| Home » Language IDEs » ServerTools (WTP) » What configuration option determines whether the Tomcat server uses a separate instance or the insta
 Goto Forum:|
| What configuration option determines whether the Tomcat server uses a separate instance or the insta [message #206589] | Thu, 10 January 2008 12:31  |  |
| Eclipse User  |  |  |  |  | Hi. I am trying to decode a paragraph in http://wiki.eclipse.org/WTP_Tomcat_FAQ
 and I would appreciate your help.  Here is the paragraph:
 separate instance or the instance from the Tomcat installation?
 The Run modules directly from the workspace (do not modify the Tomcat
 installation) checkbox of the server editor controls this option. It is
 found in the General section of the Overview view. If checked, a
 separate instance is used. If not checked, the instance from the Tomcat
 installation is used. The default is checked. It is best to change this
 option immediately after creating the server, or at least while no
 projects have been added to the server.
 So far this is what I have: (reordered to make sense to me)
 MEANS
 How to launch Tomcat using the configuration files in the Tomcat
 directory tree rather than the eclipse-internal server configuration files?
 It is best to change this option immediately after creating the
 server, or at least while no projects have been added to the server.
 MEANS
 First delete any server-configuration objects associated with the
 project you want to launch (Servers-><The config>->Delete). Next create
 a new server-configuration
 (Server->New->Other->Server->Apache->Next->Add<your project>).
 MEANS
 ?? Any idea what this means? Where in the UI is this stuff?
 If checked, a separate instance is used. If not checked, the instance
 from the Tomcat installation is used. The default is checked.
 MEANS
 If checked, the launched Tomcat will be configured with files created by
 eclipse in its .metadata directory and the Tomcat directory files will
 be untouched. If not checked, Tomcat will be configured with files in
 the Tomcat directory tree and editing these config files will change the
 Tomcat installation files.
 John
| Re: What configuration option determines whether the Tomcat server uses a separate instance or the i [message #206595 is a reply to message #206589] | Thu, 10 January 2008 13:28   |  |
| Eclipse User  |  |  |  |  | Sorry John, I'm still working on the update to this document that covers WTP 2.0.x.  The current contents were written for WTP 1.5.x.  Most of
 the document is still accurate for WTP 2.0.x, but this particular
 feature was enhanced in WTP 2.0.x, so the UI is now different.
 In the Server Locations section of the Tomcat server editor, the "Use
 workspace metadata..." option is equivalent to the "Run modules
 directly..." check box being checked.  The "Use Tomcat installation..."
 option is equivalent to the "Run modules directly..." check box being
 unchecked.  The "Use custom location..." option is new in WTP 2.0.x and
 wasn't available in WTP 1.5.x.
 Note the description string in the Server Locations section, which
 includes "Server must be published with no modules present to make
 changes".  Until this "state" is achieved, these options will be disabled.
 Additional comments below...
 > MEANS
 The "eclipse-internal server configuration files" (I assume you mean
 those in the subfolder(s) of the Servers project in your workspace.) are
 always used.  This is the reason for the "(takes control of Tomcat
 installation)" portion of the "Use Tomcat installation..." option.
 Those in the installation will be overwritten with copies from the
 Servers project each time the server is published within Eclipse.
 The selection you make in the Server Locations section affects the
 "separate instance" issue by controlling whether "CATATINA_BASE" ==
 "CATALINA_HOME" or "CATATINA_BASE" != "CATALINA_HOME".  Hopefully this
 is sufficiently explained in other parts of the FAQ.
 >  It is best to change this option immediately after creating the server,
 > MEANS
 This means that all projects should be removed from the server before
 changing this option, which is normally the state immediately after
 server creation.  As mentioned previously, in WTP 2.0.x you have to do
 this and publish the server before you can make changes.  In WTP 1.5.x,
 you could change it with projects added, but that would leave
 "artifacts" related to the old state of the option behind.  For example,
 stale work directories could get left behind that could cause undesired
 behavior if you later switched the option back.
 > MEANS
 It should have been the Server section for WTP 1.5.x.
 > MEANS
 As mentioned previously, the configuration files in the associated
 subfolder of the Servers project are always copied when publishing the
 server.  If using the "Use workspace metadata..." option (the default),
 those in your Tomcat installation remain intact.  With the "Use Tomcat
 installation..." option, they will get overwritten on each publish, so
 changes you make directly to the Tomcat installation's configuration
 could be short lived.
 Larry
 > John
| Re: What configuration option determines whether the Tomcat server uses a separate instance or the i [message #206603 is a reply to message #206589] | Thu, 10 January 2008 13:31   |  |
| Eclipse User  |  |  |  |  | Wait I got it: there is a hidden secret panel with the checkbox!
 > MEANS
 Go to the "Servers" view in eclipse, usually at the bottom. If you don't
 see it, use Window->ShowView->Servers.  Double click on the eclipse
 server-launcher you want to change. A new panel will appear in the
 editor box called "OverView", meaning "Tomcat Launch Configuration".
 Under "Server Locations", meaning "Location of Server Configuration
 Files", select "Use Tomcat Installation (takes control of Tomcat
 Installation)".  If the entries are grey, delete this eclipse
 server-launcher and create a new one.
| Re: What configuration option determines whether the Tomcat server uses a separate instance or the i [message #206611 is a reply to message #206603] | Thu, 10 January 2008 13:46  |  |
| Eclipse User  |  |  |  |  | John J Barton wrote: > Wait I got it: there is a hidden secret panel with the checkbox!
 >> is found in the General section of the Overview view. If checked, a
 >> Tomcat installation is used. The default is checked. It is best to
 >> change this option immediately after creating the server, or at least
 >> MEANS
 >> files?
 Or remove all projects from the server and publish.  This will enable
 the options.  Re-add the projects after the option is changed.
 Larry
 Current Time: Fri Oct 31 06:14:19 EDT 2025
 Powered by FUDForum . Page generated in 0.03975 seconds |
