edit HTML file [message #205514] |
Sun, 09 December 2007 11:19 |
Originally posted by: nospam.noemail.com
i've just downloaded the latest version of eclipse to get use to it.
i've downloaded the WTP, PDT and SDK packages.
However, i'm not able to edit a simple HTML file which already exists.
automatically, when i double click on it, eclipse displays the result of
this html file.
none of the 4 "parametered editors" (system editor, default editor, ...)
open it (except text editor).
where is the problem ?
why can I not open it thanks standard eclipse editor (the same as i have
for js edition) ?
thx.
A.
Re: edit HTML file [message #205537 is a reply to message #205514] |
Mon, 10 December 2007 00:29 |
Originally posted by: dcarver.starstandard.org
Alain R. wrote:
> this html file.
> for js edition) ?
Make sure you are running Eclipse with at least a Java 1.5 runtime
environment. WTP requires 1.5 otherwise some features will be disabled.
Dave
Re: edit HTML file [message #205592 is a reply to message #205537] |
Tue, 11 December 2007 17:42 |
I have 1.6 installed and still have this issue :-(
David Carver wrote:
> Alain R. wrote:
>> Hi,
>> of this html file.
>> ...) open it (except text editor).
>> have for js edition) ?
> Dave
Re: edit HTML file [message #205599 is a reply to message #205592] |
Tue, 11 December 2007 18:34 |
Did you download all the pre-reqs. You can also download the PDT
All-In-One package which will make sure you have everything.
Dave
Re: edit HTML file [message #205607 is a reply to message #205599] |
Wed, 12 December 2007 07:00 |
i've downloaded the PDT all in one package in this purpose : to be sure
that i had everything needed :-(
> Dave
Re: edit HTML file [message #205614 is a reply to message #205592] |
Wed, 12 December 2007 08:20 |
Originally posted by: mauro.molinari.cardinis.com
You have 1.6 installed, but are you sure Eclipse is using it?
Try Help | About Eclipse Platform | Configuration details and search for
java.runtime.version property.
If it is not >1.5, try:
eclipse -vm <path to javaw.exe of JRE >1.5.x>
Hope this helps.
Mauro.
Re: edit HTML file [message #205630 is a reply to message #205607] |
Wed, 12 December 2007 15:42 |
> David Carver wrote:
Try JDK 1.5, PDT has said they don't support JDK 1.6, even though it
should work,
FUDForum. Page generated in 0.03757 seconds
