Home » Modeling » GMF (Graphical Modeling Framework) » Context Menu
Context Menu [message #203233] |
Sun, 24 August 2008 15:42 |
Originally posted by: andrestenorio.cable.net.co
How do I customize the context menu for an editor in GMF? I want to remove
the default options and add some new features to work in my graphical
editor, but I cannot find what I have to change...
Andres Tenorio
Re: Context Menu [message #203242 is a reply to message #203233] |
Mon, 25 August 2008 02:18 |
I solved the problem...
"Andres Tenorio" <andrestenorio@cable.net.co> wrote in message
news:g8rvh6$a67$1@build.eclipse.org...
> Hello,
> Andres Tenorio
Re: Context Menu [message #203248 is a reply to message #203242] |
Mon, 25 August 2008 04:49 |
Originally posted by: manojm.blr.interrasystems.com
Hi! Andres,
How have you solved the problem, I am facing the same.
Moreover, could you please tell how to plug it(created editor) with with
exisating project?
Manoj
>> Hello,
>> remove the default options and add some new features to work in my
>> graphical editor, but I cannot find what I have to change...
>> Thanks,
>> Andres Tenorio
Re: Context Menu [message #203270 is a reply to message #203248] |
Mon, 25 August 2008 09:37 |
Originally posted by: martin.divbyzero.net
This can be achieved using the extension point concept of plugins.xml.
See part 3 of the GMF Mindmap tutorial for an explanation.
Martin
Re: Context Menu [message #203292 is a reply to message #203270] |
Mon, 25 August 2008 11:33 |
Thanks for your reply.
But, still I am unable to remove following menus-
Add, Navigate, Filters, Delete From Diagram/Model, Show Property View.
Manoj
> Martin
Re: Context Menu [message #203328 is a reply to message #203292] |
Mon, 25 August 2008 22:42 |
I solved part of the problem... I added new options in the context menu just
like part 3 of mindmap tutorial... but I'm still unable to remove default
options... I'm still looking for the answer.
Andres
"Manoj Mitra" <manojm@blr.interrasystems.com> wrote in message
news:g8u59e$ia$1@build.eclipse.org...
> Regards,
> Manoj
>> Martin
Re: Context Menu [message #204476 is a reply to message #203328] |
Fri, 05 September 2008 06:37 |
Hi!
Have you found some way out?
Manoj
> just like part 3 of mindmap tutorial... but I'm still unable to remove
> default options... I'm still looking for the answer.
> Regards,
> Andres
>> Regards,
>> Manoj
>>> plugins.xml. See part 3 of the GMF Mindmap tutorial for an explanation.
>>> Martin
Re: Context Menu [message #204642 is a reply to message #204476] |
Sun, 07 September 2008 16:12 |
Hi...
No, I haven't found a solution yet... I'm starting to think that there's no
way to delete the default context menu...
Andres
news:48C0D395.2040803@blr.interrasystems.com...
> Hi!
> Regards,
> Manoj
>> Hi,
>> Regards,
>> Andres
>>> Regards,
>>> Manoj
>>>> Martin
Re: Context Menu [message #206221 is a reply to message #206214] |
Mon, 22 September 2008 10:43 |
Hi!
Me too, have the same query.
Please suggest us.
Manoj
ye wrote:
> I'm also trying to modify the context menu,but I can't find the
> buildContextMenu() function and not even the
> DiagramEditorContextMenuProvider in the xxx.diagram.part?
> Do I need to create this .java file by myself?
> Thanks!
> Ye
> Hoang Quach Dinh wrote:
>> Hi,
>> I'm a new member.
>> We only need to modify method public void buildContextMenu(final
>> IMenuManager menu) of class
>> xxx.diagram.part.DiagramEditorContextMenuProvider.
>> public void buildContextMenu(final IMenuManager menu) {
>> getViewer().flush();
>> try {
>> TransactionUtil.getEditingDomain(
>> (EObject) getViewer().getContents().getModel())
>> .runExclusive(new Runnable() {
>> public void run() {
>> ContributionItemService
>> .getInstance()
>> .contributeToPopupMenu(
>> DiagramEditorContextMenuProvider.this,
>> part);
>> menu.remove(ActionIds.MENU_DIAGRAM_ADD);
>> menu.remove(ActionIds.MENU_NAVIGATE);
>> menu.remove(ActionIds.MENU_FILTERS);
>> menu.remove(ActionIds.ACTION_DELETE_FROM_MODEL);
>> menu.remove(ActionIds.ACTION_DELETE_FROM_DIAGRAM);
>> menu.remove(ActionIds.ACTION_SHOW_PROPERTIES_VIEW);
>> } catch (Exception e) {
>> ResearchDiagramEditorPlugin.getInstance().logError(
>> "Error building context menu", e);
>> Hoang Quach Dinh.Hi,
> buildContext function in the xxx.Diagram.part.
Re: Context Menu [message #206421 is a reply to message #206413] |
Tue, 23 September 2008 08:31 |
Hi!
Without creating RCP, I have built the Editor.
In that regard, how should I do that?
Manoj
> Ah, when you xxx.gmfgem from xxx.gmfmap you should check in RCP in GMF
> Dashboard (I suppose you generate xxx.gmfgen by GMF Dashboard).
> Hoang Quach Dinh.
Current Time: Thu Sep 26 19:57:56 GMT 2024
Powered by FUDForum. Page generated in 0.05942 seconds
