How to start jboss4.2.2GA in eclipse [message #207257] |
Sat, 19 January 2008 09:30  |
Originally posted by: 3309696.gmail.com
when I start jboss4.2.2ga,the eclipse shows " Timeout waiting for
JBOSS 4.2 to start. Server did not start after 50s."
how to slove this problem.thank you
Re: How to start jboss4.2.2GA in eclipse [message #207259 is a reply to message #207258] |
Sat, 19 January 2008 22:08   |
kiril mitov 写道:
> When jboss is starting its output is redirected to the eclipse console.
> Can you check whether there are some exceptions or errors in this output?
> Best Regards,
> Kiril
I didn't see any exceptions or error which shows in eclipse console.I
can start jboss in netbean.when the eclipse shows "timeout waiting for
jboss 4.2 to start.server did not start after 50s",the eclipse console
shows:
" 11:00:13,497 INFO [Server] Starting JBoss (MX MicroKernel)...
11:00:13,507 INFO [Server] Release ID: JBoss [Trinity] 4.2.2.GA (build:
SVNTag=JBoss_4_2_2_GA date=200710221139)
11:00:13,537 INFO [Server] Home Dir: C:\jboss4.2.2.GA
11:00:13,537 INFO [Server] Home URL: file:/C:/jboss4.2.2.GA/
11:00:13,537 INFO [Server] Patch URL: null
11:00:13,537 INFO [Server] Server Name: default
11:00:13,537 INFO [Server] Server Home Dir: C:\jboss4.2.2.GA\server\default
11:00:13,537 INFO [Server] Server Home URL:
file:/C:/jboss4.2.2.GA/server/default/
11:00:13,537 INFO [Server] Server Log Dir:
C:\jboss4.2.2.GA\server\default\log
11:00:13,537 INFO [Server] Server Temp Dir:
C:\jboss4.2.2.GA\server\default\tmp
11:00:13,547 INFO [Server] Root Deployment Filename: jboss-service.xml
11:00:19,516 INFO [ServerInfo] Java version: 1.6.0_03,Sun Microsystems Inc.
11:00:19,516 INFO [ServerInfo] Java VM: Java HotSpot(TM) Client VM
1.6.0_03-b05,Sun Microsystems Inc.
11:00:19,516 INFO [ServerInfo] OS-System: Windows XP 5.1,x86
11:00:22,560 INFO [Server] Core system initialized
11:00:32,284 INFO [WebService] Using RMI server codebase:
http://127.0.0.1:8083/
11:00:32,294 INFO [Log4jService$URLWatchTimerTask] Configuring from
URL: resource:jboss-log4j.xml"
where is the problem?thank you
Re: How to start jboss4.2.2GA in eclipse [message #207452 is a reply to message #207447] |
Fri, 25 January 2008 04:19  |
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi Kiril,
well, at least I was consistently wrong ;-). That's better than being right
once, and being wrong the next time.
Wolfgang
kiril mitov schrieb:
> Hi Wolfgang,
> no offense but actually "Hello" is asking the question :)
> Best Regards,
> Kiril
FUDForum. Page generated in 0.04339 seconds
