xDoclet and oc4j task [message #206627] |
Fri, 11 January 2008 12:55 |
Originally posted by: conrad.crampton.kent.pnn.police.uk
I am new to xdoclet but having followed a couple of tutorials etc. have
managed to get somewhere with creating session ejb using the xdoclet
wizard but have come across a problem generating the app server specific
deployment descriptor. In this case oc4j. The xdoclet docs list that there
is an oc4j specific task (with appropriate xdoclet tags too), but when I
go to the ejbdoclet setting in the project properties there is no oc4j
listed so I can't select it as a task to run when I run xdoclet from
within Eclipse.
There is an autogenerated build.xml file that is created before the
xdoclet task runs that appears to take the tasks from the ejbdoclet config
window but manually editing this doesn't work as it gets overwritten on
each compilation.
So the question is, how do I add oc4j task option to the ejbdoclet config
window?
Many thanks in advance
Conrad
FUDForum. Page generated in 0.03290 seconds
