Home » Modeling » EMF » EditingSupport and EditingDomain
EditingSupport and EditingDomain [message #1248977] |
Mon, 17 February 2014 16:22  |
I have implemented a UI which shows various structural features of an underlying EMF model. There is a table viewer in this UI to be able to edit these features. After initializing the data binding based on EMF, I have implemented the cell editors for the table viewer's specific column that shows the values of the selected attributes.
I call this specific editing support class of mine, which overrides the getValue() and setValue() methods, from the view as follows:
tableViewerColumn.setEditingSupport(new MyEditingSupport(tableViewer));
The editing works so far good, but there are two issues:
1.) The other editors (one being a tree viewer in the same implemented UI view and other e.g. the reflective Ecore editor) are not getting dirty, even though the table editors columns show the changed values after giving the new values of the attributes. So the save options of the Eclipse are not being activated.
2.) I also want to add the support for Undo/Redo by implementing the EditingDomain. But I don't exactly know how to combine these two aspects, the EditingSupport for JFace and the EditingDomain for EMF. Alone getting the EditingDomain doesn't work. I guess I need to implement the functions of my EditingSupport methods as Actions which I then register into the EditingDomain. Or is there a simpler way two let these two aspects interact together?
Every help will be appreciated, thanks a lot!
Re: EditingSupport and EditingDomain [message #1249267 is a reply to message #1248977] |
Mon, 17 February 2014 23:43   |
On 17/02/2014 10:22 PM, Emre T wrote:
> Hello,
Are you using org.eclipse.emf.databinding.edit.EMFEditObservables or
org.eclipse.emf.databinding.edit.EMFEditProperties?
All changes to the model must be done via commands executed on the
editing domain's command stack.
You said you use data binding, but it's not clear how. Generally I'd
expect your cell editor to do something like what you see in
org.eclipse.emf.edit.provider.ItemPropertyDescriptor.setPropertyValue(Object,
Object), though your case is probably simpler because you know exactly
which feature of which type of object you're editing.
Re: EditingSupport and EditingDomain [message #1249658 is a reply to message #1249626] |
Tue, 18 February 2014 08:42   |
Emre,
Comments below.
On 18/02/2014 1:59 PM, Emre T wrote:
> Hello Ed, thanks for the quick reply.
> I am using EMFProperties at the detail-part. Like this:
> IObservableValue value =
> EMFProperties.value(attribute).observeDetail(view.getMaster());
Didn't I suggest you use EMFEditProperties?
> I have implemented the setValue()-method in my MyEditingSupport as
> follows:
> EAttribute attr = (EAttribute) ((IEMFObservable)
> element).getStructuralFeature();
> Object obj = ((EObject) ((IEMFObservable)
> element).getObserved()).eGet(attr);
> if (obj instanceof String)
> ((EObject) ((IEMFObservable) element).getObserved()).eSet(attr, value);
This has to be done with a command. Did you look at
Object)?
I also get the sense that this is all overly complex, bypassing what
data binding should be doing for you. I.e., shouldn't you just be using
org.eclipse.core.databinding.property.value.IValueProperty.setValue(Object,
Object)?
> And no, I don't know at compile time exactly, what features my UI
> needs to show and can be edited. I observe them and collect them into
> a list as a master, which later is put into the table viewer as Input.
> Best regards,
> Emre
Re: EditingSupport and EditingDomain [message #1249668 is a reply to message #1249658] |
Tue, 18 February 2014 08:56   |
Hello Ed,
yes, indeed you have. And I have changed the line to the following:
IObservableValue value = EMFEditProperties.value(editingDomain, attribute).observeDetail(view.getMaster());
Where I try to get the editingDomain like this:
private EditingDomain editingDomain;
public void setActivePart(IAction action, IWorkbenchPart workbenchPart) {
if (workbenchPart instanceof IEditingDomainProvider) {
editingDomain = ((IEditingDomainProvider) workbenchPart).getEditingDomain();
Though it is a null. First I just wanted to test, whether EMFEditProperties would work my approach, but of course now I need to provide a real EditingDomain instance.
Furthermore I don't understand what you mean by "I also get the sense that this is all overly complex, bypassing what
Object)?"
Is my databinding somehow wrong? I need to use the IObservableValue which is my master from a listened treeviewer.
Thanks again.
Emre
[Updated on: Tue, 18 February 2014 08:59] by Moderator
Re: EditingSupport and EditingDomain [message #1249670 is a reply to message #1248977] |
On 17-02-14 22:22, Emre T wrote:
> Hello,
Typically various editors will have their own editing domain, so will
not know about a dirty command stack. (Which triggers the dirtyness of
the Editor for ISaveablePart2).
You said you implemented EditingSupport get/setValue() but how?
What I do is update the viewer (viewer.update(element,value). because
the viewer is bound with EMFDatabinding, the
change is applied. (Note EMF Databinding has two options, with or
without EditingDomain. You should use the one which includes
EditingDOmain).
Re: EditingSupport and EditingDomain [message #1249683 is a reply to message #1249670] |
Tue, 18 February 2014 09:12   |
Christophe Bouhier wrote on Tue, 18 February 2014 08:56
Oh, so the dirtyness must be implemented using the ISaveablePart2 in the UI? The databinding actually happens in my UI, which has a treeviewer(master) and a tableeditor(detail). That my UI implements the ISaveablePart2 was going to be one of my futere tasks. But I guess, I will be doing it sooner.
EditingDOmain).
I have implemented the getValue and setValue as follows:
protected Object getValue(Object element) {
EAttribute attr = (EAttribute) ((IEMFObservable) element).getStructuralFeature();
Object obj = ((EObject) ((IEMFObservable) element).getObserved()).eGet(attr);
return obj.toString();
and
protected void setValue(Object element, Object value) {
if (obj instanceof String) {
} else if (obj instanceof Integer) {
((EObject) ((IEMFObservable) element).getObserved()).eSet(attr, Integer.valueOf((String) value));
} else {
// for further types
viewer.update(element, null);
Yes, the update method works. The new values are indeed set. I can see it in the tableeditor and also in the underlying .xmi instance of the model. But I can't save it, the editors (treeviewer from my own UI and the standard ecore editor) are not getting dirty or starred, so that the save option is not active. When I close and reopen the model instance, the changes are then gone.
Emre
Re: EditingSupport and EditingDomain [message #1249699 is a reply to message #1249683] |
Tue, 18 February 2014 09:31   |
On 18-02-14 15:12, Emre T wrote:
> Hello,
I don't know about the containers (Parts) for your viewers, is
IEditorPart or IViewerPart or...? and are there multiple? Perhaps each
with their own EditingDOmain?
IEditorPart implements ISaveablePart which is what the default generated
EMF editor uses...You shouldn't need to do anything here.
If you put your viewers in an IViewerPart, you would need explicitly
implement the ISavablePart (or ISavablePart2). Simply look at the
generated EMF editor, you can see how it's done. (The command stack
listener is the interresting bit, it fires a propertychange ).
>> EditingDOmain).
> @Override
> and
> @Override
> } else {
> Best regards,
> Emre
Re: EditingSupport and EditingDomain [message #1249724 is a reply to message #1249711] |
Tue, 18 February 2014 10:04  |
On 18-02-14 15:46, Emre T wrote:
> My UI extends the ViewPart and in createPartControl() I initialize my
> tree and table viewer. So I need to implement ISaveablePart2 implicitly,
> right?
Yes it seems.
> What about the Undo/Redo functionality? How can I integrate my
> EditingSupport with the EditingDomain, so the actions made in
> getValue/setValue() methods bevome undoalbe/redoable? Any tips regarding
> this?
When your viewer is bound with an EditingDomain. (Your observable uses
EMFEditProperties as Ed explained), then simply updating the value in
the viewer should let the observable use a command on the editing domain
command stack, hence making it dirty, undoable etc..
But, as you use a ViewPart, I don't know how the EMF Edit Actions are
tight to this ViewPart, which they need to be. Have a look at i.e. the
UndoAction, the part should implement IEditingDomainProvider so it can
deal with the cmmand stack.
Basically, your challenge is to replicate the stuff generated by EMF on
an IEditorPart with a ViewPart. A ViewPart has no
EditorActionBarContributor which EMF extends, so you need to work harder
for this.
As an alternative, you could work directly on e4. EMF doesn't generate
pure e4 code, but there is an example which could prove useful here:
https://github.com/dzonekl/e4mf
Cheers Christophe
> Best regards,
> Emre
Current Time: Sun Sep 14 17:36:21 EDT 2025
Powered by FUDForum. Page generated in 0.04463 seconds
