Re: Force refresh not working for me [message #1255468 is a reply to message #1254927] |
Mon, 24 February 2014 13:20 |
Hi Micheal,
Can you provide to us a sample project that illustrates your issue or at
least the conditional style expressions used in your layer to customize
your elements colors?
A possible explanation I see is that your external XMI Resource is
loaded in an other resource set than the one used by Sirius to load the
model and the *aird resource.
Florian
On 24/02/2014 01:18, Michael Lukaszczyk wrote:
> Hey there,
> I created an emf tools extension which evaluates a model and
> automatically splits model elements into different groups (groupFoo,
> groupBar for example). Now I have a layer that shows the model elements
> in different colors. groupFoo in red, groupBar in blue etc... . This all
> happens with the help of external XML files. Theres no group information
> within the model. So the model is completely decoupled from this
> information. Now I defined a tool in my vsp that calls a wizard by
> clicking on a model element where the user can manually select another
> group for an element in case the splitting algorithm got it wrong. After
> finishing the XML file gets rewritten. I activated "force refresh" for
> the tool by clicking the checkBox. The problem is, that the colors don´t
> change in the diagram. I have to right click on the canvas and hit
> refresh again or deactivate and activate the color layer again. Is there
> a chance that I can invoke this kind of "hard" refresh after the wizard
> closed?
> thanks,
> Michael
Re: Force refresh not working for me [message #1266354 is a reply to message #1266141] |
Fri, 07 March 2014 10:29 |
Hey Michael,
Because your external resource is outside the session editing domain,
Sirius do not detect modifications.
If you can't integrate this resource in the session semantic resources,
you can execute a RefreshRepresentationsCommand
(org.eclipse.sirius.business.api.dialect.command.RefreshRepresentationsCommand).
This command is called when you perform a manual refresh on the diagram.
Florian
On 07/03/2014 03:37, Michael Lukaszczyk wrote:
> Hey Florian,
> thanks for the reply and sorry for the late response. As I mentioned, I
> am not touching the XMI resource. The splitting information is
> completely decoupled from the model information so the model elements
> don´t keep any information about the splitting groups or colors. The
> information for this is in an external XML file. So the diagram does not
> refresh after I started my service. After a manual refresh of the
> diagram the data renders fine. What I want is to fire up a complete
> diagram refresh at the end of my external java service. I found
> something like a
> org.eclipse.sirius.diagram.part.SiriusDiagramUpdateCommand Handler. But
> I´m not sure if this is the handler I need and whats the best way to
> call it. I would be happy if you could help me out.
> Michael
Re: Force refresh not working for me [message #1268990 is a reply to message #1268807] |
Tue, 11 March 2014 08:40 |
Hi Michael,
You should call the command explicitly as it's done within this Sirius
private method:
org.eclipse.sirius.diagram.tools.internal.actions.refresh.RefreshRunnableWithProgress.refreshFromDiagramEditPart(IDDiagramEditPart,
IprogressMonitor
TransactionalEditingDomain domain =
TransactionUtil.getEditingDomain(dDiagram);
domain.getCommandStack().execute(new
RefreshRepresentationsCommand(domain, new
SubProgressMonitor(progressMonitor, 1), dDiagram));
regards,
Florian
On 11/03/2014 03:12, Michael Lukaszczyk wrote:
> Thanks! But could you provide an explanation on how to call this command
> programmatically? I tried it with this (
> http://devblog.virtage.com/2012/09/snippet-of-the-day-execute-eclipse-command-programmatically/
> ) snippet but it says: Trying to execute a command that is not defined.
> org.eclipse.sirius.business.api.dialect.command.RefreshRepresentationsCommand.
> I thought that this command is already defined by sirius and I could use
> it out of the box. But this doesn´t seem to be the case. Whats missing?
FUDForum. Page generated in 0.03264 seconds
