Re: Deployment assembly failed on Juno [message #1240460 is a reply to message #1240067] |
Thu, 06 February 2014 14:13 |
Larry Isaacs Messages: 1354 Registered: July 2009 |
On 2/5/2014 6:31 PM, David Delannoy wrote:
> I have a problem in Juno WTP about deployment assembly operation. I have
> 2 projects in my workspace; one is a Dynamic Web Project and the other a
> simple java project. I need to include the java project into the web
> project to run web project in Tomcat 5.5. I use for that the deployment
> assembly property of the web project. It works well for the dependencies
> jars of the java project, it means they are added automaticaly in the
> /WEB-INF/lib directory in Tomcat. However, it doesn't work for the
> classes of the java project. I've added throw the deployment assembly
> the java project and it seems that everything is ok because eclipse
> indicates that a specific jar will be deployed in the WEB-INF/lib but
> when i run Tomcat, it doesn't work, there is no such jar file in the
> WEB-INF/lib. Is it a known bug? Did I miss something?
> Sorry for my poor english and thank you for you precious help,
> David
Just to be sure, which "WEB-INF/lib" are you looking in for the built
jar for the Java project? Is it the one under the WebContent folder in
your Dynamic Web Project or the one down under
".metadata\.plugins\org.eclipse.wst.server.core\tmp?\wtpwebapps" in your
workspace? Note that it will only appear in the published webapp that
appears under the
directory. If it is not appearing there, then we will need to diagnose why.
Larry
FUDForum. Page generated in 0.03835 seconds
