstracts from a framework.
For this i need to add an own classloader, which is able to find the
needed classes.
So far no problem, but since the local classes are loaded by the standard
plugin classloader, which does not know about the network classloader, i
am running into a ClassNotFoundException as soon as i am trying to load a
class, which was loaded by the plugin classloader and which is using
another class, which is stored on the server.
At that time i am starting to build a forced loader, which is using
resources from local files and is using defineClass to build the class and
will see, how this will run.
But the simply best solution would be if i could load the plugin class
already under my own classloader.
Michael
Igor Fedorenko wrote:
> No, there is no such extension point. What exactly do you need this
> classloader for? I might give you some ideas, but I need to understand
> your problem better.
> Remme wrote:
> > Hi all,
> > tia, Michael
| Re: Using own classloader for plugin [message #208319 is a reply to message #207951] |
Tue, 09 March 2004 19:45   |
> needed classes.
How do you get instances of the server provided classes? Do you use JNDI
lookup or you have your own factory that knows classnames to be
instantiated and calls Class.forName? How would your code and JVM's
classpath look like if it did not run inside Eclipse?
For JNDI to work you need to set your network classloader as thread
context classloader before calling context.lookup.
For the factory to work, you need to make sure that it uses your network
classloader to load classes by name. This may be little bit clumsy, but
should work.
> Michael
>>Remme wrote:
>>>Hi all,
>>>tia, Michael
| Re: Using own classloader for plugin [message #208467 is a reply to message #207951] |
Tue, 09 March 2004 23:51   |
Originally posted by: pascal.ibm.canada
If you are targeting eclipse 3.0, did you look at trying to create a new
plugin dynamically and dynamically install it once you know the classes?
There is also another example of interesting usage of classloader in the
ant.core plugin which run apps using external jars.
PaScaL
> needed classes.
> Michael
>>Remme wrote:
>>>Hi all,
>>>tia, Michael
| Re: Using own classloader for plugin [message #208869 is a reply to message #208319] |
Wed, 10 March 2004 11:28   |
>> needed classes.
> should work.
I am using a complete own format, where the server is deciding, which class
implementation is used and sends this class back if needed.
But the mistake i made was before, i think, because i tried to make a very
clumsy solution, where parent- and new ClassLoader are connecting partially
to the same repositories.
I have to restyle the plugin now first, so that i can make a solution, where
the plugin itself is working with interfaces only and something like a
bridge as own jar is loaded by the other classloader.
If i am finished with that and still desparating, then i would like to come
back again :-)
Thank you very much,
Michael
>> and will see, how this will run.
>> Michael
>>>Remme wrote:
>>>>Hi all,
>>>>tia, Michael
| Re: Using own classloader for plugin [message #213907 is a reply to message #207951] |
Sat, 20 March 2004 02:39  |
When I need to load classes that I don't have installed with the plugin
I simply
instantiate a URLClassLoader - and it works perfectly.
Genady
>needed classes.
>Michael
>>Remme wrote:
>>>Hi all,
>>>tia, Michael
Genady Beryozkin
http://www.genady.net/
Current Time: Wed Nov 05 20:14:42 EST 2025
Powered by FUDForum. Page generated in 0.31852 seconds
