Home » Newcomers » Newcomers » anybody can pl solve this
anybody can pl solve this [message #205719] |
Wed, 18 April 2007 10:43  |
am trying to run a birt report which uses a DataSource, from stand alone
java class
then am getting the following error
org.eclipse.birt.report.model.elements.OdaDataSource.setIntr insicProperty(OdaDataSource.java:201)
org.eclipse.birt.report.model.core.DesignElement.setProperty (DesignElement.java:1192)
org.eclipse.birt.report.model.core.DesignElement.setProperty (DesignElement.java:1162)
org.eclipse.birt.report.model.parser.DesignParseState.setPro perty(DesignParseState.java:99)
org.eclipse.birt.report.model.parser.OdaDataSourceState.pars eODADataSourceExtensionID(OdaDataSourceState.java:178)
org.eclipse.birt.report.model.parser.OdaDataSourceState.pars eAttrs(OdaDataSourceState.java:82)
org.eclipse.birt.report.model.parser.ModuleParserHandler.sta rtElement(ModuleParserHandler.java:167)
at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unk nown Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanSt artElement(Unknown
Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$Fragme ntContentDispatcher.dispatch(Unknown
Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDo cument(Unknown
Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unk nown Source)
at org.apache.xerces.jaxp.SAXParserImpl.parse(Unknown Source)
org.eclipse.birt.report.model.parser.ModuleReader.readModule (ModuleReader.java:90)
org.eclipse.birt.report.model.parser.DesignReader.read(Desig nReader.java:90)
org.eclipse.birt.report.model.core.DesignSession.openDesign( DesignSession.java:278)
org.eclipse.birt.report.model.api.SessionHandle.openDesign(S essionHandle.java:291)
org.eclipse.birt.report.engine.parser.ReportParser.getDesign Handle(ReportParser.java:161)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:243)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:191)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:125)
org.eclipse.birt.report.engine.api.impl.ReportEngine.openRep ortDesign(ReportEngine.java:224)
at programs.FireReport.<init>(FireReport.java:51)
at programs.ExecuteReport.main(ExecuteReport.java:12)
Re: anybody can pl solve this [message #206641 is a reply to message #206130] |
Sun, 22 April 2007 04:44   |
i tryied in so many times but still am getting the same problem, so
below am giving the complete code
//FireReport.java
package programs;
import java.util.Calendar;
import java.util.GregorianCalendar;
import java.util.HashMap;
import java.util.logging.Level;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.HTMLRenderContext;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.IGetParameterDefinitionTa sk;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.eclipse.birt.report.engine.api.PDFRenderContext;
public class FireReport
public FireReport(String birtHome, String path, String repName, String
format, String paramValue)
try
Calendar calendar = new GregorianCalendar();
int month = calendar.get(Calendar.MONTH)+1;
String currTime = calendar.get(Calendar.YEAR)+
"-"+month+
"-"+calendar.get(Calendar.DATE)+"_"+
calendar.get(Calendar.HOUR_OF_DAY)+
"."+calendar.get(Calendar.MINUTE)+
"."+calendar.get(Calendar.SECOND);
// Configure the Engine and start the Platform
EngineConfig config = new EngineConfig();
config.setEngineHome(birtHome);
// set log config using ( null, Level ) if you do not want a
log file
config.setLogConfig(path+"logfiles", Level.FINE);
Platform.startup(config);
IReportEngineFactory factory = (IReportEngineFactory)Platform
createFactoryObject(IReportEngineFactory.EXTENSION_REPORT_EN GINE_FACTORY);
IReportEngine engine = factory.createReportEngine(config);
engine.changeLogLevel(Level.FINE);
IReportRunnable design =
engine.openReportDesign(path+repName+".rptdesign");
IGetParameterDefinitionTask paramTask =
engine.createGetParameterDefinitionTask(design);
//Create task to run the report and render the report
IRunAndRenderTask task =
engine.createRunAndRenderTask(design);
if (format.equalsIgnoreCase("html"))
//Set Render context to handle url and image locataions
HTMLRenderContext renderContext = new HTMLRenderContext();
renderContext.setImageDirectory("image");
HashMap contextMap = new HashMap();
contextMap.put(
EngineConstants.APPCONTEXT_HTML_RENDER_CONTEXT, renderContext );
task.setAppContext( contextMap );
//Set rendering options - such as file or stream output,
//output format, whether it is embeddable, etc
HTMLRenderOption options = new HTMLRenderOption();
//options.setOutputStream(System.out);
options.setOutputFileName(path+format+"/"+repName+"_"+currTime+ ".html");
options.setOutputFormat("html");
task.setRenderOption(options);
task.run();
if (format.equalsIgnoreCase("pdf"))
PDFRenderContext renderContext = new PDFRenderContext();
renderContext.setFontDirectory("font");
contextMap.put(
options.setOutputFileName(path+format+"/"+repName+"_"+currTime+ ".pdf");
options.setOutputFormat("pdf");
task.run();
catch( Exception ex)
//System.out.println(ex.getMessage());
ex.printStackTrace();
public static void main(String args[])
String birtHome = "D:/birtruntime/birt-runtime-2_2_0/ReportEngine";
String path = "D:/Workspace/WebReports/";
String repName = "NewDBSample";
//String format = "html";
new FireReport(birtHome, path, repName, "html","hello");
//new FireReport(birtHome, path, repName, "pdf","hello");
Re: anybody can pl solve this [message #206759 is a reply to message #206641] |
Mon, 23 April 2007 04:32   |
I ran your code and only made minimal changes in the main and the
following in your FireReport
To
Platform.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
and after the report is executed I close the task, destroy the engine
and shutdown the platform.
task.close();
engine.destroy();
Platform.shutdown();
BTW you are also opening a parameter task. I assume you will use it
later for something different, just remember to close task when finished
with them. You do not need a parameter task to set parameters on a
report though.
After those minimal changes your example worked fine.
Jason
> //FireReport.java
> package programs;
> public class FireReport {
> String format, String paramValue)
> try {
> "-"+month+
> log file
> render the report
> engine.createRunAndRenderTask(design); if
> contextMap.put(
> task.run();
> contextMap.put(
> task.run();
Re: anybody can pl solve this [message #206769 is a reply to message #206759] |
Mon, 23 April 2007 04:33  |
I used M6 and the following report.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.12"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.2.0.v20070403 Build <2.2.0.v20070406-0959></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2006 <<Your Company
Name here>></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="4">
<text-property name="displayName"></text-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="5">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<property name="queryText">select *
from orderdetails</property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="6">
<property name="width">100%</property>
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<expression
name="expression">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
</list-property>
<column id="35"/>
<column id="36"/>
<column id="37"/>
<column id="38"/>
<column id="39"/>
<header>
<row id="7">
<cell id="8">
<label id="9">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="10">
<label id="11">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="12">
<label id="13">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="14">
<label id="15">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="16">
<label id="17">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="18">
<cell id="19">
<data id="20">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="21">
<data id="22">
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="23">
<data id="24">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="25">
<data id="26">
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="27">
<data id="28">
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="29">
<cell id="30"/>
<cell id="31"/>
<cell id="32"/>
<cell id="33"/>
<cell id="34"/>
</row>
</footer>
</table>
</body>
</report>
> To
> task.close();
> engine.destroy();
> report though.
> Jason
>> //FireReport.java
>> package programs;
>> try {
>> "-"+month+
>> a log file
>> render the report
>> contextMap.put(
>> stream output, //output format, whether it is embeddable, etc
>> task.run();
>> contextMap.put(
>> task.run();
>> String birtHome =
Current Time: Thu Sep 25 13:39:52 EDT 2025
Powered by FUDForum. Page generated in 0.10030 seconds
