Home » Archived » BIRT » Update Troubles
Update Troubles [message #204835] Tue, 05 December 2006 11:48 Go to next message
Originally posted by: david.synergies4u.com
Hey All,
Just used the Eclipse update manager and got updates for SDK, WTP and BIRT
and seemed to have lost BIRT altogether. Everything in the Report Design
perspective shows errors such as:
- Unable to create this part due to an internal error. Reason for the
failure: The editor class could not be instantiated. This usually indicates
that the editor's class name was mistyped in plugin.xml.
or
- Unable to create view: Plug-in org.eclipse.birt.report.designer.ui was
unable to load class
org.eclipse.birt.report.designer.ui.views.attributes.Attribu teView.
Stack trace shows ClassNotFoundExceptions for BIRT stuff (ReportEditorProxy,
AttributeView,etc.)
Any clues on why this happened and how to fix it. Deadlines are looming and
BIRT may get tossed if I can't keep the IDE going....
Eclipse
Re: Update Troubles [message #204978 is a reply to message #204835] Tue, 05 December 2006 19:24 Go to previous messageGo to next message
David,
Did you do the following?
http://download.eclipse.org/birt/downloads/updmaninst.php
Jason
"David Connell" <david@synergies4u.com> wrote in message
news:el47ti$1k3$1@utils.eclipse.org...
> Hey All,
> indicates
> or
> (ReportEditorProxy,
> AttributeView,etc.)
> and
> Eclipse
Re: Update Troubles [message #205729 is a reply to message #204978] Sun, 10 December 2006 21:38 Go to previous messageGo to next message
Originally posted by: paul.lecky.paradisefood.com.au
I have the same problem. On Friday I did a fresh install of Eclipse and
followed the procedure below. Only I also istalled TP, Data Tools and
Visual Editor from the Callisto Site. All was working well after the
installs.
This morning I used update manager to "search for updates for currently
installed features" and installed the updates. Now I cant create a new
Report project because the report wizard class cant be found and I am
receiving similar messages to David.
Jason Weathersby wrote:
> David,
> Jason
>>Hey All,
>>indicates
>>or
>>(ReportEditorProxy,
>>AttributeView,etc.)
>>and
>>Eclipse
Re: Update Troubles [message #205736 is a reply to message #205729] Mon, 11 December 2006 00:07 Go to previous messageGo to next message
I wanted to try BIRT out and had the same problem. First, I installed it
into my current eclipse directory and it didn't work. So, I downloaded
the latest 3.2.1 SDK and did a clean install. I then used update manager,
which added three patches. Did a -clean start. Then:
1. Added BIRT with the update manager, as described in the link in the
previous message.
2. Did a -clean start and BIRT worked fine.
3. Used update manager, which found four items: Eclipse Project SDK
3.2.1.r321.v20060801_..., w3c sac 1.3.0.v20060811, apache commons codec
1.3.0,
and mozilla rhino 1.6.0.v20061108.
4. After installing the update, did a -clean start.
5. BIRT no longer works, similar to the descriptions in previous messages.
I deleted eclipse sdk and reverted to my pre-BIRT-update version (which I
had saved, since I went through this failure scenario twice). Spent most
of the day fiddling with this, so hope someone can offer a solution.
Michael Schmidt
Eclipse - when its good, its very good, but when its bad...
Re: Update Troubles [message #205742 is a reply to message #205736] Mon, 11 December 2006 00:39 Go to previous messageGo to next message
Also, the BIRT documentation is not showing up in my sdk help system.
Again, thanks all in advance for any help
Michael Schmidt
Re: Update Troubles [message #205750 is a reply to message #205736] Mon, 11 December 2006 02:57 Go to previous messageGo to next message
Originally posted by: johnw.innoventsolutions.com
Michael,
I've always had issues with the update manager in Eclipse, regardless of
package. I usually recommend to people to get the All-in-One download
from the BIRT website if they want to try BIRT out.
John
> it into my current eclipse directory and it didn't work. So, I
> downloaded the latest 3.2.1 SDK and did a clean install. I then used
> update manager, which added three patches. Did a -clean start. Then:
> previous message.
> 1.3.0,
> I had saved, since I went through this failure scenario twice). Spent
> most of the day fiddling with this, so hope someone can offer a solution.
> Michael Schmidt
Re: Update Troubles [message #205757 is a reply to message #205750] Mon, 11 December 2006 04:39 Go to previous messageGo to next message
It seems that the 'Eclipse BIRT Report Designer Framework
2.2.0.v20061117-1020 has the bug, when I diable this update version and
enable the old one 2.2.0.v20061017-1021,the Report can open again ,no
above error message like you mentioned,good luck everbody!
Re: Update Troubles [message #206639 is a reply to message #205757] Fri, 15 December 2006 09:55 Go to previous messageGo to next message
I don't concur with your conclusion about the version number. I am using
2.1.1v20060926-0959 per Jason's earlier instructions and I still can't
open the Report Designer Perspective.
My hunch is that the culprit is one of the more recent updates/patches to
an underlying component.
BIRT was working fine on my system as of a month or more ago. I dropped
that installation fearing it was corrupted and I reinstalled Eclipse
yesterday from scratch.
I'll try removing some of the updates and I'll post another message if I
come across anything noteworthy.
jb
Re: Update Troubles [message #206669 is a reply to message #206639] Fri, 15 December 2006 10:34 Go to previous messageGo to next message
I disabled all of the patches to my Eclipse installation to no effect.
In case anyone else is in a bind (my presentation is Monday) and needs a
quick way to get a working installation, here is what I did to get things
going again:
1. Download the latest build 2.2M2 of the BIRT Report Framework and
installed it. This version in this release is 2.2.0.v20061117-1020.
2. Unzip the package to the correct directory
3. Start Eclipse and select the Help->Software Updates->Manage
Configuration menu item. In the Product Configuration dialog, toggle the
'Show Disabled Features' so that the complete roster is visible.
4. Right-click the Data Tools Platform Open Data Access Designer
0.9.1.200609201 (or some such similar version) and choose to replace it
with the version that was packaged with 2.2M2 [1.0.0.200611161].
5. Restart Eclipse when prompted.
6. Go back to the Product Configuration dialog and replace the current
BIRT version [2.1.1] with the new version [2.2.0].
7. Restart Eclipse when prompted.
After that I was able to open the Report Designer and get back to work.
This information is very specific to my environment so your mileage may
vary.
jb
Re: Update Troubles [message #207054 is a reply to message #206669] Mon, 18 December 2006 09:28 Go to previous messageGo to next message
Jonathan,
Thanks for posting this. I am still looking into why this is not working.
Jason
"Jonathan Brown" <jonathan_w_brown@hotmail.com> wrote in message
news:9218ce7d06748a00e714f67b8455ad86$1@www.eclipse.org...
> going again:
> vary.
> jb
Re: Update Troubles [message #208070 is a reply to message #207054] Thu, 21 December 2006 13:59 Go to previous message
> Jonathan,
> Jason
>> going again:
>> vary.
>> jb
I tried the below and it still doesn't work.. are there any other
suggestions? This is a very serious problem for new systems running
eclipse and birt. Right out of the box it's broken.
Previous Topic:(repost) Birt Drill Down with Open Reports
Next Topic:Extracting the resultset problem.
Current Time: Tue Oct 28 11:27:29 EDT 2025
Powered by FUDForum. Page generated in 0.23774 seconds
