Home » Language IDEs » ServerTools (WTP) » XSD editor: nillable property?
XSD editor: nillable property? [message #204023] Fri, 09 November 2007 04:54 Go to next message
Originally posted by: mauro.molinari.cardinis.com
Hi there!
Before submitting an enhancement request... anyone knows if there's an
hidden option in Preferences view to set the "nillable" property of an
XSD element??? I hardly believe it is not present...
Mauro.
Re: XSD editor: nillable property? [message #204056 is a reply to message #204023] Fri, 09 November 2007 11:42 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
Mauro Molinari wrote:
> Hi there!
Mauro, you are correct it is not there. All other options are available
through the Advanced tab of the Properties View, but nillable is not one
of them.
You can add it in the source view, via content assist (CTRL+SPACE) when
in the xsd element.
I've opened the following bug for this enhancement:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=209356
Please feel free to add your comments to that as well.
Re: XSD editor: nillable property? [message #204093 is a reply to message #204023] Fri, 09 November 2007 12:42 Go to previous messageGo to next message
Hi Mauro, do you mean in the properties view for an element? Or do you
want an option in the preferences so that any newly created element has
nillable set to true or false? Either way, please open an enhancement bug
for what you want.
Thanks.
Re: XSD editor: nillable property? [message #204100 is a reply to message #204056] Fri, 09 November 2007 12:45 Go to previous messageGo to next message
Thanks David for opening the bug.
Re: XSD editor: nillable property? [message #204179 is a reply to message #204100] Sun, 11 November 2007 00:17 Go to previous messageGo to next message
I've created an initial patch for this bug, may do a bit of tweaking
with it to make sure it's only enabled when it can be used, and that
initial values are being set correctly.
Dave
Re: XSD editor: nillable property? [message #204228 is a reply to message #204093] Mon, 12 November 2007 04:07 Go to previous message
> bug for what you want.
> Thanks.
Hi Keith,
I meant a field in the properties view.
Thanks David for the patch!
Mauro.
Previous Topic:Open Source Software Research
Next Topic:JSP version mismatch using WTP with BEA?
Current Time: Sun Nov 09 06:51:39 EST 2025
Powered by FUDForum. Page generated in 0.04457 seconds
