Home » Eclipse Projects » DSDP - Target Management » Incompatible Host Server Error
Re: Incompatible Host Server Error [message #20062 is a reply to message #19983] |
Mon, 31 March 2008 15:22 |
Martin Oberhuber Messages: 1007 Registered: July 2009 |
Also, could you please file a bug for this. I find bugzilla
better to search and archive than the newsgroup.
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Target%2 0Management&version=unspecified&component=RSE
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
David McKnight wrote:
> Hi Asai,
> Could you tell me how you're running the Linux server? Are you running a
> daemon (via daemon.pl) or are you using the server directly? Could you show
> me the shell output that the server produces?
> Dave
> "Asai" <asai@globalchangemusic.org> wrote in message
> news:fsmbho$1ga$1@build.eclipse.org...
>> Hi All,
>> I'm working with RSE for the first time, and in trying to get the RSE
>> server up and running on my (Linux) server, I get a Incompatible Host
>> Server error when I try to connect from Eclipse. I have JRE "1.6.0_05"
>> installed, a hole in the firewall, and the proper listening ports
>> configured for connection.
>> I've tried running the 3.0 version, (up from the previous stable release)
>> but get the same error.
>> Any insights?
>> Thanks.
Re: Incompatible Host Server Error [message #20092 is a reply to message #19983] |
Mon, 31 March 2008 15:32 |
Asai Messages: 16 Registered: July 2009 |
Hi, David,
Thanks so much for your reply.
Here's the linux command line and the output:
[root@foo rseserver]# ./daemon.pl 4075 10001-10010
Daemon running on: foo.bar.net, port: 4075
launched new server on 10001
RECEIVER ERROR
java.lang.Exception: The connection to the server has been lost.
finished on port 10001
> Hi Asai,
> Dave
>> Hi All,
>> Any insights?
>> Thanks.
Re: Incompatible Host Server Error [message #20503 is a reply to message #20092] |
Mon, 31 March 2008 16:22 |
David McKnight Messages: 244 Registered: July 2009 |
Hi Asai,
I have not tried running the server with JRE 1.6 before. Does it make any
difference for you when using JRE 1.5 or 1.4?
news:fsr06q$aqs$1@build.eclipse.org...
> Hi, David,
> RECEIVER ERROR
>> Hi Asai,
>> show me the shell output that the server produces?
>> Thanks,
>> Dave
>>> Hi All,
>>> release) but get the same error.
>>> Any insights?
>>> Thanks.
Re: Incompatible Host Server Error [message #20509 is a reply to message #20062] |
Mon, 31 March 2008 16:23 |
I have submitted this in the bugzilla tracker.
> Cheers,
>> Hi Asai,
>> running a daemon (via daemon.pl) or are you using the server
>> directly? Could you show me the shell output that the server produces?
>> Thanks,
>> Dave
>>> Hi All,
>>> "1.6.0_05" installed, a hole in the firewall, and the proper
>>> listening ports configured for connection.
>>> Any insights?
>>> Thanks.
Re: Incompatible Host Server Error [message #20518 is a reply to message #20503] |
Mon, 31 March 2008 16:41 |
I will try this and let you know. Thanks.
> Hi Asai,
>> Hi, David,
>> RECEIVER ERROR
>>> Hi Asai,
>>> Thanks,
>>> Dave
>>>> Hi All,
>>>> Any insights?
>>>> Thanks.
Re: Incompatible Host Server Error [message #20526 is a reply to message #20503] |
Mon, 31 March 2008 17:08 |
Hi David,
I uninstalled ver 1.6 and put in 1.5, but still no dice. Same error.
> Hi Asai,
>> Hi, David,
>> RECEIVER ERROR
>>> Hi Asai,
>>> Thanks,
>>> Dave
>>>> Hi All,
>>>> Any insights?
>>>> Thanks.
Re: Incompatible Host Server Error [message #20535 is a reply to message #20526] |
Mon, 31 March 2008 17:21 |
Hi Asai,
Hmm.. I haven't seen this before.
As an experiment, could you try connecting to the server directly?
Steps:
1) start the server directly using server.sh
2) In RSE, go to the Server Launcher Settings property page for the file
subsystem and specify connect to running server.
3) On the Subsystem property page specify the port that the server you
started is running on.
news:fsr5qa$fto$1@build.eclipse.org...
> Hi David,
>> Hi Asai,
>> any difference for you when using JRE 1.5 or 1.4?
>>> Hi, David,
>>> RECEIVER ERROR
>>>> Hi Asai,
>>>> a daemon (via daemon.pl) or are you using the server directly? Could
>>>> Thanks,
>>>> Dave
>>>>> Hi All,
>>>>> "1.6.0_05" installed, a hole in the firewall, and the proper listening
>>>>> Any insights?
>>>>> Thanks.
Re: Incompatible Host Server Error [message #20545 is a reply to message #20535] |
Mon, 31 March 2008 17:36 |
Sure,
here's the result:
[root@foo rseserver]# ./server.pl
DStore Server Starting...
Server Started Successfully
4033
Server running on: foo.bar.net
RECEIVER ERROR
at
org.eclipse.dstore.internal.core.util.XMLparser.readLine(XML parser.java:363)
at
org.eclipse.dstore.internal.core.util.XMLparser.parseDocumen t(XMLparser.java:480)
at
org.eclipse.dstore.internal.core.util.Receiver.handleInput(R eceiver.java:117)
at
org.eclipse.dstore.internal.core.util.Receiver.run(Receiver. java:98)
Server Finished
> Hi Asai,
> Steps:
>> Hi David,
>>> Hi Asai,
>>>> Hi, David,
>>>> RECEIVER ERROR
>>>>> Hi Asai,
>>>>> Thanks,
>>>>> Dave
>>>>>> Hi All,
>>>>>> Any insights?
>>>>>> Thanks.
Re: Incompatible Host Server Error [message #20555 is a reply to message #20545] |
Mon, 31 March 2008 17:49 |
Okay, discussion of this will continue in:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=224934
news:fsr7fm$ue8$1@build.eclipse.org...
> Sure,
> here's the result:
> 4033
> RECEIVER ERROR
> at
> at
> at
> at
> Server Finished
>> Hi Asai,
>> Steps:
>> Thanks,
>>> Hi David,
>>>> Hi Asai,
>>>>> Hi, David,
>>>>> RECEIVER ERROR
>>>>>> Hi Asai,
>>>>>> produces?
>>>>>> Thanks,
>>>>>> Dave
>>>>>>> Hi All,
>>>>>>> RSE server up and running on my (Linux) server, I get a Incompatible
>>>>>>> Host Server error when I try to connect from Eclipse. I have JRE
>>>>>>> Any insights?
>>>>>>> Thanks.
Re: Incompatible Host Server Error [message #573288 is a reply to message #19983] |
> Hi Asai,
> Dave
>> Hi All,
>> Any insights?
>> Thanks.
Re: Incompatible Host Server Error [message #573318 is a reply to message #19983] |
Hi, David,
RECEIVER ERROR
> Hi Asai,
> Dave
>> Hi All,
>> Any insights?
>> Thanks.
Re: Incompatible Host Server Error [message #573382 is a reply to message #20092] |
Hi Asai,
> Hi, David,
> RECEIVER ERROR
>> Hi Asai,
>> Thanks,
>> Dave
>>> Hi All,
>>> Any insights?
>>> Thanks.
Re: Incompatible Host Server Error [message #573399 is a reply to message #20062] |
> Cheers,
>> Hi Asai,
>> Thanks,
>> Dave
>>> Hi All,
>>> Any insights?
>>> Thanks.
Re: Incompatible Host Server Error [message #573429 is a reply to message #20503] |
> Hi Asai,
>> Hi, David,
>> RECEIVER ERROR
>>> Hi Asai,
>>> Thanks,
>>> Dave
>>>> Hi All,
>>>> Any insights?
>>>> Thanks.
Re: Incompatible Host Server Error [message #573444 is a reply to message #20503] |
Hi David,
> Hi Asai,
>> Hi, David,
>> RECEIVER ERROR
>>> Hi Asai,
>>> Thanks,
>>> Dave
>>>> Hi All,
>>>> Any insights?
>>>> Thanks.
Re: Incompatible Host Server Error [message #573470 is a reply to message #20526] |
Hi Asai,
Steps:
> Hi David,
>> Hi Asai,
>>> Hi, David,
>>> RECEIVER ERROR
>>>> Hi Asai,
>>>> Thanks,
>>>> Dave
>>>>> Hi All,
>>>>> Any insights?
>>>>> Thanks.
Re: Incompatible Host Server Error [message #573497 is a reply to message #20535] |
Sure,
here's the result:
4033
RECEIVER ERROR
at
at
at
at
Server Finished
> Hi Asai,
> Steps:
>> Hi David,
>>> Hi Asai,
>>>> Hi, David,
>>>> RECEIVER ERROR
>>>>> Hi Asai,
>>>>> Thanks,
>>>>> Dave
>>>>>> Hi All,
>>>>>> Any insights?
>>>>>> Thanks.
Re: Incompatible Host Server Error [message #573518 is a reply to message #20545] |
> Sure,
> here's the result:
> 4033
> RECEIVER ERROR
> at
> at
> at
> at
> Server Finished
>> Hi Asai,
>> Steps:
>> Thanks,
>>> Hi David,
>>>> Hi Asai,
>>>>> Hi, David,
>>>>> RECEIVER ERROR
>>>>>> Hi Asai,
>>>>>> produces?
>>>>>> Thanks,
>>>>>> Dave
>>>>>>> Hi All,
>>>>>>> Any insights?
>>>>>>> Thanks.
Current Time: Sat Apr 27 02:37:02 GMT 2024
Powered by FUDForum. Page generated in 0.05765 seconds
