Home » Language IDEs » Java Development Tools (JDT) » remote debugging trying to clean output folder
remote debugging trying to clean output folder [message #207034] Thu, 16 June 2005 23:08 Go to next message
When launing a remote debugging, eclipse tries to clean output folder. I
see a message saying "trying to clean output folders." Does eclispe try
to clean output folders and build again?
Anand
Re: remote debugging trying to clean output folder [message #207128 is a reply to message #207034] Fri, 17 June 2005 09:11 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Only if it thinks it needs to build and an incremental build is not
sufficient.
Rich Kulp
Re: remote debugging trying to clean output folder [message #207166 is a reply to message #207128] Fri, 17 June 2005 15:37 Go to previous messageGo to next message
But I have "Automatic Build" turned off. Also I have disabled "Java
Builder" off. I do not want eclipse to build it. We use make to build
our sources. Is there a way to tell eclipse not to try to build the
sources. When I create a launcher for debuggig, there is an option for
turning off build before launch. I don't see similar option for remote
debugging.
Anand
> sufficient.
Re: remote debugging trying to clean output folder [message #207172 is a reply to message #207166] Fri, 17 June 2005 15:45 Go to previous messageGo to next message
In Preferences/Run-Debug/Launching there is a preference to build before
launching which is on by default. Have you turned it off?
Kevin
> debugging.
> Anand
>> sufficient.
Re: remote debugging trying to clean output folder [message #207178 is a reply to message #207172] Fri, 17 June 2005 17:26 Go to previous message
No. I had turned off the build in the project.
When I turn off the debug preferences, it works fine.
Anand
> Kevin
>> debugging.
>> Anand
>>> sufficient.
Previous Topic:unneeded class modifiers
Next Topic:What event is sent when clicking into some column-header of a TableViewer?
Current Time: Mon Nov 03 19:06:47 EST 2025
Powered by FUDForum. Page generated in 0.04192 seconds
