Home » Eclipse Projects » Eclipse Platform » Delete key Java Editor
Delete key Java Editor [message #203149] Fri, 27 February 2004 12:49 Go to next message
This is getting better every day!!!
build id:
200402270010
the delete key remove 2 characters
Re: Delete key Java Editor [message #203936 is a reply to message #203149] Mon, 01 March 2004 05:22 Go to previous messageGo to next message
> build id:
> 200402270010
Hello
Forgive me if I am being a bit to harsh, but what is the use of such a
post ?!?!
It does not help in any manner.
This build is a dev build, therefore, it is not bugfree, and is even not
intended to be.
If you really want to help, you should post a bug report.
Such posts only discredit their authors ...
Jean
"No brain, no headache"
Re: Delete key Java Editor [message #204620 is a reply to message #203149] Tue, 02 March 2004 12:10 Go to previous messageGo to next message
Originally posted by: douglas.pollock.magma.ca
Thank you for your kind comments.
This has been filed as Bug 53489.
Re: Delete key Java Editor [message #210344 is a reply to message #203149] Fri, 12 March 2004 03:09 Go to previous messageGo to next message
Originally posted by: lizhih.cn.ibm.com
Hi , I don't know exactly what bug you fixed , but the del key not work in
the graphical editor in my multipage editor , would please help me to check
this? thank you.
"Andre Arpin" <arpin@kingston.net> wrote in message
news:Xns949C831B7B9DDarpinkingstonnet@204.138.98.10...
> build id:
> 200402270010
Re: Delete key Java Editor [message #211387 is a reply to message #210344] Mon, 15 March 2004 11:36 Go to previous message
> check this? thank you.
There is already a thread you started on this elsewhere, which I've been
replying to. The delete problem mentioned here is in the 3.0 development
stream, and has nothing to do with multi-page editors in 2.1.3.
d
Previous Topic:Hotkey develop for multipage graphical editor
Next Topic:paste does not work in text-editor
Current Time: Thu Aug 14 00:13:36 EDT 2025
Powered by FUDForum. Page generated in 0.03550 seconds
