Home » Modeling » GMF (Graphical Modeling Framework) » Changing Link Arrows
Changing Link Arrows [message #206388] Tue, 23 September 2008 01:11 Go to next message
Originally posted by: nuclearpsyche.gmail.com
Let's suppose I have Link objects with a boolean property called
"bidirectional".
I want the link on the diagram to show arrows on both sides of the line
when that property==true and only an arrow on one side if
bidirectional==false.
Is there a way to do that assuming I have a property sheet that allows
changing the boolean value?
Thank you!
tamer
Re: Changing Link Arrows [message #206474 is a reply to message #206388] Tue, 23 September 2008 05:30 Go to previous messageGo to next message
Hello Tamer,
You have to create two different link mappings with appropriate costraints
(bidirectional/not bidirectional) + listen to this property and call diagram
updater to replace existing link with new one on changing this property from
properties view.
Alex Shatalin
Re: Changing Link Arrows [message #206506 is a reply to message #206388] Tue, 23 September 2008 06:08 Go to previous messageGo to next message
Originally posted by: tobk42.gmx.de
In addition to Alex' sugestion -- which surely is more in the sense of
model driven engineering -- it is also possible to do some changes in
the code, which might have advantages depending on the number of
settings for a link or a node (and the possible combinations thereof).
Add a method setBidirectional(boolean) to your link's figure (normally
found in the link's edit part), adding/removing the link's second
decoration (see the code for the first decoration, to find out how to do
this). Now you have to implement the link edit part's notifyChanged
method, testing notification.getFeatureID(YourPackage.class) and calling
the setBidirectional method followed by calling refreshVisuals() on the
right feature ID.
Finally, don't forget to mark both methods "@generated NOT", so they
will not be overwritten on the next code generation.
Tobias
Tamer schrieb:
> Hello,
> "bidirectional".
> Thank you!
> tamer
Re: Changing Link Arrows [message #206537 is a reply to message #206506] Tue, 23 September 2008 06:38 Go to previous messageGo to next message
Hello tobias,
Good point. Another way to implement alternative view mapping is to modify
generated code and sometimes it can be even more simple then my original
suggestion. :-)
Alex Shatalin
Re: Changing Link Arrows [message #206868 is a reply to message #206474] Wed, 24 September 2008 10:25 Go to previous messageGo to next message
Alex,
Thank you for you suggestion!
tamer
Alex Shatalin wrote:
> Hello Tamer,
> costraints (bidirectional/not bidirectional) + listen to this property
> and call diagram updater to replace existing link with new one on
> changing this property from properties view.
> Alex Shatalin
Re: Changing Link Arrows [message #206884 is a reply to message #206506] Wed, 24 September 2008 10:27 Go to previous message
Tobias,
Thank you! I will definitely try this out.
tamer
> right feature ID.
> Tobias
> Tamer schrieb:
>> Hello,
>> "bidirectional".
>> line when that property==true and only an arrow on one side if
>> Thank you!
>> tamer
Previous Topic:How to generate a link with multiple sources and targets
Next Topic:How can i get control of star mouse pointer drag?
Current Time: Sun Oct 19 19:33:18 EDT 2025
Powered by FUDForum. Page generated in 0.22984 seconds
