Re: [Teneo] How to get the audit history of a deleted entity? [message #1250415 is a reply to message #1249691] |
Wed, 19 February 2014 08:15 |
Hi Erdal,
Can you try the following:
- from the datastore get the AuditHandler
- then using the URI string as a parameter call: auditHandler.fromString(uriAsString)
- the auditreference has the entity name, id and timestamp, to get from the entityname to the eclass:
dataStore.getEntityNameStrategy().toEClass(entityName)
- then get the auditversionprovider from the datastore and call auditVersionProvider.getAuditEntry(eclass, id, timestamp)
This can clearly be made easier in the auditVersionProvider by having a method there getAuditEntry(String)... Can you
add a bugzilla and attach your working code on it?
gr. Martin
On 02/18/2014 03:22 PM, Erdal Karaca wrote:
> Hi Martin,
> When traversing the history of an entity I may encounter deleted entities for which I want to recursively obtain the
> history itself. At that point I have only the URI of it which has this format:
> http://www.eclipse.org/teneo/auditing#1392732431978;EntityName;java.lang.String;a4fa1673-cdb5-4b8f-8282-f7eefa475c8c
> How do I get the history of a deleted entity (using its URI)?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
FUDForum. Page generated in 0.03104 seconds
