Home » Newcomers » Newcomers » Issue with Eclipse Kepler and Apache 7.0 compatibility(Not able to start Tomcat via eclipse)
Issue with Eclipse Kepler and Apache 7.0 compatibility [message #1245422] |
Thu, 13 February 2014 19:54 |
shir m Messages: 1 Registered: February 2014 |
I am facing issue while starting tomcat 7.0 via eclipse. I am using eclipse kepler and using Windows 7 OS.
When i start Tomcat via "Services" option, it starts fine,
and when i try localhost:8080 in browser, the apache default page opens ok.
However when i add Tomcat 7.0 in Eclipse and try to start Tomcat;i get the below error.
Several ports (8005, 8080, 8009) required by Tomcat v7.0 Server at localhost are already in use. The server may already be running in another process, or a system process may be using the port. To start this server you will need to stop the other process or change the port number(s).
As suggested by others, i change my port numbers (random numbers), 8010,9090,8019.
In this scenario Apache server starts up fine and localhost:9090 is working ok too, however i get similar error while trying to start server via eclipse
Several ports (8010, 9090, 8019) required by Tomcat v7.0 Server at localhost are already in use. The server may already be running in another process, or a system process may be using the port. To start this server you will need to stop the other process or change the port number(s).
Please suggest, how do i actually find if any application are using the above port or
kindly suggest some alternative to overcome this issue,
Thanking in anticipation
Re: Issue with Eclipse Kepler and Apache 7.0 compatibility [message #1247019 is a reply to message #1245422] |
Sat, 15 February 2014 19:00 |
On 02/13/2014 02:31 PM, shirshendu mukherjeee wrote:
> the below error.
> number(s).
> 8010,9090,8019.
> via eclipse
> number(s).
> above port or kindly suggest some alternative to overcome this issue,
> Thanking in anticipation :)
If you're certain you actually killed the previous running instance of
Tomcat, then you've got another instance running on your computer. You
can either investigate that and kill it (but, maybe you're doing it on
purpose?) or you can double-click the server in the Servers view and
change the ports it uses.
I'm not a Windows guy, but I suspect you wouldn't have too much trouble
Googling on how to determine why Tomcat is running separately on your
box. In any case, that isn't an appropriate question in this forum which
is why no one's answered yet.
Hope this helps.
Current Time: Fri Apr 26 13:35:21 GMT 2024
Powered by FUDForum. Page generated in 0.11101 seconds
