Eclipse & Axis2 Problem [message #205045] |
Tue, 27 November 2007 20:50 |
Originally posted by: brfullwood.hotmail.com
I'm new to Eclipse and Axis 2. I'm using the following tutorial to set up
my first Axis Web Service:
http://www.eclipse.org/webtools/community/tutorials/BottomUp Axis2WebService/bu_tutorial.html
When I try to run the example (start the server), I get the following
exception (I haven't included the entire stack trace):
[ERROR] The mex-1.3.mar module, which is not valid, caused
org.apache.axis2.mex.MetadataExchangeModule
org.apache.axis2.deployment.DeploymentException:
MORE TRACE LINES
Caused by: org.apache.axis2.deployment.DeploymentException:
MORE TRACE LINES
Caused by: java.lang.ClassNotFoundException:
And then the service, obviously, isn't available/doesn't work.
Here's my environment:
Eclipse Version: 3.3.1.1 Build id: M20071023-1652 (the Europa build)
JDK Version: 1.6.0_03
Axis 2 Version: 1.3
Tomcat Verstion: 6.0.14
Your help is very much appreciated. I'd really love to get away from ASMX
Web Services.
Re: Eclipse & Axis2 Problem [message #205080 is a reply to message #205045] |
Wed, 28 November 2007 21:17 |
Originally posted by: khvatov.yahoo.com
I had this problem when used newest release of WTP 2.01.
The problem went away after downgrading to WTP 2.0.
Hope it helps.
Alex
"Bruce Fullwood" <brfullwood@hotmail.com> wrote in message
news:c8a6eba60790ff8c1e14b13758a4bf95$1@www.eclipse.org...
> MORE TRACE LINES
> MORE TRACE LINES
> Axis 2 Version: 1.3
> Web Services.
Re: Eclipse & Axis2 Problem [message #205235 is a reply to message #205045] |
Fri, 30 November 2007 23:58 |
Kathy Chan Messages: 93 Registered: July 2009 |
Member |
Hi Bruce,
I'm able to reproduce the problem on WTP 2.0.1 using Axis2 v1.3. However,
even though I got that stack trace in the server console, the Web service
worked properly. If you use Axis2 v1.2 with WTP 2.0.1, you would not get
that problem in the server console.
Please note that this problem has been fixed in WTP bugzilla defect 206967
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=206967). It's available in
WTP 2.0.2 driver or WTP 3.0 after 11/01.
Kathy Chan
> MORE TRACE LINES
> MORE TRACE LINES
> Axis 2 Version: 1.3
> Web Services.
FUDForum. Page generated in 0.02907 seconds
