Home » Modeling » Papyrus » Create a diagram from an existing uml file
Create a diagram from an existing uml file [message #1249174] Mon, 17 February 2014 21:35 Go to next message
Reading https://wiki.eclipse.org/Papyrus_User_Guide, I should be getting a whole set of 'initialize' options when I right-click on a .uml file - but I'm not seeing it anywhere.
Perhaps the screenshot is outdated and the functionality was moved elsewhere?
Re: Create a diagram from an existing uml file [message #1249327 is a reply to message #1249174] Tue, 18 February 2014 01:11 Go to previous messageGo to next message
I should note that I'm working with Eclipse 3.7, Papyrus 0.8.2. Perhaps things have changed in this regard since.
Re: Create a diagram from an existing uml file [message #1249478 is a reply to message #1249327] Tue, 18 February 2014 04:39 Go to previous messageGo to next message
Some parts of the user guide have not been updated for a while.
On the current version (>= 0.8.x), you need to right click on a UML File, then select New > Other... > Papyrus Model
This will open the Papyrus Model wizard, but instead of creating a whole new model, it will only initialize the diagrams, and reuse the selected UML model.
Camille
Re: Create a diagram from an existing uml file [message #1250056 is a reply to message #1249478] Tue, 18 February 2014 17:44 Go to previous message
Got it, thanks.
Previous Topic:Showing applied profiles in package diagrams
Next Topic:How to unlink Papyrus from a UML model?
Current Time: Sat Nov 08 21:09:46 EST 2025
Powered by FUDForum. Page generated in 0.04271 seconds
