Re: [Xcore] Something wrong with casts? [message #1240977 is a reply to message #1240451] |
Fri, 07 February 2014 09:43 |
Ed Merks Messages: 33216 Registered: July 2009 |
Phillip,
Comments below.
On 06/02/2014 2:48 PM, Phillip Keldenich wrote:
> Hey, for the lack of documentation stating that casts do very strange
> things in xcore, I believe this is a bug:
> package test
> //import java.lang.Double // - these are not important
> //type Double wraps Double // - problem occurs with and without these lines
> class Test {
> op Double test(Object obj) {
> if(obj instanceof Double) {
> return (Double)obj // gives an error about
> // being unable to convert from Class<Double> to Double ?
> } else {
> return new Double(0.0)
> Is this known?
This is more of an Xbase question. With Xbase casting is done with
using "as", i.e., "obj as Double". But if you try that, you'll notice
it warns you that the cast is unnecessary. Xbase knows obj must be of
type Double in that context. How smart is that? :-P
> How does one workaround this?
> If this is the desired behaviour, how does one perform casts properly?
> Cheers,
> Phillip
Ed Merks
Re: [Xcore] Something wrong with casts? [message #1244134 is a reply to message #1240977] |
Wed, 12 February 2014 00:00 |
Phillip Keldenich Messages: 9 Registered: January 2014 |
Am 07.02.2014 10:43, schrieb Ed Merks:
> Phillip,
> Comments below.
>> package test
>> lines
>> class Test {
>> } else {
>> Is this known?
>> Cheers,
>> Phillip
Thank you. Using "as" works.
The automatic detection however doesn't.
Re: [Xcore] Something wrong with casts? [message #1244317 is a reply to message #1244134] |
Wed, 12 February 2014 06:48 |
Phillip,
I think the automatic detection is new to Xtext 2.5.1 (or maybe new to
the ongoing 2.6 development), i.e., it's a new feature of Xbase.
>> Phillip,
>> Comments below.
>>> package test
>>> lines
>>> class Test {
>>> } else {
>>> Is this known?
>>> Cheers,
>>> Phillip
Ed Merks
FUDForum. Page generated in 0.03181 seconds
