Home » Modeling » Graphiti » org.eclipse.graphiti.features.impl.AbstractFeatureProvider.getPictogramElementForBusinessObject(Obje
org.eclipse.graphiti.features.impl.AbstractFeatureProvider.getPictogramElementForBusinessObject(Obje [message #1256609] Tue, 25 February 2014 11:03 Go to next message
Hi all,
I am having a little conceptual problem with the above method (Graphit 0.9).
Its body is
if (businessObject instanceof EObject) {
			Diagram diagram = getDiagramTypeProvider().getDiagram();
			if (diagram != null) {
				Collection<PictogramLink> pictogramLinks = diagram.getPictogramLinks();
				for (PictogramLink pictogramLink : pictogramLinks) {
					List<EObject> businessObjects = pictogramLink.getBusinessObjects();
					for (EObject obj : businessObjects) {
						if (getDiagramTypeProvider().getCurrentToolBehaviorProvider().equalsBusinessObjects(businessObject, obj)) {
							PictogramElement pe = pictogramLink.getPictogramElement();
							if (pe != null) {
								result = pe;
							break;
					if (result != null) {
						break;
Doesn't tha mean that it will find only Business Objects linked to the diagram? Is that intended?
Re: org.eclipse.graphiti.features.impl.AbstractFeatureProvider.getPictogramElementForBusinessObject( [message #1258654 is a reply to message #1256609] Thu, 27 February 2014 10:59 Go to previous messageGo to next message
Andreas,
no, it does not mean that.
I guess what you are concerned about is the line Collection<PictogramLink>
pictogramLinks = diagram.getPictogramLinks();. The links are stored in a
special diagram links association directly on diagram level not on the
individual shapes. It's designed as one list containing all links for a
diagram, one link again has references to a shape and a domain object.
Michael
Re: org.eclipse.graphiti.features.impl.AbstractFeatureProvider.getPictogramElementForBusinessObject( [message #1258843 is a reply to message #1258654] Thu, 27 February 2014 15:32 Go to previous messageGo to next message
Hi Michael,
in our diagrams, this section is quite empty (1 entry), though we do have a lot of links. They are directly stored at the pictogram elements.
e.g. org.eclipse.graphiti.internal.services.impl.LinkServiceImpl.getLinkForPictogramElement(PictogramElement) does access the getLink() of the PictogramElement and not of the link section? I am not quite understanding how they are related?
Best Regards,
Andreas
Re: org.eclipse.graphiti.features.impl.AbstractFeatureProvider.getPictogramElementForBusinessObject( [message #1410371 is a reply to message #1258843] Wed, 20 August 2014 11:17 Go to previous messageGo to next message
I'm having a problem with this method as well.
One of our business object <A> includes a containment reference to an EMF object <B>; which contributes 2 attributes to its container <A>. When any of those 2 attributes are changed, the getAllPictogramElementsForBusinessObject() method is called with object <B> as a parameter. However, since <B> is contained by <A> so pictogramLink.getBusinessObjects() only returns <A> and hence getDiagramTypeProvider().getCurrentToolBehaviorProvider().equalsBusinessObjects(businessObject, obj) is never equal.
Is there workaround to handle containment reference as business object with Graphiti?
Or, do I need to override the getAllPictogramElementsForBusinessObject() method and handle this case scenario myself?
Re: org.eclipse.graphiti.features.impl.AbstractFeatureProvider.getPictogramElementForBusinessObject( [message #1412941 is a reply to message #1410371] Wed, 27 August 2014 07:56 Go to previous message
Overriding getAllPictogramElementsForBusinessObject() would be an option,
but maybe also implementing your own logic for that object comparision in
equalsBusinessObjects() in your tool behavior provider would b e sufficient
as well.
Michael
Previous Topic:Creating Graphiti based plugin project
Next Topic:Connection Decorator with Text
Current Time: Wed Sep 10 05:30:10 EDT 2025
Powered by FUDForum. Page generated in 0.05314 seconds
