| Re: creating a jet project [message #19993 is a reply to message #19896] | Tue, 05 June 2007 08:38   |  |
| Eclipse User  |  |  |  |  | This is a multi-part message in MIME format.
 ------=_NextPart_000_000A_01C7A74C.EF670E10
 Content-Type: text/plain;
 charset="iso-8859-1"
 Alexandre:
 You need to install JET separately. You can download from the M2T (Model =
 to Text) site, you you can use the following update site:
 http://download.eclipse.org/modeling/m2t/updates/site.xml
 If you want pre-release builds of the upcoming JET release (Jun 30, =
 2007), you can use this update site:
 http://download.eclipse.org/modeling/m2t/updates/site-interi m.xml
 Paul
 "Ed Merks" <merks@ca.ibm.com> wrote in message =
 news:f43hd0$9f6$2@build.eclipse.org...
 Alexandre,
 Did you install JET2? =20
 http://www.eclipse.org/modeling/m2t/
 You should ask about JET2 on the M2T newsgroup, which I've added to =
 the "to" on my reply.
 Alexandre Jaquet wrote:=20
 I'm trying to follow this tutorial
 http://www-128..ibm.com/developerworks/java/library/os-ecl-j et/index.html=
 ?ca=3Ddrs
 but I doesn't found the wizard File > New > Other > EMFT JET =
 Transformations=20
 > EMFT JET Transformation Project
 I'm been runing emf 2.2.3 sdk.
 Any idea ?
 Alexandre=20
 =20
 Content-Type: text/html;
 <HTML><HEAD>
 <META content=3D"MSHTML 6.00.2900.3086" name=3DGENERATOR>
 <STYLE></STYLE>
 </HEAD>
 <DIV><FONT face=3DArial size=3D2>Alexandre:</FONT></DIV>
 <DIV><FONT face=3DArial size=3D2></FONT> </DIV>
 <DIV><FONT face=3DArial size=3D2>You need to install JET separately. You =
 can=20
 download from the M2T (Model to Text) site, you you can use the =
 following update=20
 site:</FONT></DIV>
 <DIV><FONT face=3DArial size=3D2><A=20
 href=3D"http://download.eclipse.org/modeling/m2t/updates/site.xml">http:/=
 /download.eclipse.org/modeling/m2t/updates/site.xml</A></FONT ></DIV>
 <DIV><FONT face=3DArial size=3D2>If you want pre-release builds of the =
 upcoming JET=20
 release (Jun 30, 2007), you can use this update site:</FONT></DIV>
 href=3D" http://download.eclipse.org/modeling/m2t/updates/site-interi m.xml=
 "> http://download.eclipse.org/modeling/m2t/updates/site-interi m.xml</A></=
 FONT></DIV>
 <DIV><FONT face=3DArial size=3D2>Paul</FONT></DIV>
 <BLOCKQUOTE=20
 <DIV>"Ed Merks" <<A =
 href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
 wrote in message <A=20
 href=3D"news:f43hd0$9f6$2@build.eclipse.org">news:f43hd0$9f6$2@build.ecli=
 pse.org</A>...</DIV>Alexandre,<BR><BR>Did=20
 you install JET2?  <BR>
 <BLOCKQUOTE><A=20
 href=3D"http://www.eclipse.org/modeling/m2t/">http://www.eclipse.org/mode=
 ling/m2t/</A><BR></BLOCKQUOTE>You=20
 should ask about JET2 on the M2T newsgroup, which I've added to the =
 "to" on my=20
 reply.<BR><BR><BR>Alexandre Jaquet wrote:=20
 <BLOCKQUOTE cite=3Dmid:f43dec$1f0$1@build.eclipse.org =
 type=3D"cite"><PRE wrap=3D"">I'm trying to follow this tutorial
 <A class=3Dmoz-txt-link-freetext =
 href=3D" http://www-128.ibm.com/developerworks/java/library/os-ecl-je t/ind=
 ex.html?ca=3Ddrs">http://www-128..ibm.com/developerworks/java/library/os-=
 ecl-jet/index.html?ca=3Ddrs</A>
 Transformations=20
 Any idea ?
 Alexandre=20
 </PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
 ------=_NextPart_000_000A_01C7A74C.EF670E10--
| Re: creating a jet project [message #20721 is a reply to message #19993] | Wed, 06 June 2007 03:11  |  |
| Eclipse User  |  |  |  |  | Originally posted by: alexjaquet.gmail.com
 ------=_NextPart_000_002E_01C7A81A.BAB022F0
 Thanks it's work fine now.
 Alexandre
 "Paul Elder" <pelder@ca.ibm.com> a =E9crit dans le message de news: =
 f43lho$o78$1@build.eclipse.org...
 Alexandre:
 You need to install JET separately. You can download from the M2T =
 (Model to Text) site, you you can use the following update site:
 Paul
 Alexandre,
 ?ca=3Ddrs
 Transformations=20
 Any idea ?
 Alexandre=20
 =20
 <HTML><HEAD>
 <META content=3D"MSHTML 6.00.5730.11" name=3DGENERATOR>
 <STYLE></STYLE>
 </HEAD>
 <DIV><FONT face=3DArial size=3D2>Thanks it's work fine now.</FONT></DIV>
 <DIV><FONT face=3DArial size=3D2>Regards,</FONT></DIV>
 <DIV><FONT face=3DArial size=3D2>Alexandre</FONT></DIV>
 <BLOCKQUOTE dir=3Dltr=20
 <DIV>"Paul Elder" <<A=20
 href=3D"mailto:pelder@ca.ibm.com">pelder@ca.ibm.com</A>> a =E9crit =
 dans le=20
 message de news: <A=20
 href=3D"mailto:f43lho$o78$1@build.eclipse.org">f43lho$o78$1@build.eclipse=
 ..org</A>...</DIV>
 <DIV><FONT face=3DArial size=3D2>You need to install JET separately. =
 You can=20
 following=20
 upcoming=20
 JET release (Jun 30, 2007), you can use this update site:</FONT></DIV>
 FONT></DIV>
 <BLOCKQUOTE=20
 <DIV>"Ed Merks" <<A=20
 href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>> wrote in =
 message <A=20
 <BLOCKQUOTE><A=20
 "to" on=20
 my reply.<BR><BR><BR>Alexandre Jaquet wrote:=20
 Transformations=20
 Any idea ?
 Alexandre=20
 </PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BLOCKQUOTE></BODY ></HTML>
 ------=_NextPart_000_002E_01C7A81A.BAB022F0--
FUDForum. Page generated in 0.25669 seconds
