Home » Modeling » EMF » EMF Localization questions
EMF Localization questions [message #1239276] |
Mon, 03 February 2014 20:56 |
Patrick Tournet Messages: 17 Registered: July 2009 Location: Aix-en-Provence, FRANCE |
Hello everyone,
I'm still discovering EMF (I'm reading right now the 2nd edition of the EMF book), but keeping in mind the upcoming challenges of my project and especially the multi-lingual capabilities. And as I haven't found all the answers yet in all I've read, I'm turning to you...
As an example framework for my questions, I'll use the Library tutorial (a Library contains Books and Writers, a Book has a Writer, a Writer has written Books, ...)
First of all, the easy part (I think) : if my app should support English and French, I'd like to read {Library, Book, Writer} or {Bibliothèque, Livre, Auteur} based on the active language. I've seen that the strings are located in the plugin.properties of the .edit plugin, so my guess is that there must be a way to create localized plugins to load the resources from.
But, assuming, I'm right, is there a way to achieve that, with runtime editable strings ? (I don't want to have to compile a plugin to get a new translation). I suppose there is, but where should I look to find how to do it ?
The second, would be the icing of the previous cake : I've seen that the model can be persisted as a XMI file and that is really nice. But is there a way to make the XML tags also localizable ? (ex: <writer name="JRR Tolkien"> or <auteur nom="JRR Tolkien"> based on the current language). I'm aware that would imply a new XML Schema for each language, but that could be a very valuable asset in some cases (especially in companies that operate in several countries and where not everyone speak one common language).
At last, I need to be able to achieve the localization of the objects, meaning that a book has a title, yes, but not the same in French and English (except for 1984 ). And I would like to have only 1 book, but getting "The hobbit" or "Bilbo, le hobbit" as its title depending on the language I'm using.
Of course, creating a "title_en" and a "title_fr" String as EAttribute of Book is not an option, as I would like to be able to add more languages without having to update the model. I guess it should be a fairly standard issue, but as I failed to come across a solution, any pointer would be appreciated.
Thanks for your time.
I can do anything and I can do it better than anyone. Be as I am : be the best !
Re: EMF Localization questions [message #1240968 is a reply to message #1239276] |
Fri, 07 February 2014 09:28 |
Ed Merks Messages: 33142 Registered: July 2009 |
Patrick,
Comments below.
On 03/02/2014 9:56 PM, Patrick TOURNET wrote:
> Hello everyone,
Yes, generally you'd have additional plugin.properties for the different
languages. But the'd not be additional plugins. You could put them in
the same plugin or contribute them via fragments. You can look at how
http://www.eclipse.org/babel/ provides translations for such things.
> how to do it ?
Runtime editable is asking for a lot. Even dynamic switching of locales
is not generally supported.
> language).
No, definitely not. You should try to avoid such things. Translation
should be focused on the presentation to the user, not changing the
persistence representation.
Sounds like a bit of a disaster...
> English (except for 1984 :d ). And I would like to have only 1 book,
That's also quite tricky. There's nothing special in EMF to support
such things, and even if you were to hand do something like that in Java
directly, you're faced with the same problem, i.e., how to represent that?
Yes, that would be very ugly...
It's a tricky problem and I'm not sure anyone even has an good "hand
written Java" solutions for it.
Ed Merks
Current Time: Fri Apr 26 23:30:55 GMT 2024
Powered by FUDForum. Page generated in 0.03633 seconds
